Results 1 to 5 of 5
Reload Thread: How many OHM's is this?
    Da64u's Avatar
    Da64u is offline Senior VIP Member
    May 2007
    Fort Lauderdale, FL
    413
    71 Post(s)
    I want to wire 4 mid's (two 6.5's and two 6x9's)
    The amp is 2 channel. 2 Ohm stable
    I want to wire all the speakers to the amp.
    If I put 2 on each channel what will the total ohm load be?
    Or should I put them all together bridged?
    I'm bad with math =\
    This should be good, right?
    Head Unit: Pioneer DEH-X8600BH
    Front's: Alpine Type-R 6 1/2's
    Rear's: Alpine Type-R 6x9's
    Mid Range: Dayton RS75-4's
    Tweeters: Vifa XT25SC90-04's
    Subs: 2 Obsidian Audio 12v3's
    Sub Amp: Hifonics BRX2400.1D
    Mid Amp: Alpine F-4
    Tweeter / Mid Range Amp: JL 300/4
    Powerplant: Die Hard Platinum
    Buck's Avatar
    Buck is online now always low Buck is a Supporting Member of the forum!
    May 2008
    Nashville
    18,670
    29 Post(s)
    1129 Post(s)
    Re: How many OHM's is this?
    If your speakers are all dual 4, connecting two of them in parallel will result in a 2 ohm load at the amp.
    Alpine - ASE (local) - Batcap - CT Sounds - eD - Excessive Amperage - Powerware - Rainbow
    Da64u's Avatar
    May 2007
    Fort Lauderdale, FL
    413
    71 Post(s)
    Quote Originally Posted by Buck View Post
    They are all 4OHM SVC
    Mid Amp: Alpine F-4
    Buck's Avatar
    May 2008
    Nashville
    18,670
    29 Post(s)
    1129 Post(s)
    Just like you showed in that pic is how it will be.
    pickup1's Avatar
    pickup1 is offline CarAudio.com Veteran
    Aug 2005
    Roanoke,TX
    53
    8,468
    19
    7 Post(s)
    839 Post(s)
    2 ohm load per channel.
  1. How many ohms is this circuit?
    By timma100 in forum Wiring, Electrical and Installation Help
    Last Post: 11-02-2011, 03:57 PM
  2. How many Cu.Ft is this..
    By GetLikeMe in forum Enclosure Design & Construction Help
    Last Post: 02-21-2010, 04:40 PM
  3. how many cubic feet is this
    By 87linkin in forum General Discussion
    Last Post: 11-06-2008, 03:19 PM
  4. Can anyone tell what this box is tuned to and how many cubes it is
    By ChuteBoxe515 in forum Enclosure Design & Construction Help
    Last Post: 11-10-2004, 11:06 AM
  5. Umm How many feet cubed is this box?
    By flakko in forum Enclosure Design & Construction Help
    Last Post: 09-26-2004, 01:08 AM
