Page 1 of 2 1 2 LastLast
Results 1 to 15 of 27
Reload Thread: Help With Finding My Problem??
    scotty3x3's Avatar
    scotty3x3 is offline Member
    Nov 2013
    Tampa, FL
    36
    10 Post(s)
    Hey guys. Got a pretty basic install in my 2013 Elantra.
    Kenwood DNX890HD
    Alpine Class D 450 Watt RMS Mono Amp
    Alpine Class D 400 Watt RMS 4 Channel Amp
    12" Memphis Audio Sub (300-600 Watt RMS)
    1 Farad Rockford Fosgate Cap
    Clarion 3 channel Crossover Network
    0 Gauge Wiring from Battery to Cap, 4 Gauge from Cap to distribution block, 4 gauge to both amps - grounded to rear seat mounting bolt.
    Yesterday I noticed the battery light on in the car for about 2 minutes then I parked and went into a business... came back out and the light was off... didn't see it again until later. Later comes on my way to dinner, all sound cuts out but radio is still on with nav running normally. LED lights in cluster start coming on, lights start to dim and I lost power steering. Pulled over to the side of the road and called for help.
    Pops got there, jumped the car, removed the fuse from the power wire and the car has been fine ever since. Started right up after dinner, started right up this morning. Is the alternator just not strong enough for what I have? This is really not anything extravagant.
    I'm going to take it apart this weekend to try to troubleshoot. Any possible ideas would be much appreciated!
    Thanks.
    djulz93's Avatar
    djulz93 is offline Member
    Nov 2012
    chicago
    52
    15 Post(s)
    Re: Help With Finding My Problem??
    You should check your voltage. To me it sounds like you're straining the electrical.
    scotty3x3's Avatar
    Nov 2013
    Tampa, FL
    36
    10 Post(s)
    Quote Originally Posted by djulz93 View Post
    This has pretty much been the consensus of everyone I have talked to about this. I will connect everything back up tonight test the voltage. If I'm reading 11-12 with the system playing, I will know that could be the problem.
    The question I have is how to rectify this problem. My system is not that large and I don't want to have to downgrade if I don't have to.
    djulz93's Avatar
    Nov 2012
    chicago
    52
    15 Post(s)
    Do you plan on upgrading in the future? And my guess would be the battery is bad, or maybe even the alternator (don't quote me though, because I'm the furthest thing from an expert in this field haha).
    scotty3x3's Avatar
    Nov 2013
    Tampa, FL
    36
    10 Post(s)
    The sound I get now is what I see myself sticking with. I don't want insane SPL or anything like that. And while it's not 'impossible' for either the battery or alternator to be bad, the car is barely a month old. I bought it brand new from the dealer a little over a month ago. So it if they are bad, no big deal, I'll have them repaired, but I would like to know some things I can troubleshoot before I just take it to the dealer and they say my audio install caused a failure.
    jrdnhsnbrg's Avatar
    jrdnhsnbrg is offline Pimped my grandma's ride
    Aug 2012
    Menomonie, WI
    22
    1,874
    683 Post(s)
    Take your car to autozone and have them do an alt and battery test.
    2013 Ford Taurus SEL - James aka Captain Slow
    Stock... For now.
    New build log:http://mobileaudioforum.com/forum/showthread.php?8019-2013-Ford-Taurus-SEL-audio-performance
    djulz93's Avatar
    Nov 2012
    chicago
    52
    15 Post(s)
    ^ what he said. And the reason I asked if you planned on upgrading was because you can upgrade the electrical (better battery or h/o alt), but that would be the expensive route if you don't plan on going past 1k.
    Freeman's Avatar
    Freeman is offline I TrY
    May 2013
    Watertown, SD
    834
    310 Post(s)
    why do u have a cap?
    1986 Nissan hardbody
    Hu:Kenwood Kmm-100u
    front:1 Cheep Kenwood speaker.
    Rear:the 3in of room behind my seat where my amp sits
    Sub:soon
    Amp:polk pa330
    Wiring:1/0 knu kca to 4gauge distribution block and 1/0 kca big 3
  9. #9
    argenis69's Avatar
    argenis69 is offline SQ Bass Lover
    Dec 2012
    NY, USA
    836
    245 Post(s)
    I will do a complete test on the battery and alternator. That light only turns on when one of those 2 are with problem.
    Front stage Image Dynamics 6.5 CX62 V2. Rear stage O2 Audio 5 1/4in.
    Cadence Tweeters. KnuKonceptz Rcas and Wiring.
    Kicker Impulse x3i 3-way Active Electronic Crossover(disconnected for now).
