Page 1 of 2 1 2 LastLast
Results 1 to 15 of 25
Reload Thread: 2013 4runner 4 Channel amp install Help
    T4R13's Avatar
    T4R13 is offline Junior Member
    Oct 2013
    Tampa
    17
    I'm currently trying to upgrade my sound system on my 2013 4runner with standard audio system and I think would get more help from you guys than my 4runner forums.
    Local shop wants 75 for the amp install and another 75 for the component and I figured I could do this again by myself if I get all the right resources.
    This all started when I picked up a JL 10W0v3-4 in a wedge box for cheap. And figured it's time to upgrade the pathetic standard system since I have my old Rockford Fosgate Power 400.4 4ch amp laying around from my previous car. My plan is to use the stock HU for now and bridge the rear ch for 1 10 inch sub and front channel for the front components and leave the rears speakers. I have now purchased Image Dynamics CTX 65CS which will include a mounting kit for my front doors and I think a tweeter mount that I could use if I decide to mount it on the stock front dash location
    I will be using this thread as a guide for my amp install and this thread as well for the speaker install, and install the amp under front passenger seat instead.
    First problem I can see is that if I decide to mount the tweeter on the dash location is that according hieroglyphics that someone attached here on this thread, is that front door speakers and front dash speakers are wired as parallel and I concluded that it's not just a simple switch plug and play installation of speakers. Any recommendations on what's the best way of doing this? Do I have to lay new speaker wires going to front door and front dash speaker locations? Where is the best position for the crossover unit? From photos here it looks like there's lot of space behind stock HU compared to door area here..
    I have thought of just mounting the tweeter on the door jamb to make it an easier install but cuttting the door jamb just upped the dificulty level on this install for me.
    As for wiring is there a online database for factory head unit wiring diagrams? Also where should I tap remote switch? Any one familiar with the 4runner party mode here? Where is the best speaker to tap the 2 sni 35, front, rear, or liftgate?
    Have'nt found any thread on how I can snake a speaker wire from under front passenger seat to the rear so any ideas where should I run this speaker cable? I'm thinking of rigging an speaker terminal post on one of the rear panel where I can plug a speaker wire with banana plugs on both ends so I can easily remove the sub box if I need extra cargo.
    Here are list of stuff I have gathered so far for the install feel free to add anything I might need to make this install right.
    RF 8 AWG Amp Install kit
    25 Sq Ft of Sound deadening material from amazon.
    Posi tap connectors and this solderless wire terminal and connectors
    Fish tape/line
    I think that's it for now. I know I have more questions as I go through this. Thanks in advance for any help!
    T4R13's Avatar
    Oct 2013
    Tampa
    17
    Re: 2013 4runner 4 Channel amp install Help
    Found on the last page of this thread repair manual but can't seem to find anything about speaker wiring diagram.
    keep_hope_alive's Avatar
    keep_hope_alive is offline Acoustics Engineer keep_hope_alive is a Supporting Member of the forum!
    May 2007
    Quad Cities, IL
    7,078
    28
    47 Post(s)
    1500 Post(s)
    welcome.
    first, you need an interface between the stock head unit and the amplifier(s). The Audio Control LCQ-1 is a nice piece for this and includes some equalization for you to further tweak the system.
    you will need to run new wire from the crossover's tweeter outputs to the tweeters. the stock tweeters have a small crossover mounted to them. locate them in the stock locations as they were determined on purpose by the vehicle engineers. further testing of locations and aiming are possible if you want to build custom pods.
    you can re-use the stock wiring for the door woofers and intercept it behind the head unit (i.e. cut) and connect to the crossover woofer outputs.
    new wire will be used from the amplifier to the crossover inputs. i like mounting crossovers next to the amp for several reasons but this increases wire length. not a huge deal since you are running cables anyway. you can put them in the glove box but you lose some space there and wiring is a PITA.
    the LCQ-1 (or other OEM interface) will also need to be accessible so putting it under a seat or at the amp is a good idea (not behind the dash). you will need to run wiring from the stock head unit to the interface as well.
