Results 1 to 5 of 5
Reload Thread: 2007 Prius Very Loud Static Noise from speakers
    FATech67's Avatar
    FATech67 is offline Junior Member
    Mar 2014
    Wiesbaden, Germany
    2007 Prius is experiencing an intermittent very loud static noise coming from all speakers. It is so loud that it sounded like a train crash three feet away. The loud static will continue even after the radio is turned off. The static seems to occur after driving 1-3 hours. The car is a single owner and has never been in an accident. There is 67,000 miles on the car. There have not been any aftermarket additions. Once the static starts, the only way to stop it is to pull the radio fuse from under the hood.
    The Prius has the JBL system with the Amp under the RF seat. I attempted to go to the Toyota dealer (Wiesbaden, Germany) and they could not duplicate the problem and suggested they keep the car and send off the head unit and it would take 4-6 weeks (I can't give up my wife's car for that long). I also attempted to have an aftermarket audio installer to check for shorts (he wouldn't touch a factory installed system to troubleshoot???) I miss being back in the States.
    Can you offer a suggestion on cause and correction of intermittent loud static noise coming from all speakers.
    CrossoverOre's Avatar
    CrossoverOre is offline CarAudio.com Elite
    May 2012
    oregon
    1,038
    205 Post(s)
    Re: 2007 Prius Very Loud Static Noise from speakers
    turn on system let play for 1-3 hours and smack the fatory amp. doesnt have to be that hard but I'm thinking its the amp. also kinda wiggle the plugs a little at the amp itself but i do think its an internal amp issue.
    FATech67's Avatar
    Mar 2014
    Wiesbaden, Germany
    The loud static seems to occur faster during the hot weather vs the 1-3 hour drive (???). I have no idea why this is a factor.
    May 2012
    oregon
    1,038
    205 Post(s)
    Heat is the factor. components inside the amp are failing when they get too hot.
    FATech67's Avatar
    Mar 2014
    Wiesbaden, Germany
    Is there a way to check the Amp for an intermittent short or just replace it. This is tough to diagnose without a great deal of time invested to heat up the car (1-3 Hours) and duplicate the symptoms.
  1. Static noise from speakers and front speakers popping/clipping after the amp install?
    By Falloutkid90 in forum Wiring, Electrical and Installation Help
    Last Post: 03-23-2013, 07:49 PM
  2. Static noise from speakers when turning off accesories
    By mkelias11 in forum Wiring, Electrical and Installation Help
    Last Post: 02-02-2009, 06:34 PM
  3. help idk what wrong static noise from speakers.... why?
    By jbsilentkill in forum Head Units
    Last Post: 01-27-2009, 09:14 PM
  4. very loud noise from speakers all of a sudden
    By orangecounty1 in forum General Discussion
    Last Post: 10-07-2008, 01:36 PM
  5. static noise from speakers?
    By saintluey in forum Home Audio/Video
    Last Post: 08-17-2005, 06:29 PM
Tags for this Thread
