Results 1 to 3 of 3
Reload Thread: how to bench test for watts
    enraged's Avatar
    enraged is offline Member
    May 2004
    tx
    39
    i think i got it right but can someone tell me how to figure true wattage,,,dont ya use test tones, and check with voltmeter on ac and probe the outputs on the amp while playing tones and square the number and then divide by ohms of subs?,,,,example 55 ac volts equals ?
    helotaxi's Avatar
    helotaxi is offline Kilroy was Here
    Dec 2003
    South Central (New Mexico that is...)
    37
    8,945
    Re: how to bench test for watts
    You need to use a large bank of resistors that are wired to the load that you want to test at. You might want to have a way of cooling them as they are going to get really hot. You want to use resistors because there is no variance in the resistance based of frequency, there is no impedance phase shift and there is no risk of destroying your sub.
    You will need a multimeter that measures RMS VAC and a 0 dB test tone. Play the tone at max with the gain properly set and measure the voltage across the resistor bank. Square the voltage and divide by the resistance.
    Artificial Intelligence is no match for Natural Stupidity.
    Never underestimate the power of stupid people in large numbers.
    Life's tough...it's even tougher when you're stupid.
    maylar's Avatar
    maylar is offline Electrical Weenie
    Jan 2002
    Connecticut
    61
    3,239
    8 Post(s)
    You should also have an oscilloscope to verify that the amp isn't going into major distortion while doing the test.
    dave
    1999 Buick Park Ave Ultra
    Head Unit: JVC KWHDR720
    EQ: Audiocontrol EQL
    Front Stage: Hybrid Audio Technologies Imagine 5.25
    Sub Stage: In process (will be Boston G310)
    Amp: Boston Acoustics GTA-704 4 Ch
    Rear Fill: Boston SE953 6X9's
  1. The Kicker comparison Test
    By InhumanAcura in forum Amplifiers
    Last Post: 05-14-2004, 07:14 PM
  2. Amp test results
    By helotaxi in forum Amplifiers
    Last Post: 02-22-2004, 07:10 PM
  3. Bass test cd, frequency test cd
    By bobo244 in forum General Discussion
    Last Post: 02-01-2004, 03:47 PM
  4. Bass test cd, frequency test cd
    Last Post: 01-31-2004, 05:26 PM
  5. bx1500d bench test
    By limitkid7 in forum Amplifiers
    Last Post: 07-31-2003, 04:08 AM
