Results 1 to 2 of 2
Reload Thread: 2 amps on one battery?
    beartoe's Avatar
    beartoe is offline Junior Member
    Apr 2014
    Baton Rouge,LA
    21
    5 Post(s)
    I have a 2010 ford focus with a 900 watt amp punching two comp 12s and I have an extra amp that is 760 watts. Would it be safe to add the extra amp to the battery with the 900 watt amp or would I need another battery or dist block. Any help, tips, or info for the future would be greatly appreciated
    Roland's Avatar
    Roland is offline Senior VIP Member
    Dec 2012
    Atlanta
    491
    10 Post(s)
    232 Post(s)
    Re: 2 amps on one battery?
    You should be fine.
    Most people don't pull anywhere near rated power. I have three 1000 watt amps on one battery, combined they never pull more than 80 amps when playing music.
    Your concern should really be your alternators output rating not the number of battery's.
    2001 Odyssey - 80PRS -MS8 - NVX JAD amps - Satori 6.5", Satori tweeters, Pioneer TS-W1200Pro
    2008 Odyssey - 4100NEX - Helix P-SIX - ND16FA-6 - GB25 - Titan 8, JAD 1000.1 - TS-W1200Pro Still in progress
  1. question about 2 amps on one sub?
    By tuckintaco93 in forum General Discussion
    Last Post: 06-04-2011, 01:21 AM
  2. setting gains with two amps on one sub
    By jusBloud in forum General Discussion
    Last Post: 03-22-2009, 07:02 PM
  3. Q. about 2 amps on one sub
    By dan_k727 in forum General Discussion
    Last Post: 01-31-2007, 07:40 PM
  4. Can I run three amps with one battery
    By supraman1379 in forum Amplifiers
    Last Post: 07-10-2005, 12:40 PM
  5. can you put two amps on one set of compnents?
    By cjj2d in forum Amplifiers
    Last Post: 02-20-2004, 12:47 PM
Tags for this Thread
