Page 1 of 2 1 2 LastLast
Results 1 to 15 of 28
Reload Thread: Capacitor Problem?
    DJDroc22's Avatar
    DJDroc22 is offline Junior Member
    Dec 2013
    United States
    14
    3 Post(s)
    Capacitor Problem?
    Hey everyone! Okay jumping right into it. I bought a Power Acoustik 5 Farad capacitor and watched plenty of videos and diagrams so I knew I was hooking it up right. First of all i took out my fuse under the hood so theres no power.I installed the capacitor with in 18" inches of amp. Connected my ground cable to my amp mount bolt which I have cleaned of any paint. I ran my power wire from my amp to the capacitor and then from there back to the amp. Everything should be golden. So I grab the resistor my cap came with and drop it into the fuse holder and I feel it get hot but I get no power to my cap or amp. By the way this is now my 2nd cap. I sent the first one back cuz I figured it was defective. Also I noticed when i was bolting in my positive wire to my cap it sparked a little bit when I first touched it. Buuut I didn't have the fuse in at all so there should be zero power..? Could there be something wrong there? Swing away at this cuz I'm gonna feel stupid sending back another cap for a 3rd try. Thank you guys!!
    CrossoverOre's Avatar
    CrossoverOre is offline CarAudio.com Elite
    May 2012
    oregon
    1,041
    205 Post(s)
    Re: Capacitor Problem?
    the spark was probably the caps inside the amp discharging because of the cap. I would rewire the cap so the main power from the battery goes to the cap and then to the amp. I would double check all connections between the amp and cap just to make sure that everything is connected to the proper terminals i.e. pos to pos neg to neg. Next disconnect the amp from the equation and try to charge the cap again. If you have a dmm this will help a lot because you will be able to see when you reach a sufficient charge to remove the resistor and install the fuse. If you can successfully charge the cap without the amp connected then you may have an issue with your amp of the installation. Also how exactly are you determining that you have no power at the amp or cap?
    NASTY08IMPALA's Avatar
    NASTY08IMPALA is offline CarAudio.com Veteran
    Aug 2012
    LOUISVILLE, KENTUCKY
    6,131
    3 Post(s)
    2554 Post(s)
    The problem is u have a capacitor..they are junk and are in no way beneficial to a daily system as they only hold a millisecond of juice...sell it to a sucker and wire the system straight up or buy a small battery if need be ..what does ur system consist of?
    DoesDad's Avatar
    DoesDad is offline CarAudio.com Veteran
    Dec 2011
    Tulsa, OK
    2,342
    675 Post(s)
    ^^^Beat me to it. LOL!
    Just ditch the cap altogether. Plenty of threads on here regarding their usefulness. I myself think their worthless. Anyway, if you're having that bad of voltage drops just get an extra battery and run that (an upgrade to the one under the hood can do the trick as well).
  5. Likes Jeffdachef liked this post
    Dislikes Audio4ever disliked this post
  6. #5
    Jepalan's Avatar
    Jepalan is offline CarAudio.com Elite
    Jun 2013
    Midwest
    603
    1 Post(s)
    158 Post(s)
    "So I grab the resistor my cap came with and drop it into the fuse holder and I feel it get hot but I get no power to my cap or amp"
    This may be a stupid question, but after charging the capacitor did you put your normal in-line fuse back in? The resistor is just for charging the cap before connecting thing up so it doesn't spark, or for discharging the cap when disconnecting. You don't power your system through the resistor.
  7. #6
    Slobalt's Avatar
    Slobalt is offline CarAudio.com Elite
    Aug 2013
    East Coast
    758
    263 Post(s)
    You should disconnect the negative off of your battery before doing anything with the electronics in your car. Taking the fuse (what fuse btw) out is not enough.
    Alpine CDE-HD149BT
    RF T1675-s Comps
    RF PPS4-8 PRO
    PPI Bk800.4
    SSA ZCON 12
    ZX2500.1
  8. #7
    DoesDad's Avatar
    Dec 2011
    Tulsa, OK
    2,342
    675 Post(s)
    Quote Originally Posted by Jepalan View Post
    That might be why this is his 3rd one?
