Results 1 to 4 of 4
Reload Thread: 2 ohm stable but says produces 1600 watts at 1 ohm can wire it for 1 ohm and be safe?
    chazer188's Avatar
    chazer188 is offline Junior Member
    Apr 2014
    Mt Vernon, IL
    13
    2 Post(s)
    Icon14 2 ohm stable but says produces 1600 watts at 1 ohm can wire it for 1 ohm and be safe?
    i have a QXA1600M and want too wire it to 1 ohm but my amp is stable at 2 ohm. can i wire it to 1 ohm and produce the 1600 watts but not over heat the sub?
    Jepalan's Avatar
    Jepalan is offline CarAudio.com Elite
    Jun 2013
    Midwest
    603
    1 Post(s)
    158 Post(s)
    Re: 2 ohm stable but says produces 1600 watts at 1 ohm can wire it for 1 ohm and be s
    Quote Originally Posted by chazer188 View Post
    Quantum doesn't have a good reputation. There power ratings are not CEA compliant. The amp is not likely to put out RMS anywhere near what the spec says. If it says "2 ohm stable" then don't run it at 1 ohm, you're just asking for trouble (IMO).
    chazer188's Avatar
    Apr 2014
    Mt Vernon, IL
    13
    2 Post(s)
    alright then well here is another question i have a 4 ohm sub that i would like to wire to 1 ohm and did some messing around with the sub and found that if i connect both the positive and negative sides of both voice coils they equal out to .5 ohm on each side will my sub actually work wired like that?
    brian84corvette's Avatar
    brian84corvette is offline CarAudio.com Elite
    Feb 2008
    coral springs FL.
    1,540
    1 Post(s)
    195 Post(s)
    Rockford Fosgate® - RFTECH Support
    the box wizzard on that sight is fairly ok also fyi
    brians ghetto burb of amazing and cheap and loud build log
    http://www.caraudio.com/forums/car-audio-build-logs-cars-trucks-suvs/604559-get-loud-cheap-ghetto-blaster-burb.html
  1. WANTED:: 2 Ohm stable Mono Amplifier 300-500 watts RMS
    By PureKaoz in forum Wanting to Buy (WTB) - Car Audio
    Last Post: 08-17-2012, 08:50 PM
  2. WTB: 1200-1600 watts at 2 or .5 ohms.
    By HypnoticCure in forum Wanting to Buy (WTB) - Car Audio
    Last Post: 07-21-2009, 04:58 PM
  3. wtb 1600 watts at 1or 4 ohms
    By Dozy_production in forum Wanting to Buy (WTB) - Car Audio
    Last Post: 03-09-2006, 05:21 PM
  4. Replies: 13
    Last Post: 12-14-2005, 03:05 PM
  5. Amp Is Soposibly 2 Ohm Stable. But It Cuts Out! ? Wtf?
    By warren84 in forum Wiring, Electrical and Installation Help
    Last Post: 12-22-2003, 02:37 PM
