Page 2 of 2 FirstFirst 1 2
Results 16 to 28 of 28
Reload Thread: Capacitor Problem?
  1. #16
    NIHL8ION's Avatar
    NIHL8ION is offline RUN ur car NOT ur mouth !
    Mar 2013
    IlliNOISE
    1,355
    22
    377 Post(s)
    Re: Capacitor Problem?
    This cap is pretty much useless as most ppl above have already stated, but YES: to answer your question - The Cap's Ground should be a GOOD GROUND - NOT just ran over to one of your amp case / mounting screw / bolts ! EVERY ground in ANY vehicle SHOULD be treated the SAME WAY - Use the SAME GAUGE wire as you do for the positive side of whatever you are grounding, and ground to a good SOLID, UN-PAINTED, METAL SURFACE... I always ground directly to the frame, or if uni-body: Run a dedicated ground from the battery along with your power wire when you run it. Honestly though: If you have yet to do the BIG 3 upgrade under the hood of your vehicle yet: DO IT - That alone will do more for you than that cap EVER will GL, hope you get it sorted out
    - Cadence DCA2500.1 Running a Tantric HDD - 12" D2
    *Bought From: cx-7heaven, nutnbutcustm, naughtyca, agarabaghi, Skip01*Traded With: infamous_e46, basswiigee**Sold To: DeanG, R.S.D., livinloud!*
    Feedback Link: http://www.caraudio.com/forums/itrader.php?u=1028333
  2. #17
    Jepalan's Avatar
    Jepalan is offline CarAudio.com Elite
    Jun 2013
    Midwest
    603
    1 Post(s)
    158 Post(s)
    You guys are brutal
  3. #18
    argenis69's Avatar
    argenis69 is offline SQ Bass Lover
    Dec 2012
    NY, USA
    836
    245 Post(s)
    Quote Originally Posted by jeffdachef View Post
    get rid of the power accoustik cap and get a boss or pyle 20-30 farad cap, it'll make wonderful power to give your amps every ounce of juice it needs!!! fill your car up with capacitors! one run between the alternator and battery, one between each grounds, one between your amp and battery and one between your amp and subwoofer!
    Front stage Image Dynamics 6.5 CX62 V2. Rear stage O2 Audio 5 1/4in.
    Cadence Tweeters. KnuKonceptz Rcas and Wiring.
    Kicker Impulse x3i 3-way Active Electronic Crossover(disconnected for now).
    JL Audio 300/4 . JL Audio XD700/5 . Crescendo BC3500D.
    15" Fi Audio SP4 fully loaded in 3.5cu ft flared ported box.
    One complete +/- run of Knu Ofc 0 gauge with big 3, volt meter inside, biggest acid battery under hood, Battery Isolator. A XS Power D3100 and a Crescendo Logic F-31HP battery in trunk.
  4. #19
    CrossoverOre's Avatar
    CrossoverOre is offline CarAudio.com Elite
    May 2012
    oregon
    1,041
    205 Post(s)
    man everyone seems to just have a hard on for how much they think caps ****. If you think that so much open up your amp and remove the caps and see how much they actually WORK cuz your amp wont without them.
  5. Likes Da64u liked this post
    Dislikes akheathen disliked this post
  6. #20
    Mass Car Audio's Avatar
    Mass Car Audio is offline CarAudio.com Elite
    Nov 2008
    Canada
    1,219
    190 Post(s)
    Take the capacitor and throw it away, then go buy a small agm battery and put it where the cap was. Problem solved !!!
    Bought from: tc3k101, traksta15, loudwhat?, MitchZ, Igotwire, dgaf, kalkx, mylows10, akadj, SPLaudio
  7. #21
    Nov 2008
    Canada
    1,219
    190 Post(s)
    Quote Originally Posted by CrossoverOre View Post
    Are you serious ?? LOL
    You have no idea what your talking about.
  8. #22
    May 2012
    oregon
    1,041
    205 Post(s)
    Quote Originally Posted by Mass Car Audio View Post
    The caps inside the amp supply the power that the amp outputs. cap added to the power cable outside of the amplifier behaves just the like caps inside the amp.
