Results 1 to 9 of 9
Reload Thread: recone time?
    elchemo1986's Avatar
    elchemo1986 is offline Member
    Dec 2013
    Coldwater,mi
    36
    7 Post(s)
    recone time?
    https://www.youtube.com/watch?v=UdoN...e_gdata_player
    Please help I have no clue what I need to do here.
    garychoffmann's Avatar
    garychoffmann is offline CarAudio.com Elite
    Mar 2011
    Missouri
    1,972
    6 Post(s)
    544 Post(s)
    Re: recone time?
    Where exactly are you pressing to stop the noise? Check all of your glue joints. See if dustcap is loose anywhere?
    Dec 2013
    Coldwater,mi
    36
    7 Post(s)
    Re: recone time?
    I'm pushing up right under the spiders. I only tried one side didn't try the other. All areas seem to be glue6
    Mar 2011
    Missouri
    1,972
    6 Post(s)
    544 Post(s)
    Re: recone time?
    It's definately not hitting the bottom plate when you were playing it. Does the spider looked stretched or torn anywhere? My guess is the coil is rocking. Meaning that as it travels down its not linear. A few things could be wrong. What led up to the noise? Did it just start? Sub moved or dropped? Probably time for a recone and inspecting each piece could tell you what happened. Look at the coil and see if there are any rub marks anywhere on it.
    Jan 2005
    Farmington, NM
    96
    2,475
    45 Post(s)
    Re: recone time?
    I've seen a lot of lvl 5 triple joints separate. Just a guess from what I've seen, but I bet it hasn't fully separated yet but it's on its way out.
    Dec 2013
    Coldwater,mi
    36
    7 Post(s)
    Re: recone time?
    That's the only tear I saw
    hispls's Avatar
    hispls is offline CarAudio.com Veteran
    Sep 2009
    Cape Cod, Massachusetts
    9,935
    15
    36 Post(s)
    4034 Post(s)
    Re: recone time?
    Those DC softparts are junk. A friend of mine ran LV5, and LV6 and both failed constantly, their turnaround time to send his parts was horrible, and the prices were over-the-top. I got a Sundown Zv2 kit in his LV5 (with an extra spider) and he thought it sounded better than OEM and it definitely held up to his abuse better.
    First of all, at this point, you have nothing to lose by prying off the dustcap. Take a peak under there and you'll be able to see if the cone is separating from the spider there. If so you can just shim up the coil, dump the glue or epoxy of your choice in there, then reattach the dustcap and it should keep it going, if not you may find that the coil former is broken. If you bottomed out the sub hard you could have snapped the former. My friend broke a few formers.
    Assuming that sub is older than a few weeks the coil will not be misaligned in the gap unless you have dropped the sub hard and shifted the pole piece. A coil misaligned from the factory would start rubbing within 4-5 hours of hard play.
    Dec 2013
    Coldwater,mi
    36
    7 Post(s)
    Re: recone time?
    It's older I've had it for a while but hadn't really turned it up..... what's the best recone to get? And if I want to sale it what's the right price? Like it sits
  9. #9
    Dec 2013
    Coldwater,mi
    36
    7 Post(s)
    Re: recone time?
    Any suggestions
  1. Replies: 9
    Last Post: 07-02-2008, 03:14 PM
  2. Recone time(pics inside)
    By bigwheel15 in forum Subwoofers
    Last Post: 04-30-2006, 12:39 AM
  3. RE Recone Time *The Truth*
    By bamaboy in forum Subwoofers
    Last Post: 05-18-2005, 08:16 AM
  4. RE Recone Time
    Last Post: 05-16-2005, 11:23 PM
  5. MT with 500+ burps w/11kw - Recone Time!
    By NDMstang65 in forum Subwoofers
    Last Post: 04-26-2005, 01:16 PM
