Page 1 of 2 1 2 LastLast
Results 1 to 15 of 23
Reload Thread: 2 batteries 13.3v
    PuZo's Avatar
    PuZo is offline Senior VIP Member
    Jan 2008
    Toronto, Canada
    424
    33 Post(s)
    2 batteries 13.3v
    I just moved my old yellowtop the to trunk and put in a new starting battery.
    When the car starts it shows 14v but after a while it drops to 13.3v. Would this mean my yellowtop is drained? I've had it for probably a good 5 years. I had a xs power d675 before but I figured the yellowtop would be better even though it is older.
    This is with no load other than normal car functions.
    vibe's Avatar
    vibe is offline CarAudio.com Elite
    Nov 2013
    Prescott, AZ
    28
    662
    313 Post(s)
    Re: 2 batteries 13.3v
    Mine does too. When your alt heats up it tends to start losing power. Mine starts at 14.4 n when hott charges at 13.9ish. I know thats one reason why your voltage drops.
    mylows10's Avatar
    mylows10 is offline B2,singer,ampere rep
    Sep 2009
    monterey , ca
    54
    22,442
    141 Post(s)
    1 Thread(s)
    6015 Post(s)
    Disconnect the batteries from each other and check all of them individually. Sounds like ones bad
    pioneer avhx 4800 dvd, ampere tfhe 9.0 and 150.4 with arc audio xxd 4080
    4 d3100 and 3 deka 8a31 and d975 ,270 dc power and 320 amp singer alt
    B2 ref mids,Cdt es6 mids cdt es 010 tweets x2 ,es 03 Mids x 2 mx1000 , sky high ,eb flex, and stinger hpm o gauge wires ,also 2 crossfire xsv2 18s in a 4th order no wall box
    NOR CAL DB DRAG JUDGE
    http://www.dcsoundlab.com
  4. Likes michaellane liked this post
  5. #4
    PuZo's Avatar
    Jan 2008
    Toronto, Canada
    424
    33 Post(s)
    Well considering one is new it's probably the yellowtop?
  6. #5
    SounDrive's Avatar
    SounDrive is offline www.soundrive.audio SounDrive is a Supporting Member of the forum!
    SounDrive is a Supporting Vendor of the forum!
    Apr 2013
    Lebanon, TN
    3,072
    20 Post(s)
    1347 Post(s)
    Quote Originally Posted by PuZo View Post
    Test them all. Don't assume.
    Owner, SounDrive Audio
    Visit our store at www.soundrive.audio
    Like us on Facebook at www.facebook.com/soundriveAudio
    PLEASE EMAIL ME FOR FASTER RESPONSES - [email protected]
    Dealer for: SounDrive Audio | Synergy Audio | Audio Legion | XS Power | Mechman | SPL-Lab | Taramps | Limitless Lithium | Wolfram Audio | Singer Alternators | Ampere Vibraflex
  7. #6
    PuZo's Avatar
    Jan 2008
    Toronto, Canada
    424
    33 Post(s)
    Just with a voltmeter? Will it cause damage to the good battery if I wait a week or so to change it?
  8. #7
    PuZo's Avatar
    Jan 2008
    Toronto, Canada
    424
    33 Post(s)
    I don't have a voltmeter but I managed to separate the batteries so the new one is connected to the alternator and the second one in the trunk is only connected to the amp. I have a voltmeter on my splitter and it's showing 12.4v(on the yellowtop). Is that normal for "resting"?
  9. #8
    MrFoca's Avatar
    MrFoca is offline CarAudio.com Veteran
    Nov 2013
    MD
    2,774
    9 Post(s)
    1136 Post(s)
    Bad battery will drag a good battery down man.
  10. #9
    PuZo's Avatar
    Jan 2008
    Toronto, Canada
    424
    33 Post(s)
    This is the battery I have for starting:
    MotoMaster Eliminator Ultra Flat Plate AGM Automotive Battery | Canadian Tire
    What is the best way to test my yellowtop and D975 to see which has more life?
  11. #10
    Side Show's Avatar
    Side Show is offline Bringin The Noise
    Aug 2007
    Australia
    3,337
    457 Post(s)
    test the battery resting voltage, then but a decent draw on it and test it again.... I had one batt that tested fine until it was put under load then it dropped to around 7/8v and started sucking the pwr from my other batt.
  12. #11
    PuZo's Avatar
    Jan 2008
    Toronto, Canada
    424
    33 Post(s)
    So it is deffinetly the new battery. Drove with it with nothing on and it dropped to 13.2/13.3
    What type of battery should I get? Looking to combine it with my yellowtop or xs power d975
  13. #12
    jrdnhsnbrg's Avatar
    jrdnhsnbrg is offline Pimped my grandma's ride
    Aug 2012
    Eau Claire, WI
    22
    1,877
    689 Post(s)
    Your alternator will charge at a higher voltage right after you start the vehicle (especially in the cold) in order to charge up the power that was lost during starting. My car will charge around 14.3V right after starting and die down to 13.4-13.6, it's totally normal. Go get that battery load tested before you do anything else.
    2013 Ford Flex Ecoboost AWD “Turbo Fridge”
    Shok Triton 15”
    3.8 cubic feet tuned to 32
    DC 1.2k
  14. #13
    PuZo's Avatar
    Jan 2008
    Toronto, Canada
    424
    33 Post(s)
    Any links for how to do a load test at home?
    Will it be okay though with a starting only battery in the front with a yellowtop in the back? Before I had 2 deep cycle and now I'll only have 1 so just a bit concerned.
    I'd really like this one for the front.
    Http://www.saskbattery.com/ecommerce_308.htm
  15. #14
    michaellane's Avatar
    michaellane is offline CarAudio.com Veteran
    Oct 2005
    tx
    31
    11,533
    29 Post(s)
    814 Post(s)
    take it to your local auto store they will check it for free man go today
    http://www.caraudio.com/forums/buyer-seller-feedback/414807-michaellane-feedback-if-i-bought-you-traded-i-sold-you-something.html
  16. #15
    jrdnhsnbrg's Avatar
    Aug 2012
    Eau Claire, WI
    22
    1,877
    689 Post(s)
    You need a specialized tool as far as I know. A shop or parts store should be able to do it for free
    Shok Triton 15”
    DC 1.2k
  1. FS: Macbook Pro 13" Mid-2009 Fully Upgraded SSD, HD, Battery - $750 OBO
    By jamesmington in forum Miscellaneous Classifieds
    Last Post: 07-03-2013, 09:15 AM
  2. Battery sits on 13.x but won't start the car
    By Flipx99 in forum Car Performance and Repair
    Last Post: 08-15-2009, 04:16 PM
  3. Replies: 0
    Last Post: 03-17-2009, 12:44 AM
  4. Yellow top optima battery
    By <Black> in forum General Discussion
    Last Post: 01-03-2002, 10:43 PM
