Results 1 to 12 of 12
Reload Thread: install help
    basshead38114's Avatar
    basshead38114 is offline Junior Member
    May 2014
    memphis tn
    install help
    Wassup car audio...im new here...im comin to a problem installing my system...at first i had b.s. Polk audio 12's...with a 2000 watt pyledriver amp....and it was bridged...the amp blew the polk audio subs...so I went and bought pioneer championship series pro 12's...as soon as I hooked them up I noticed they wasn't hitting hard...I tried tweaking the amp and still nothin. ..now even tho my polk audio blew, they hit harder than my current setup...so I tried to bridge the amp and when I turned the vol up the amp went into protect mode...and that is my problem...thanks for the help
    bigd26's Avatar
    bigd26 is offline Member
    May 2014
    Toronto
    41
    7 Post(s)
    Re: install help
    is it still in protect mode? ur wiring could be messed up,
    May 2014
    memphis tn
    Re: install help
    Yes...the amp stays n protect mode until I cut it off...I turn the car back on and its ok till I turn up the vol...then it goes red
    garychoffmann's Avatar
    garychoffmann is online now CarAudio.com Elite
    Mar 2011
    Missouri
    1,972
    6 Post(s)
    544 Post(s)
    Re: install help
    That amp cannot do 2 ohm bridged. Have to run each channel to a sub. Polks were probably a better speaker than the pioneers. Polk are not junk. We're the polks dual voice coil?
    May 2014
    memphis tn
    Re: install help
    Polls were not dual and the amp was bridges with them...I jus knew I was gonna hit harder with the pioneer subs...shuda I keep the amp and by others subs or vice versa?
    Mar 2011
    Missouri
    1,972
    6 Post(s)
    544 Post(s)
    Re: install help
    Probably 8 ohm subs. Definately a new amp. A small 500 to 600 watt true power amp would probably do pretty decent on those subs.
    May 2014
    memphis tn
    Re: install help
    500-600 watt amp for 3500 watt subs?
    May 2014
    memphis tn
    Re: install help
    Also the pioneer website states that those subs are dual 2ohm and dual 4ohm voice coils
  9. #9
    Mar 2011
    Missouri
    1,972
    6 Post(s)
    544 Post(s)
    Re: install help
    Just caught they were pro's. What model subs do you have? Do or d4? If they are the champion pros you want a good 1800 to 2000 watt amp.
  10. #10
    May 2014
    memphis tn
    Re: install help
    Jus took one out and it says these r D2's...3500 watt max...1000 watts nom....it has 4 speaker connectors grouped together...it almost looks as if they r bridged
  11. #11
    Mar 2011
    Missouri
    1,972
    6 Post(s)
    544 Post(s)
    Re: install help
    You want to run them at 4 ohms so run the speaker in series. Then run each one to a channel on the amp.
  12. #12
    May 2014
    memphis tn
    Re: install help
    4 ohms??? Dnt know how to wire it up like that without step by step help..can u email me so I can send u pics at [email protected]
  1. sub install help
    By jooky in forum Wiring, Electrical and Installation Help
    Last Post: 03-28-2002, 01:34 PM
  2. Component Set Installation help!!!
    By mikey in forum Wiring, Electrical and Installation Help
    Last Post: 02-14-2002, 11:38 AM
  3. install help? again
    By gator01 in forum General Discussion
    Last Post: 01-24-2002, 07:14 PM
  4. head unit install help
    By <SlayeR1> in forum Wiring, Electrical and Installation Help
    Last Post: 12-24-2001, 10:26 PM
  5. need some amp instalation help
    By <baller540> in forum Amplifiers
    Last Post: 12-08-2001, 11:05 PM
