Results 1 to 8 of 8
Reload Thread: amp mounting in Chevy 2500 std cab
    cdr's Avatar
    cdr
    cdr is offline Member
    Dec 2003
    AZ
    31
    136
    Hey I need to get around to mounting my 4 channel cadence in my truck, I have a 99 Chevy 2500 Standard cab so room is fairly limited. I was thinking of epoxying some thin strips of wood to the back of the cab with some bolts through them and metal strapping, then mounting a piece of plywood to that and then the amp to that. Has anyone ever done this before or are there any other ideas?
    thanks
    Acidburn's Avatar
    Acidburn is offline Super Mod-like-guy
    Dec 2003
    Tempe, AZ
    31
    15,596
    22
    Re: amp mounting in Chevy 2500 std cab
    it is about **** time you get your amp mounted :p
    that may work, or you could mount it to the floor, looked like there was room back there to me, or maybe build an angled piece that it can be mounted to
    MdOiDcEtRaAtToOrR
    1996 Chevrolet Impala SS 14.5 @ 94
    1967 Chevrolet Camaro 18.4 @ 74
    cdr's Avatar
    cdr
    Dec 2003
    AZ
    31
    136
    here is what I am working with, definately needs fixing as that is a patheticly horrible finish to an install heh, just havent had the time and have been tossing it over in my head a bit:
    mulisharider10's Avatar
    mulisharider10 is offline Low Co. Motives
    May 2003
    San Diego, Ca
    32
    278
    i say hide it under the seat. there should be plenty of room under there bc i know there is more than enough in a standard cab toyota tacoma for a decent sized amp.
    BIG_SUPERMAN72's Avatar
    BIG_SUPERMAN72 is offline mother humper
    Jan 2004
    Grand Rapids, Michigan, United States
    30
    2,078
    oh yea under the seat would be really good. N hide wires under carpet. IT may take some time. But ull be more than pleased by the finish.
    99 Chevy Silverado 1500 ext cab
    22" Giovanni rims
    200 amp alt.
    Optima Yellow top in the cab
    Duralast under the hood
    3 other batts.
    Eclipse 3100
    Eclipse Comps. crossfire cfa202
    eclipse 6.75s rear + eclipse 4x6s alpine T-130
    (2) FI 15" BTLs 10cu/ft tuned to 32 hertzzzzzzz
    Massive D400x 5k @ 2 ohm
    Sorry if I make ur girlfriend wet, in advance.
    cdr's Avatar
    cdr
    Dec 2003
    AZ
    31
    136
    I would rather not put it under the seat for two reasons:
    1) I live in Phoenix AZ right now it is 103*F out and it will be getting up to 115*F this summer and I will be driving every day in that heat come the lunch hour.
    2) I would like access to the amp easily both for future work and short term work as I am going to have a chance to test a couple subs bridged on the 3rd and 4th channels, and I just want general access for the future
    anyways thanks for the idea, just dont think under the seat is for me
    Lowridin_Chevy's Avatar
    Lowridin_Chevy is offline ridin on 16's......bling!
    Apr 2004
    Alabama
    192
    here's an idea/\.....make a triangle shaped box and mount the box to the floor and the amp to the box...have it in the middle where u have it know with not as big a slant though then drill holes into the side of the box and run all the wires into the box and runn the wires out the back and then behind the carpet on the back wall.....wallllah wires gone
    Jan 2004
    30
    2,078
    Ive seen a box made like a V. Its tight the subs both inside the V. But it has to be a big *** box. It also had a plexiglass window. But they kid was a ******* n screwed it up. Aslong as the guy mounts his amp outside the box and not inside good idea. Just incase he reads that wrong. Amps Overheat in boxes =)~~.
    22" Giovanni rims
    200 amp alt.
    3 other batts.
    Eclipse 3100
  1. chevy 2500 std cab amp mounting
    By cdr in forum Wiring, Electrical and Installation Help
    Last Post: 08-10-2004, 11:40 PM
  2. Amp Mounting Location
    By 68 R/T in forum Wiring, Electrical and Installation Help
    Last Post: 03-25-2004, 06:54 PM
  3. Mounting an AMP upside down?
    By H1PH0P in forum Amplifiers
    Last Post: 02-28-2004, 09:55 PM
  4. mounting amp
    By the_flatlander in forum Wiring, Electrical and Installation Help
    Last Post: 01-03-2004, 01:47 AM
  5. Need help with 2000 Chevy ext. cab
    By HarleyF150 in forum Subwoofers
    Last Post: 11-20-2003, 05:14 PM
