Page 3 of 3 FirstFirst 1 2 3
Results 31 to 39 of 39
Reload Thread: Subs aren't hitting like they should... Please Help
  1. #31
    nismos14's Avatar
    nismos14 is offline CarAudio.com Veteran
    Dec 2006
    Jersey
    37
    14,586
    273 Post(s)
    Re: Subs aren't hitting like they should... Please Help
    And sub at 0
    Car audio IS an addiction.
    C.A.A.A Member #1
    (Car Audio Addicts Anonymous)
    Refs http://www.caraudio.com/forums/buyer-seller-feedback/278560-nismos14-feedback-refs-thread.html
  2. #32
    SplAffair's Avatar
    SplAffair is offline I lol'd
    Mar 2009
    Knocksville, TN
    27
    2,120
    340 Post(s)
    I too thought on my alpine you had to set the sub +15 to get full pre amp voltage. This isn't right?
    big 3 in 2/0 welding wire
    Northstar battery up front.
    1 run of 2/0 to the back.
    Us amps md2d @1 ohm
    2 skar vvx-v2 12s
    (Front stage in the works)
  3. #33
    Chriszle's Avatar
    Chriszle is offline CarAudio.com Elite
    Jan 2011
    SD
    1,718
    373 Post(s)
    You can set the gain on the amp with whatever sub setting you want. It really doesn't make a difference (as long as the signal being sent to the amp is not clipped). You have more range if you set the gain with the subwoofer volume up, as you can attenuate it down as much as you need to. For instance my kenwood clips at 33/35 with
    +13 subwoofer setting. If you bump it to +15 (max) it clips at 29/35. I can choose to set the gain at either point, knowing exactly where I cannot go past either way.
    I should say this is also h/u dependent. If your subwoofer volume control boosts certain frequencies, it is best left at 0.
  4. #34
    heimsothe's Avatar
    heimsothe is offline Member
    Dec 2013
    Portland, OR
    66
    34 Post(s)
    Going to try to fix things up today after classes. Couldn't get around to it yesterday with all the midterms and lack of light in the after noon.
  5. #35
    nismos14's Avatar
    Dec 2006
    Jersey
    37
    14,586
    273 Post(s)
    They make these things called flashlights now....
    C.A.A.A Member #1
  6. Likes heimsothe liked this post
  7. #36
    heimsothe's Avatar
    Dec 2013
    Portland, OR
    66
    34 Post(s)
    Quote Originally Posted by nismos14 View Post
    Chalk it up to a count of laziness then
  8. #37
    nismos14's Avatar
    Dec 2006
    Jersey
    37
    14,586
    273 Post(s)
    Ain't no cure for that.
    C.A.A.A Member #1
  9. #38
    heimsothe's Avatar
    Dec 2013
    Portland, OR
    66
    34 Post(s)
    You mean they don't make a flashlight for that???
  10. #39
    nismos14's Avatar
    Dec 2006
    Jersey
    37
    14,586
    273 Post(s)
    Nope, just an APP.
    C.A.A.A Member #1
  1. Subs aren't hitting PLEASE HELP!!!
    By Justin braaapp in forum Wiring, Electrical and Installation Help
    Last Post: 09-21-2013, 01:16 PM
  2. Replies: 7
    Last Post: 09-21-2013, 07:52 AM
  3. subs aren't hitting as hard as they should
    By snev in forum Wiring, Electrical and Installation Help
    Last Post: 01-20-2012, 10:46 PM
  4. Replies: 17
    Last Post: 06-25-2010, 04:24 PM
  5. alpine type x's not hitting like they should...
    By snowcruizer713 in forum Subwoofers
    Last Post: 01-31-2010, 09:22 AM
Tags for this Thread
