Page 2 of 3 FirstFirst 1 2 3 LastLast
Results 16 to 30 of 39
Reload Thread: Subs aren't hitting like they should... Please Help
  1. #16
    Beatin''s Avatar
    Beatin' is offline CarAudio.com Elite
    Nov 2012
    MI
    998
    574 Post(s)
    Re: Subs aren't hitting like they should... Please Help
    Quote Originally Posted by heimsothe View Post
    Any advice? I'm confused as to what I should do? I don't have an oscope available to me. I know they should be able to hit harder, I'm just trying to figure out what I should do. I've thought about using a -3db tuning tone. And also tuning with the subs plugged in. When I originally tuned with my 50hz tone, I had my hu hpf set but sound to still went out to the door speakers... One I don't think that's normal and two could it have affected the tuning?
    set the amp gain UNLOADED with a DMM, that's digital multimeter. When a load is presented afterward, the resistance of that load will determine how much amperage will be put out at that target voltage, which then will result in wattage.
    Bass in music rarely sees 0db, so most people use -3 or -6db to set gains. I use 0db because I like the reference point it gives me due to the fact that all my music is bass boosted through Audacity.
    Food for thought, if you set gains with 0db tone, and the song you play doesn't exceed -6db, you're only getting quarter power. So 1000watts is actually 250watts. Therefore, you have to turn up the volume on the HU some more to get closer to 1000watts.
    If you set gains with a -3db tone for 1000watts, now that -6db tone in that song is giving you 500watts.
    All day I'm clippin'
    voltage be dippin'
    I don't give a damn,
    cause my trunk always hittin'!
    creating a proper sound wave. Step one, turn it up until clipping. Step two, done.
  2. #17
    Spooney's Avatar
    Spooney is offline CarAudio.com Veteran
    Dec 2007
    Charlotte,MI,USA
    37
    4,416
    3 Post(s)
    793 Post(s)
    The high pass filter on your headunit is not a sonic brick wall . Some of that 50 hz tone is going to make it to your speakers whether you like it or not unless that filter has a really steep slope. I wouldn't be concerned that some of the tone is making it through to your interior speakers unless it is distorting them badly. Like was mentioned before that test tone is much higher in signal than your music. I have always set my gains by ear. I know it doesnt work for everyone but it has served me well for the last 18 years.
  3. Thanks heimsothe thanked for this post
    Likes BoomBoxStereo, shauncox26 liked this post
  4. #18
    Sep 2013
    Mount Pleasant, PA
    109
    51 Post(s)
    Quote Originally Posted by bigaudiofanatic View Post
    Yep AND turn your SW level to 0!!!!! Not max
    Really? I thought you were supposed to max it out?
    HU: Kenwood Excelon KDC-X397
    Front speakers: Kicker 40CS654
    Back speakers: Kicker 40CS54
    Amp: American Bass VFL 4480
    Sub: 2 Soundqubed HDS312
    Wiring: KnuKonceptz Kolossus 4 Gauge OFC
  5. #19
    marcos65's Avatar
    marcos65 is offline Member
    Aug 2013
    Phoenix, AZ
    97
    32 Post(s)
    I thought that on Kenwoods and Alpines you have to max it out to get the full RCA voltage?
  6. #20
    bigaudiofanatic's Avatar
    bigaudiofanatic is offline Dynamic Mobile Audio
    Nov 2008
    Bridgeton NJ
    29
    1,934
    53 Post(s)
    I have always set mine with everything flat no bass boost no sub level up nothing. Even on all kenwood and alpine I've used and installed.
    I help people with car audio, computers, and much more.
    AIM me at reimermatt
    http://www.caraudio.com/forum/showth...wpost&t=370497
  7. #21
    heimsothe's Avatar
    heimsothe is offline Member
    Dec 2013
    Portland, OR
    66
    34 Post(s)
    Thanks guys, so I should continue to tune without my subs plugged in? I'll use a -3db tone at 60hz. Hopefully this will help it. If I'm correct, my 8 band eq should be flat when I time the amp?
  8. #22
    heimsothe's Avatar
    Dec 2013
    Portland, OR
    66
    34 Post(s)
    Tune the amp is what I meant, not time. Sorry on my phone
  9. #23
    Nov 2008
    Bridgeton NJ
    29
    1,934
    53 Post(s)
    Everything flat and sub plugged in
  10. #24
    fatboytyler's Avatar
    fatboytyler is offline CarAudio.com Elite
    Nov 2013
    Easternl Kentucky
    24
    1,141
    2 Post(s)
    543 Post(s)
    Quote Originally Posted by Biggiesmails72 View Post
    I too am curious on this. I know on my JVC when the sub level is at 0/8 (There is no negative) there is absolutely no power going to the amp what so ever.
    EDIT: By power I mean audio signal via the RCAs
    References: mylows10, michaellane, Tantricz, bradl79
    Amp: RF R1200-1D and SoundQubed Q4-120.4
    Speakers: 2 SA-12s in 4 Cubes @ 32 Hz with ES-6iM (Mids), TW-125 (Tweets), EX-530 (X-Over)
    Electrical Singer 275 Amp (Clamped 284+ Amps), 0 Gauge SHCA OFC (Big 3), Mix of 4 Gauge CCA SHCA and Knu, Shitty G24 Lead Acid (RIP to my Deka)
    Quote Originally Posted by C1500martin View Post
    Life has bent you over butt fucked you busted down your throat made you spit it back out onto cow shit and slurp it back up and swallow.
  11. #25
    heimsothe's Avatar
    Dec 2013
    Portland, OR
    66
    34 Post(s)
    Why sub plugged in? Some people are saying tune amp loaded and some say unloaded
  12. #26
    nismos14's Avatar
    nismos14 is offline CarAudio.com Veteran
    Dec 2006
    Jersey
    37
    14,586
    273 Post(s)
    Set everything on the hu to 0 also, not maxed out.
    Car audio IS an addiction.
    C.A.A.A Member #1
    (Car Audio Addicts Anonymous)
    Refs http://www.caraudio.com/forums/buyer-seller-feedback/278560-nismos14-feedback-refs-thread.html
  13. #27
    Nov 2008
    Bridgeton NJ
    29
    1,934
    53 Post(s)
    Because otherwise you will not be tuning g properly. The readout with a dmm needs to be under load hence ohms which is why you want the sub conected.
  14. #28
    nismos14's Avatar
    Dec 2006
    Jersey
    37
    14,586
    273 Post(s)
    Huh
    C.A.A.A Member #1
  15. #29
    Nov 2008
    Bridgeton NJ
    29
    1,934
    53 Post(s)
    Quote Originally Posted by nismos14 View Post
    Huh
    He needs to have a load on the amp to show correct running with a DMM
  16. #30
    heimsothe's Avatar
    Dec 2013
    Portland, OR
    66
    34 Post(s)
    I'll try tuning with the load of the subs present, eq flat, and a -3db 60hz tone
  1. Subs aren't hitting PLEASE HELP!!!
    By Justin braaapp in forum Wiring, Electrical and Installation Help
    Last Post: 09-21-2013, 01:16 PM
  2. Replies: 7
    Last Post: 09-21-2013, 07:52 AM
  3. subs aren't hitting as hard as they should
    By snev in forum Wiring, Electrical and Installation Help
    Last Post: 01-20-2012, 10:46 PM
  4. Replies: 17
    Last Post: 06-25-2010, 04:24 PM
  5. alpine type x's not hitting like they should...
    By snowcruizer713 in forum Subwoofers
    Last Post: 01-31-2010, 09:22 AM
Tags for this Thread
