Results 1 to 3 of 3
Reload Thread: need help buying new amp plz
    adamo1288's Avatar
    adamo1288 is offline Junior Member
    Mar 2014
    quebec
    1 Post(s)
    hello guys ..i need help choosing wich amp i should buy ...i wanted to buy an MTX THUNDER1000.1 its 1000 watts RMS 1ohm stable ..my subs are 2x 10'' MTX 500watts RMS each but 4ohm svc so my question is ... is this MTX amp good or not cuz of the 1ohm ? :S and if u go look at the spec of amp it say 1ohm stable but 600rms 2ohm and 400 4 ohm something like that ..so y it say 1ohm stable ?
    thx
    Jeffdachef's Avatar
    Jeffdachef is online now Gunz That Turn on Nunz
    Feb 2013
    South Coast Metro, CA
    15,804
    233 Post(s)
    7687 Post(s)
    Re: need help buying new amp plz
    Quote Originally Posted by adamo1288 View Post
    thx
    It means you can wire it down to 1 ohm with Dual Voice Coil subwoofers and it can handle that low of an impedance just fine compared to other amps that will shutoff and go into protect mode at anything lower then 2 ohms. With those subs however, you might want an amp that does 1k at 2 ohms instead. Look for some used kicker or alpine 1k amps since those typically favor 2 ohm operation. If your on a budget though, grab a precison power black ice 1800.1D
    09 Sienna Subs : Four Team Ascendant 18s......Sub amp: Two Taramps 15k
    Headunit: Pioneer 80PRS................................Mids/Highs amp: CT 500.2, ppi 600.2, ppi 900.4 bridged
    Front stage: Two PWX 10s per door midbass only....... PRV 6MR500 midrange....... Massive CT 2 german tweeters.
    320 amp Singer alt....... 1 group 34 under the hood 6 group31 agms in the back 560 amp hours total.
    Pyromaniac4food's Avatar
    Pyromaniac4food is offline Senior VIP Member
    Jul 2013
    Socal
    278
    1 Post(s)
    82 Post(s)
    I have an Old School American made MTX thunder 1000d that is rated 1000w @2 ohm (12v) if you're are interested in keeping the same brand.
    RD 3250 V1, Old School MTX, Older PPI, 18" atomic apx
  1. help buying new amp
    By gimpster80 in forum Amplifiers
    Last Post: 03-26-2006, 12:06 AM
  2. Need help with new amp
    By TheBlackSheep in forum Amplifiers
    Last Post: 10-08-2005, 01:49 PM
  3. Replies: 0
    Last Post: 10-19-2004, 01:58 AM
  4. Need help with new amp plz!
    By ayoung in forum Amplifiers
    Last Post: 07-24-2004, 04:05 PM
  5. Need Help Buying 2 AMPS
    By 2kPhatMax in forum Amplifiers
    Last Post: 12-14-2003, 01:51 PM
