Page 2 of 2 FirstFirst 1 2
Results 16 to 23 of 23
Reload Thread: Would like to know I'm on the right track
  1. #16
    fatalphenom's Avatar
    fatalphenom is offline Member
    Feb 2014
    MI
    37
    11 Post(s)
    Re: Would like to know I'm on the right track
    I'm 27 now and that setup was when I was 20 lol. And CrossoverOre, it was a mic and a box they used. Anyway back to original question; I've been doing a lot of research and decided that with the 3200w Zeus only doing 2000w rms, I'm going to start with Big 3 and AGM batteries then go from there.
  2. #17
    CrossoverOre's Avatar
    CrossoverOre is offline CarAudio.com Elite
    May 2012
    oregon
    1,041
    205 Post(s)
    I would do big 3 H.O. alt and agm under the hood. Shouldnt need a second batt unless you are thinking about doing bass race or something that would require more reserves of power.
  3. #18
    Jeffdachef's Avatar
    Jeffdachef is online now Gunz That Turn on Nunz
    Feb 2013
    South Coast Metro, CA
    16,096
    242 Post(s)
    7862 Post(s)
    if you have the money for it, go straight for the high output alt. The batteries is just either a bandage solution or supplemental backup power. Batteries only store and release power, they can't make power.
    09 Sienna Subs : Four Team Ascendant 18s......Sub amp: Two Taramps 15k
    Headunit: Pioneer 80PRS................................Mids/Highs amp: CT 500.2, ppi 600.2, ppi 900.4 bridged
    Front stage: Two PWX 10s per door midbass only....... PRV 6MR500 midrange....... Massive CT 2 german tweeters.
    320 amp Singer alt....... 1 group 34 under the hood 6 group31 agms in the back 560 amp hours total.
  4. #19
    Feb 2014
    MI
    37
    11 Post(s)
    Quote Originally Posted by jeffdachef View Post
    Okay thank you guys. I was going to start with Big 3, AGM under the hood and Kinetik in the back, but if I will end up needing a HO alt anyway I'll start with that first since its the higher cost. I asked in a different thread about HO alts and one response was that they aren't meant for daily driving. I understand this, although my ride wont be the typical 'daily driver'. That concerned me a little because there was no clear distinction between my ride with a high power stereo versus a complete stock vehicle. I was also reading the sticky about HO alts and seen the pic of the guy's Chrysler 300 and I'd like to avoid that, lol. The one I was looking into is a Powermaster from SummitRacing at 200A. As long as I fuse the alt to battery power I should be fine, correct?
    Edit: Read to the end of the Alternator thread; I found my answers.
  5. #20
    kevyn's Avatar
    kevyn is offline Junior Member
    Feb 2014
    alexandria.La.
    25
    7 Post(s)
    Do not understand why everyone wants a spare battery. Power comes from alt with vehicle running. Buy a good battery under the hood and that's it unless you listen with key off.like competing.
  6. #21
    kevyn's Avatar
    Feb 2014
    alexandria.La.
    25
    7 Post(s)
    With ho alt of course
  7. #22
    Beatin''s Avatar
    Beatin' is offline CarAudio.com Elite
    Nov 2012
    MI
    998
    574 Post(s)
    an extra batt will help with buffering power output that the alt can't provide, but at a lower voltage. It helps greatly with protecting the alt from burning up tring to put out amperage it cannot produce safely. But when certain amount of power you want to draw is reached, you WILL need a HO alt. Extra batts wont cut it anymore.
    All day I'm clippin'
    voltage be dippin'
    I don't give a damn,
    cause my trunk always hittin'!
    creating a proper sound wave. Step one, turn it up until clipping. Step two, done.
  8. #23
    Feb 2014
    MI
    37
    11 Post(s)
    Quote Originally Posted by kevyn View Post
    Quote Originally Posted by Beatin' View Post
    These are the reasons why I asked along with what everyone else had to say. I decided to go with an alt and go from there.
  1. Replies: 5
    Last Post: 08-11-2012, 10:55 PM
  2. i would like to know something
    By juanl in forum Amplifiers
    Last Post: 12-10-2006, 09:18 AM
  3. Replies: 4
    Last Post: 11-02-2006, 09:51 PM
  4. i would like to know something
    By juanl in forum Subwoofers
    Last Post: 09-04-2006, 11:55 AM
  5. Want to know if I'm on the right track.......
    By shadybutclever in forum Speakers
    Last Post: 04-27-2003, 07:31 PM