  9. #23
    argenis69's Avatar
    Dec 2012
    NY, USA
    836
    245 Post(s)
    As lots of people keep repeating, Capacitors like those are more harm than good. Get yourself a good agm battery instead.
  10. #24
    bumpasauras's Avatar
    bumpasauras is offline Always Hurtin Ears!!
    Feb 2009
    West. TEXAS
    436
    97 Post(s)
    Ditch the cap and buy a decent battery the only thing a cap is used for is filtering out alt noise. Other than that they are completely useless. I might have misread but you should have your power wire from your battery going to the cap and then from your cap to your amp with as short of a wire as possible . also put your ground away from the mounting location of the amp but keep this wire as short as possible as well, you cannot over do your amps ground the more contact with metal the better. Also you may need to put a better ground on your batt as well
  11. #25
    TheUnderFighter's Avatar
    TheUnderFighter is offline Beer Addict
    Mar 2011
    Murrieta, California, (SoCal)
    27
    3,488
    862 Post(s)
    The only thing wrong with the cap, is that you haven't sold it yet. It has no use in your system.
    2009 Hyundai Elantra - Budget Sound in Progress
    HU- Kenwood eXcelon KDC-X994
    Fronts- Crescendo MP6 mids, Vifa Ring Radiator tweets on Arc KS300.4
    Subs- Single SA-10 on Mmats 2000.1 @ 1ohm
    Misc- 1/0 CCA from AT, Big 3 in Stinger HPM, and AT 60 mil deadener
    Bought from: Inferno333, select127, treesive, Kangaroux, DonH
    Sold to: coolest user, Psychodrama, MidgetClown, mr.tigger, av83
  12. #26
    garychurch84's Avatar
    garychurch84 is offline Senior VIP Member
    Dec 2012
    hornbeak,tn
    287
    65 Post(s)
    Extra battery nuff said!
    What few caps I have hooked up I never used the resistor,I always used a small 12vdc light bulb to charge the cap
  13. #27
    akheathen's Avatar
    akheathen is offline trianoacitol contraceptiv akheathen is a Supporting Member of the forum!
    Jan 2011
    Anchorage AK
    36
    2,355
    1 Post(s)
    250 Post(s)
    tldr........ assuming you have the conventional round cap, there will be a small screw behind the main terminals that appears to just hold the plastic cap on...... it's actually the remote wire to turn the cap on, just like your amp remote. any cap with a display, or over a few farads will typically be remote activated for a good reason. caps, are not a bad thing, unless you are using it/them to stop voltage drops, then, yah, they are pointless, and only mask the voltage drop, which still happens. i use them on the bench power supply to filter the ac ripple..... your battery normally does this in your car, but not completely....that is what a cap is good for.
    and, fyi: your amp will work without the main caps, or even rail caps. i do it all the time.
    *IF I have forgotten to exchange feedback, please let me know*
    i buy broken amps....
    No, i will not "gift" paypal. please do not even make it awkward by asking. if the fees are an issue, I am usually inclined to add them. unless you have discount elsewhere, shipping is through usps flat rate, through usps parcel post, or through the roof..... i am in alaska. thanks
    -Heath H-
  14. Likes garychurch84 liked this post
  15. #28
    Nov 2008
    Canada
    1,219
    190 Post(s)
    Nice try..LOL, you still have no idea what your talking about.
  1. capacitor problem...... need help..
    By jeppe0204 in forum General Discussion
    Last Post: 03-06-2010, 11:57 PM
  2. capacitor problem
    By xR2KxIam187ingU in forum Wiring, Electrical and Installation Help
    Last Post: 01-19-2009, 07:09 PM
  3. visonik amp and capacitor problem
    By FLEX4U18 in forum General Discussion
    Last Post: 07-17-2004, 06:39 PM
  4. capacitor problem
    By ry4n in forum General Discussion
    Last Post: 01-04-2004, 10:31 PM
  5. Capacitor Problem
    By mark4h2001 in forum Wiring, Electrical and Installation Help
    Last Post: 12-01-2002, 06:03 PM
Tags for this Thread
