Results 1 to 5 of 5
Reload Thread: building solar floating ice chest entertainment center
    lf1047@txstate's Avatar
    lf1047@txstate is offline Junior Member
    May 2004
    san marcos tx
    Im building a solar powered floating icechcest intertainment center. Im just researching solar equipment and am not sure if i have it all correct. Is there anyone out there that has any experince with it. I was going to power a headunit and dvd player that will be a source to 1 10 inch screen and the radio will power 2 6x9's. I found solar pannels in radioshacks webpage that are 6volts and 7 amps each, i was going to wire them in parallell to get 12 volts and use a pair of 6volt batterys they sell to power the copmonets.
    anyone have any suggestions for me?????
    boister77's Avatar
    boister77 is offline CarAudio.com Elite
    Dec 2003
    SoCal
    36
    824
    Re: building solar floating ice chest entertainment center
    where do you plan to mount the solar cells? also, do you plan to wire all of your entertainment components to the solar cell powered batteries? if so, i'm not sure if the solar cells will be able to keep up with the amount of power pulled. however, it's a nice idea.
    www.realmofexcursion.com: Free Hosting for Videos, Pics, Audio, and more!
    forum.realmofexcursion.com: Another car audio forum.
    the_flatlander's Avatar
    the_flatlander is offline CarAudio.com Elite
    Jun 2003
    Wisconsin
    30
    745
    I don't think it will work. In your home the power outlets the smallest is 15amps. What kind of solar panels are you getting?
    1995 Acura Integra Ls
    Pioneer DEH-P7500
    RE XXX12
    RE 12.1
    Quote Originally Posted by snova031
    They should make people like superman get parental consent before conducting any online activity.
    Quote Originally Posted by `pr0digy
    I was giving you a free massage officer... I'm sorry you didn't like it!
    Quote Originally Posted by Jmac
    I always thought you needed a 7th order quasi-quintiple bandpass transmission snail line in order to put up good numbers and sound good ...
    May 2004
    san marcos tx
    If I delete the dvd player and the monitor, and just use a cd player and 4 6x9's that may be enough power for that.....I dont understasnd why you say it may not be enough power if a cd player pulls no more than 15-20 amps max. If the batteries are 6volts I can wire them in parallell to provide 12 volts and the solar cells supply 7 amps each so by wiring them in parallell that should be 14 amps. Am I missing something? Do you think the CD head unit will pull too much current too fast or may there be another problem???
    cdr's Avatar
    cdr
    cdr is offline Member
    Dec 2003
    AZ
    31
    136
    you have to remember though that 7 amps/cell is in prime conditions.
