Page 3 of 3 FirstFirst 1 2 3
Results 31 to 33 of 33
Reload Thread: Truck stutters
  1. #31
    garychurch84's Avatar
    garychurch84 is offline Senior VIP Member
    Dec 2012
    hornbeak,tn
    287
    65 Post(s)
    Re: Truck stutters
    Quote Originally Posted by Dub7sonoma View Post
    Its the drag created from your alternator. You don't feel it surge when the clutch is pushed in or when your in neutral right? I have a 5 speed in my Sonoma (4.3L v6) with dual alternators. When the amps are drawing a ton of power it puts more strain on your electrical and makes the alts work harder. If im just idling about 5mph in 1st gear and turn my system up a ton.... It almost stops the truck. But its definitely the alternator
    I agree with this.
    I have a 98 GTP just installed a 250a singer it started this but only at full tilt,never stalled the car but does choke it down
  2. #32
    voltagexdt's Avatar
    voltagexdt is offline Member
    Nov 2012
    South Georgia
    52
    21 Post(s)
    Re: Truck stutters
    Quote Originally Posted by garychurch84 View Post
    I agree with this.
    I'm wondering if u don't have the same issue I had. Something I did will using the help I was given was measure the resistance on te grounds. My oem ground strap was .025. I checked various places on the engine and it matched. After adding the 0ga grounds my engine and components sit at .03. Heck my meter from lead to lead is .02. So that might help u.
    J & M Car Audio and Security
    http://www.jmcaraudio.net/
  3. #33
    Dec 2012
    hornbeak,tn
    287
    65 Post(s)
    Re: Truck stutters
    Quote Originally Posted by voltagexdt View Post
    Its just the alternator picking up to supply the current draw.
    Just like when giving someone a boost when you hook the jumper cables up you get a slight drop in rpms and can hear the alternator pickup some
  1. Truck Stutters when Bass Hits
    By voltagexdt in forum Wiring, Electrical and Installation Help
    Last Post: 11-25-2012, 07:25 PM
  2. what to put in my truck
    By Unregistered in forum General Discussion
    Last Post: 02-10-2002, 09:36 AM
  3. components for my truck
    By harbon in forum General Discussion
    Last Post: 01-25-2002, 04:30 PM
  4. hookin up a cd player to my truck
    By patrick in forum Wiring, Electrical and Installation Help
    Last Post: 12-29-2001, 02:53 AM
  5. Infinitys in a truck???
    By snobrdrdan in forum Subwoofers
    Last Post: 12-14-2001, 12:32 PM
Tags for this Thread