    JL Audio 300/4 . JL Audio XD700/5 . Crescendo BC3500D.
    15" Fi Audio SP4 fully loaded in 3.5cu ft flared ported box.
    One complete +/- run of Knu Ofc 0 gauge with big 3, volt meter inside, biggest acid battery under hood, Battery Isolator. A XS Power D3100 and a Crescendo Logic F-31HP battery in trunk.
  10. #10
    scotty3x3's Avatar
    Nov 2013
    Tampa, FL
    36
    10 Post(s)
    Well, the alternator appears to be working. Last night I reconnected my power wire to my battery and played the system for a little while watching the volt output from the battery. Turned the inside air on full blast, all lights on system turned up loud and the lowest reading I got from my battery was down to 11.6 volts, but the battery light in the car did not come on. I turned the car off and went to bed. This morning the battery light was on as soon as I started the car. I checked the battery and it was still reading 11.6 volts. I drove the car on the way to work for about 6 minutes hoping the alternator would charge the battery, but when I checked, the battery still read 11.6. I disconnected the power wire again and as soon as I got in the car, the battery light was off. I drove to work and checked the battery when I got there and it was reading 14.2 again. I don't think the battery is bad or the alternator since it charged back up without the system. I just need to find out why this relatively small system is pulling so much from my battery.
  11. #11
    mylows10's Avatar
    mylows10 is online now B2,singer,ampere rep mylows10 is a Supporting Member of the forum!
    mylows10 is a Supporting Vendor of the forum!
    Sep 2009
    monterey , ca
    54
    22,433
    141 Post(s)
    1 Thread(s)
    6011 Post(s)
    Dump the cap. This maybe the cause. Get a big 3 kit instead $45 the amps your running shouldn't be causing this. Not enough power. Also check to make sure you have good grounds as well
    pioneer avhx 4800 dvd, ampere tfhe 9.0 and 150.4 with arc audio xxd 4080
    4 d3100 and 3 deka 8a31 and d975 ,270 dc power and 320 amp singer alt
    B2 ref mids,Cdt es6 mids cdt es 010 tweets x2 ,es 03 Mids x 2 mx1000 , sky high ,eb flex, and stinger hpm o gauge wires ,also 2 crossfire xsv2 18s in a 4th order no wall box
    NOR CAL DB DRAG JUDGE
    http://www.dcsoundlab.com
  12. #12
    djulz93's Avatar
    Nov 2012
    chicago
    52
    15 Post(s)
    The first thing that comes to my mind is that while the alternator can charge the battery, it isn't built to power anything much more than stock equipment. What was your reason to install a cap though? Because I've been told by various people they really don't do anything beneficial unless it's the really high quality and your goal is spl.
  13. #13
    scotty3x3's Avatar
    Nov 2013
    Tampa, FL
    36
    10 Post(s)
    Quote Originally Posted by mylows10 View Post
    I have read about the big three upgrade. My question is does this upgrade void my warranty?? The only reason I bought this car was the 5/10 year warranty. I don't want to have a problem with my alternator or something and take it to them to turn around and blame the wiring change I made. Can you suggest a kit for me? link
    This system was in my previous car and I've had the cap for roughly 3 1/2 years. Back then, caps were an accepted solution to lights dimming with bass hits. I bought the cap, put it in and it fixed the issue. I've had it in 2 different cars since then and never had this issue.
  14. #14
    mylows10's Avatar
    Sep 2009
    monterey , ca
    54
    22,433
    141 Post(s)
    1 Thread(s)
    6011 Post(s)
    Quote Originally Posted by scotty3x3 View Post
    Shouldn't void any warranty. Your just adding more and larger wire not removing anything. I have kits ready to bolt on
  15. #15
    scotty3x3's Avatar
    Nov 2013
    Tampa, FL
    36
    10 Post(s)
    Checking your site, I don't see any Big 3 upgrade kits... just subs, amps and accessories like shirts and hats.
  1. Need help with finding the correct harness for my head unit (Sony CDX-GT250MP)
    By nickk513 in forum Wiring, Electrical and Installation Help
    Last Post: 12-11-2012, 07:03 PM
  2. Help me find my Monoblock Amp..
    By absolutcain in forum Amplifiers
    Last Post: 12-22-2003, 12:33 AM
  3. Replies: 1
    Last Post: 01-25-2003, 12:05 AM
  4. Hey I need Help with a simple problem!!
    By Lord_Vegeta in forum Wiring, Electrical and Installation Help
    Last Post: 12-24-2002, 09:29 PM
  5. Help with RV audio problem
    By LlamaLarry in forum Wiring, Electrical and Installation Help
    Last Post: 07-16-2002, 10:16 AM
