Results 1 to 4 of 4
Reload Thread: What sub to use with this amp?
    Chrysler300M-an's Avatar
    Chrysler300M-an is offline Junior Member
    Jan 2014
    LA
    I have a Coustic Power Logic AMP 260
    It says "45 Watts RMS Per Channel or 125 Watts RMS (Bridged Mono)"
    I just want to hook up a single 10 inch sub woofer but I don't know what kind to buy, as I am 100% green when It comes to amps and subs and what goes with what. the amp is so old that there isn't even a manual online so I had to scan a page from a friends and paste it online. These are the only specs I have for it.
    Picture here:
    Specs (Far Right Side Is My Amp):
    Any help would be awesome and a great contribution to a green horn!
    Thanks again.
    Also, I went to crutchfield and they recommended this:
    Rockford Fosgate R1S410 Prime Series 10" 4-ohm subwoofer at Crutchfield.com
    and said I could use a 4 ohm sub with a wattage of 100-150
    CrossoverOre's Avatar
    CrossoverOre is offline CarAudio.com Elite
    May 2012
    oregon
    1,041
    205 Post(s)
    Re: What sub to use with this amp?
    that sub would work.
    Jan 2014
    LA
    Quote Originally Posted by CrossoverOre View Post
    How did you figure it would work? Like how do you calculate it that a sub will work with it?
    sciontistbb's Avatar
    sciontistbb is offline Member
    Jan 2012
    In the garage
    95
    24 Post(s)
    That amp you have puts out 125 watts @ 4ohms bridged, the R1 is rated 150 watt RMS. It is a single voice coil 4 ohm sub. 125 watts going to sub that can handle 150 watts. No calculators, most of the guys here have been in the business a long time...
    2005 Scion xB
    Head Unit: 80PRS
    Front Stage: Hertz HSK 165
    Sub: Incriminator Audio Lethal Injection
    Amps: DD C4c, DD M1c
    Underhood: Js Ultimate 240a Alt, Diehard Platinum AGM
    Quote Originally Posted by EnemyxXxGhost View Post
    Why would I want a mono block, I'm running 2 subs...the 4 channel is bridged down to 2 chs
    Bought from: The Silverman, Dmac1991
  1. I need a Sub to go with this AMP HELP
    By DaBurner in forum Subwoofers
    Last Post: 12-26-2006, 05:10 PM
  2. decent subs to run with this amp
    By alenon12 in forum Subwoofers
    Last Post: 08-17-2006, 02:39 PM
  3. Need a sub to go with this amp...need help
    Last Post: 01-15-2006, 08:54 PM
  4. Which sub to pair with this amp?
    By MetalMaxima in forum Subwoofers
    Last Post: 01-13-2005, 07:38 PM
  5. subs to use with this amp
    By x5-452 in forum Amplifiers
    Last Post: 12-05-2002, 10:47 PM