    for jobs like this, i find cutting wires poor form and I buy two wire harnesses. one into the car and one into the radio. that simplifies installation and eliminates cutting of factory wiring while allowing you to reuse some of it.
    got a question? shoot me a PM. Matthew 6:9-15 - YouTube Channel: https://www.youtube.com/channel/UCkYUo2EShW9lgtrfXiDvLNQ/videos
    2014 Accord build log: http://www.caraudio.com/forums/car-audio-build-logs-cars-trucks-suvs/608637-2014-accord-sport-sq-build-keep_hope_alive.html
    2001 Accord build log: http://www.caraudio.com/forums/car-audio-build-logs-cars-trucks-suvs/536049-2001-accord-ex-sedan-its-long.html
    Fix Photobucket Image Loading ------> https://addons.mozilla.org/en-US/firefox/addon/photobucket-fix/ <------
  4. Likes tommydh liked this post
  5. #4
    tommydh's Avatar
    tommydh is offline CarAudio.com Elite
    Mar 2012
    Baltimore, MD
    501
    160 Post(s)
    Quote Originally Posted by keep_hope_alive View Post
    welcome.
    This is the best advice your gonna get listen to this man. I also like the Audio Control Lc6i but the LCQ-1 is the latest piece i believe that includes a few extra features you will find andy. Or you just go new HU its not much diff on price
    Pioneer DEH 80 PRS
    1 Sundown SD-2 10,
    Kicker SS56.2 components.(Soon to be changed out) Anyone with a set of these or maybe a single mid I'm looking
    Rockford Fosgate T-1000.1bd
    Pioneer GM6400f
    I am DH Audio.,
    This isn't baseball I'm the original DH Richard Ctranium
  6. #5
    May 2007
    Quad Cities, IL
    7,078
    28
    47 Post(s)
    1500 Post(s)
    if you get the Metra 70-1761 and 71-1761 those harnesses will give you access to the wiring behind the head unit without cutting wires.
    The 71-1761 plugs into the back of the radio and you get front and rear speaker outputs you can extend to the OEM interface.
    The 70-1761 plugs into the harness in the car and gives you access to the front speaker wires and lets you connect the rear speakers to the head unit. you can connect power and ground between the two, and tap it also for power of the interface (if you want to put it under the front seats, for example).
  7. #6
    T4R13's Avatar
    Oct 2013
    Tampa
    17
    Thanks for the reply. Originally it was just a low budget build, hook up the cheap sub box that I picked up and I'm happy with the added bump with the single 10" but we all know how every budget builds gets out of hand easily once you start reading up on one of these forums.
    The audio control unit looks like a great idea but I think once I get another good excuse for a GPS navigation unit for my wife then boom there goes in a 6-7 inch touch/smart/nav HU. I'll stick with 2 sni-35 for now and save it up for new HU.
    This is the dash speaker, read somewhere that seem to be the small crossover that you're talking about. So as long as I run new tweeter speakers to the crossover I should be good right? Like I said earlier would to put the tweeter in the dash for stealth however I keep my options open. If I decide to mount it in the door jamb, can I just unplug the dash speaker to disable it? Or would I just end up with an open circuit?
    How about front door speaker should I be worried about hidden crossover somewhere in the wiring if I decide to just intercept the factory wiring from the stock HU?
    16 guage regular speaker wires should be ok or should I go smaller to make it easier to run? What's the min guage that's recommended? I would like to hide everything under the front seats. What's the no. 1 reason you'd want the crossover by the amp? I always thought people just hid these behind door panels.
    71-1761 and 70-1761 purchased through amazon prime already. I'm guessing they have on the packaging which wire is the front/back speakers since they're designed for toyota's?
  8. #7
    May 2007
    Quad Cities, IL
    7,078
    28
    47 Post(s)
    1500 Post(s)
    the black cylinder with letters on it is a capacitor (non-polarized). in-series with the speaker it provides a 6dB/octave high pass filter (not suitable for tweeters).
    you would make a mount to hold the new tweeter in that location - you will want to play with aiming for best sound (forward, up, back, angled, etc.)
    the front woofer is full-range. no worries about a crossover on it.
