Page 2 of 2 FirstFirst 1 2
Results 16 to 19 of 19
Reload Thread: Can't Find my problem
  1. #16
    fatboytyler's Avatar
    fatboytyler is online now CarAudio.com Elite
    Nov 2013
    Easternl Kentucky
    24
    1,135
    2 Post(s)
    538 Post(s)
    Re: Can't Find my problem
    Dont use different sized ground and power wires... Also, if you're actually drawing 2200 Watts rms on a stock electrical you very well could have killed it due to voltage drops, depending on your stock alt.
    EDIT: Also, were the gains set properly?
    References: mylows10, michaellane, Tantricz, bradl79
    Amp: RF R1200-1D and SoundQubed Q4-120.4
    Speakers: 2 SA-12s in 4 Cubes @ 32 Hz with ES-6iM (Mids), TW-125 (Tweets), EX-530 (X-Over)
    Electrical Singer 275 Amp (Clamped 284+ Amps), 0 Gauge SHCA OFC (Big 3), Mix of 4 Gauge CCA SHCA and Knu, Shitty G24 Lead Acid (RIP to my Deka)
    Quote Originally Posted by C1500martin View Post
    Life has bent you over butt fucked you busted down your throat made you spit it back out onto cow shit and slurp it back up and swallow.
  2. #17
    JakeHigg78's Avatar
    JakeHigg78 is offline Junior Member
    Apr 2014
    Indianapolis, IN
    13
    1 Post(s)
    What do I need to do to keep my amp from getting too much power? Or what do I need to do to keep it from blowing?
  3. #18
    Apr 2014
    THE SOUTH
    110
    62 Post(s)
    Does your amp smell burnt? Or Fried? A lot could cause an amp to blow, but what do mean when you say how do you keep it from getting too much power? Take it to local car audio shop, and ask them to test it.
    Head Piece - Pioneer AVH-X3600BHS
    Door Front - Factory BOSE for now
    Door Rear - Factory BOSE for now
    Tweets - Kicker KST20
    Mids & Highs Amp - Factory Bose for now
    Subs Amp - HiFonics BRX2400.1D
    Subwoofer(s) - (8) Kicker 10CVR104 (Old Schools)
  4. #19
    garychoffmann's Avatar
    garychoffmann is offline CarAudio.com Elite
    Mar 2011
    Missouri
    1,972
    6 Post(s)
    544 Post(s)
    An amp can't receive too much power on a stock electrical system. Problem lies in not getting enough power to the amp. When you under power an amplifier it will often times heat up and cause an internal failure. Just because it lights up does not mean the amp is working. I blew the engine in my car but my headlights still worked. The amp or subs obviously have a problem. What have you done to make sure the subs are not blown? Being a hifonics amp, which tend to be temperamental with voltage/power, I'm guessing your amp is the culprit
  1. Help With Finding My Problem??
    By scotty3x3 in forum Wiring, Electrical and Installation Help
    Last Post: 01-11-2014, 08:01 PM
  2. Can I find my posts?
    By Bubblebass in forum Forum News, Bug Reporting & Usage Questions
    Last Post: 02-08-2010, 08:17 PM
  3. I need help with sub and amp. Can't find the problem
    By Buck in forum General Discussion
    Last Post: 09-11-2008, 01:56 PM
  4. where can i find my factory amp
    By chinxtaboi in forum General Discussion
    Last Post: 06-06-2003, 01:23 PM
Tags for this Thread
