Results 1 to 10 of 10
Reload Thread: 4/3/2 channel amp wireing.
    moparman1's Avatar
    moparman1 is offline Junior Member
    Sep 2013
    PA
    2 Post(s)
    Icon33 4/3/2 channel amp wireing.
    I had a Sony xplode 600watt amp given to me. I plan on running all 2 6x9s and 2 6.5s along with 1 12" sub. How do I go about wiring this? The car is a 2000 Chrysler cirrus, any ideas on where to put my amp? Run my power cable? Any help would be great!
    Jepalan's Avatar
    Jepalan is offline CarAudio.com Elite
    Jun 2013
    Midwest
    603
    1 Post(s)
    158 Post(s)
    Re: 4/3/2 channel amp wireing.
    What head unit are you using?
    What model sony amp exactly?
    What brand & models are all the speakers & sub?
    What kind of enclosure is the sub in and where is it mounted?
    2000 Chrysler Cirrus Car Audio Wiring Color Codes
    Car Radio Battery Constant 12v+ Wire: Pink/Yellow
    Car Radio Accessory Switched 12v+ Wire: Red/White
    Car Radio Ground Wire: Chassis
    Car Radio Illumination Wire: Orange/Brown
    Car Stereo Dimmer Wire: Black/Light Blue
    Car Stereo Antenna Trigger Wire: Ornage/Red
    Car Stereo Amp Trigger Wire: N/A
    Car Stereo Amplifier Location: N/A
    Car Audio Front Speakers Size: 6 1/2″ Speakers
    Car Audio Front Speakers Location: Doors
    Left Front Speaker Positive Wire (+): Light Green/Green
    Left Front Speaker Negative Wire (-): Light Green/Purple
    Right Front Speaker Positive Wire (+): Light Blue/Green
    Right Front Speaker Negative Wire (-): Light Blue/Purple
    Car Audio Rear Speakers Size: 6″ x 9″ Speakers
    Car Audio Rear Speakers Location: Rear Deck
    Left Rear Speaker Positive Wire (+): Brown/Yellow
    Left Rear Speaker Negative Wire (-): Brown/Light Blue
    Right Rear Speaker Positive Wire (+): Dark Blue/White
    Right Rear Speaker Negative Wire (-): Dark Blue/Orange
    moparman1's Avatar
    Sep 2013
    PA
    2 Post(s)
    All I know is It's a Sony xplode 600watt 4/3/2 channel. All my speakers are OEM for now. Sub is a mtx. That's all I really know. The box was bought from a local audio guy.
    Jepalan's Avatar
    Jun 2013
    Midwest
    603
    1 Post(s)
    158 Post(s)
    OK, sorry, I thought maybe you could turn the amp over and look for a label, but apparently too much trouble. Does it look like the one in this link...?
    https://docs.sony.com/release/specs/XMGTX6040_mksp.pdf
    Also maybe you can look at the back of the sub and tell me if it has one or two voice coils and what impedance they are (probably 2 ohm or 4 ohm) Or maybe there is a model number there.
    The reason we ask these questions is so we don't tell you to connect things in a way that will blow the speakers or amp.
    You can't connect the amp to all those speakers. you don't have enough channels. I would just connect the amp in 3-channel configuration where you run the front L/R speakers off amp channels 1 and 2 and then bridge the outputs of channels 3 & 4 to drive the sub.
    I highly recommend you get a new pair of fornt speakers when you do this as you will probably just blow the factory speakers by adding only an amp.
    moparman1's Avatar
    Sep 2013
    PA
    2 Post(s)
    The amp is bolted down in my car and I drive my truck to school and work so I didn't get to look at the label. Sorry, yes it does look like that one in the picture exactly. I'm probably not going to hook the sub up as I don't listen to music with tons of base. Could I atleast power my front and rear speakers? I'm going to get Sony xplode speakers within the next few days. Thanks for the help.
    CrossoverOre's Avatar
    CrossoverOre is offline CarAudio.com Elite
    May 2012
    oregon
    1,041
    205 Post(s)
    You could just use the amp to power the midrange speakers. But if you have a sub already I would highly recommend putting it into the system. About 20% of music is played in a range that is not friendly for midrange speakers to reproduce. So even if you dont set the sub to output a lot you in fact gain a lot just by having it.
  7. Thanks moparman1 thanked for this post
  8. #7
    moparman1's Avatar
    Sep 2013
    PA
    2 Post(s)
    Do I need another amp for the sub then?
  9. #8
    May 2012
    oregon
    1,041
    205 Post(s)
    Quote Originally Posted by moparman1 View Post
    if you are planning on using the 4ch to run all midrange speakers then yes, but you could get away with just using it to run the front speakers and the sub.
  10. #9
    Jepalan's Avatar
    Jun 2013
    Midwest
    603
    1 Post(s)
    158 Post(s)
    Quote Originally Posted by CrossoverOre View Post
    ^^ this is what I would recommend.
    But - to answer your original question - yes, the 4-ch amp will power the front and rear speakers just fine. This is the most basic application of a 4-ch amp. Diagrams are in the manual. My cautions above about over-powering your factory speakers still apply. Set your gains correctly and you should be OK.
  11. #10
    Nov 2013
    Circle Pines, MN
    33
    14 Post(s)
    IMO amping rear speakers isn't really worth it. I would put your front speakers on the front channel, and bridge the rear channel at 4 ohms to the sub. Hopefully your sub is a SVC 4 ohm or DVC 2 ohm.
  1. 4 channel amp wiring
    By bdisslimm in forum Wiring, Electrical and Installation Help
    Last Post: 02-02-2007, 01:51 AM
  2. 2 channel amp wiring options
    By derek33 in forum Wiring, Electrical and Installation Help
    Last Post: 03-30-2005, 10:21 AM
  3. Eclipse (or any 4 channel amp) Wiring/Setup Help
    By downsider in forum Amplifiers
    Last Post: 11-16-2003, 09:25 AM
  4. Eclipse (Or Any 4 Channel) Amp Wiring ?
    By downsider in forum Speakers
    Last Post: 09-10-2003, 06:48 PM
  5. 4 Channel amp wiring question
    By Croat23 in forum Wiring, Electrical and Installation Help
    Last Post: 11-06-2002, 09:02 PM