  9. #8
    DJDroc22's Avatar
    Dec 2013
    United States
    14
    3 Post(s)
    My main power cable from my battery is the cable going straight to my pos on cap an then from there to my amp. I'll double check my connections but i had no issues with wiring before the cap. And yes I have a multimeter and ive been checking from the battery to the amp and I'm getting my 12 volt reading all the way through. And when the cap is wired in I know I'm not getting power cuz my cap has lights and a volt meter on it and nothing lights up at all.
  10. #9
    DJDroc22's Avatar
    Dec 2013
    United States
    14
    3 Post(s)
    By Fuse I mean the fuse on my main power to my amp. And yes I do know the resistor isnt a FUSE. I only left the resistor in for 30 or so seconds before I realized something was wrong.
  11. #10
    DJDroc22's Avatar
    Dec 2013
    United States
    14
    3 Post(s)
    What if my ground for my cap isnt good enough? Would that be a cause? Or possibly hurt the cap?
  12. #11
    Audio4ever's Avatar
    Audio4ever is offline Box Chevy Boi
    Oct 2009
    Maryland
    2,075
    1 Post(s)
    233 Post(s)
    Are u grounding the cap too?
    Hu:
    Front Stage:
    Sub Stage:
    Box:
    Electrical:
    Amps:
  13. #12
    DJDroc22's Avatar
    Dec 2013
    United States
    14
    3 Post(s)
    Quote Originally Posted by Audio4ever View Post
    Yes the cap has its own ground cable
  14. #13
    Aug 2012
    6,131
    3 Post(s)
    2554 Post(s)
    Quote Originally Posted by DJDroc22 View Post
    Did u not read any of the advice? The cap itself isnt good ..they r junk..ditch it and wire it straght up ..and if ur runnig enough power to think u need reserve ..upgrade the battery under the hood and/or add a 2nd batter
  15. Thanks Jeffdachef thanked for this post
  16. #14
    globalminds_ent's Avatar
    globalminds_ent is offline CarAudio.com Elite
    Dec 2011
    oxford ms
    1,214
    414 Post(s)
    Get rid of the cap one kinetik hc600 is better than 20 of those caps literally
  17. #15
    Jeffdachef's Avatar
    Jeffdachef is online now Gunz That Turn on Nunz
    Feb 2013
    South Coast Metro, CA
    15,792
    233 Post(s)
    7683 Post(s)
    get rid of the power accoustik cap and get a boss or pyle 20-30 farad cap, it'll make wonderful power to give your amps every ounce of juice it needs!!! fill your car up with capacitors! one run between the alternator and battery, one between each grounds, one between your amp and battery and one between your amp and subwoofer!
    09 Sienna Subs : Four Team Ascendant 18s......Sub amp: Two Taramps 15k
    Headunit: Pioneer 80PRS................................Mids/Highs amp: CT 500.2, ppi 600.2, ppi 900.4 bridged
    Front stage: Two PWX 10s per door midbass only....... PRV 6MR500 midrange....... Massive CT 2 german tweeters.
    320 amp Singer alt....... 1 group 34 under the hood 6 group31 agms in the back 560 amp hours total.
  18. Likes Da64u, garychurch84, DoesDad liked this post
  1. capacitor problem...... need help..
    By jeppe0204 in forum General Discussion
    Last Post: 03-06-2010, 11:57 PM
  2. capacitor problem
    By xR2KxIam187ingU in forum Wiring, Electrical and Installation Help
    Last Post: 01-19-2009, 07:09 PM
  3. visonik amp and capacitor problem
    By FLEX4U18 in forum General Discussion
    Last Post: 07-17-2004, 06:39 PM
  4. capacitor problem
    By ry4n in forum General Discussion
    Last Post: 01-04-2004, 10:31 PM
  5. Capacitor Problem
    By mark4h2001 in forum Wiring, Electrical and Installation Help
    Last Post: 12-01-2002, 06:03 PM
Tags for this Thread
