Results 1 to 2 of 2
Reload Thread: Wiring Alpine SWR 12D2 with Infinity 5350a
    sdalpine's Avatar
    sdalpine is offline Junior Member
    Nov 2013
    United States
    2 Post(s)
    Hey everyone,
    I have an Alpine 12 inch type R and an Infinity 5350a amp and was wondering what the most power i could get out of the amp was with what wiring. I've tried looking up explanations on wiring but am completely lost. I'll post the specs for the amp as well as the sub below. Any help would be much appreciated.
    Infinity Reference 5350a 5-channel car amplifier 50 watts RMS x 4 + 150 watts RMS x 1 at Crutchfield.com
    http://support.alpine-usa.com/produc...2_4_12D2_4.pdf
    CrossoverOre's Avatar
    CrossoverOre is offline CarAudio.com Elite
    May 2012
    oregon
    1,038
    205 Post(s)
    Re: Wiring Alpine SWR 12D2 with Infinity 5350a
    you will need to wire the sub coils in series creating a 4ohm load. that amp is not 1ohm stable. You are also going to be severely underpowering that sub. i would highly recommend a dedicated sub amp for that sub. 1000 watt rms sub on 150 watt rms amp is just not enough. It will make some noise but not nearly what is should or can do.
  1. Alpine SWR-12D2/D4: 800W @ 2 ohms or 1200W @ 1 ohm ?
    By Golitan11 in forum Amplifiers
    Last Post: 07-29-2013, 12:15 AM
  2. Replies: 5
    Last Post: 03-09-2013, 11:31 PM
  3. 2x Alpine SWR-10D4 with Alpine mrp m1000 good ?
    By greenpat01 in forum Subwoofers
    Last Post: 12-27-2012, 05:36 PM
  4. best amp for a alpine swr 12d2
    By joeysalas421 in forum Amplifiers
    Last Post: 07-09-2012, 08:55 AM
  5. Alpine SWR 1222D or Infinity Kappa Perfect 12"
    By bballman1441 in forum Subwoofers
    Last Post: 01-21-2007, 05:09 AM
Tags for this Thread