    16awg is fine. 18 awg is as small as I go (and it needs to be high-quality CL2 rated wire). I commonly use 2- and 4-conductor CL2 rated wire (has an outer jacket and used in home construction, in walls).
    NEVER put a crossover inside a door. inside of a door gets wet and will rust/destroy crossovers. aftermarket speakers need to have an internal water channel - I use closed cell weatherstripping foam. (I also use foam to create seals between speaker and door panel - see my build logs) Putting it behind the panel (on the plastic) only works if the tweeter is mounted to the door - door tweeters usually suffer for location due to height. Since the crossover needs to feed the door and dash, keeping it in the cabin makes the most sense and simplifies everything. most have adjustments for tweeter level so you want them accessible. you can hide them, but you want wiring secure so it doesn't loosen. mounted at the amp is the most secure location, wire management is easily achieved, and access is inherent.
    luckily, with the wire adapters you bought, the color codes are industry standard and simply match up. and yes, a color code is provided on the package.
    color codes:
    Car Stereo Head Unit Wiring Harness
    factory color codes (for factory wire polarity identification)
    2012 Toyota 4Runner Car Audio Wiring Chart
    Car Radio Battery Constant 12V+ Wire: Light Blue
    Car Radio Accessory Switched 12V+ Wire: Gray
    Car Radio Ground Wire: Brown
    Car Radio Illumination Wire: N/A
    Car Radio Dimmer Wire: N/A
    Car Radio Antenna Trigger Wire: N/A
    Car Radio Amp Trigger Wire: N/A
    Car Stereo Amplifier Location: N/A
    Car Audio Front Tweeter Size: 2 3/5″ Tweeters
    Left Front Speaker Positive Wire (+): Light Green
    Left Front Speaker Negative Wire (-): Blue
    Right Front Speaker Positive Wire (+): Violet
    Right Front Speaker Negative Wire (-): Pink
    Car Audio Front Speakers Size: 6″ x 9″ Speakers
    Car Audio Front Speakers Depth: 4″
    Left Rear Speaker Positive Wire (+): Black
    Left Rear Speaker Negative Wire (-): Yellow
    Right Rear Speaker Positive Wire (+): Red
    Right Rear Speaker Negative Wire (-): White
    Car Audio Rear Speakers Size: 6 1/2″ Speakers
    Second Rear Speakers Size: 6 1/2″ Speakers
  9. #8
    T4R13's Avatar
    Oct 2013
    Tampa
    17
    Ok got it. Almost have everything I need to do the install, component is scheduled to be delivered later today. I was going to start sound deadening the door this morning but rained overnight with 1 rear window cracked open so will need to wait for it to dry up.
    Got the wiring cables and just trying to visualize how to wire it up. So you're saying that unplug the factory harness from HU and replace with 71-1761 and plug the 70-1761 into the factory harness that I disconnected from the HU then splice them all back up with 1 SNI35 to left and right front speakers, and 1 SNI35 into just 1 rear speaker and power/or remote turn on for the amp?
    Should I turn the SNI35 gain all the way up before leaving it inside the panels?
    Just going through your build and would love to demo those cars you've built up. How do you go about knowing how these panels comes off in cars that you are not familiar with?
    BTW ended up a getting a used JL HD600/4 for dirt cheap. Would 150 watts be too much for the Image Dynamics CTX since it's only rated for 50 rms each? Or the 150 watts is more like 75 watts each speakers?
    Thanks for the help again.
  10. #9
    May 2007
    Quad Cities, IL
    7,078
    28
    47 Post(s)
    1500 Post(s)
    you don't reconnect the front speaker wires at the harnesses, you use the front speaker wires (left and right) from the deck to feed the SNI35#1 which gives an RCA signal to the front channels of the amp. the front speaker wires at the car harness are extended to the crossover woofer output.
    the rear speaker wires should ideally be assigned to SNI35#2 only and not reconnected to the rear speakers. that lets you use the fader on the head unit as a quasi-sub level control. you won't hear or want to hear the rear speakers anymore anyway. if anything, the rear speakers are now connected to the front speaker output on the head unit and you adjust level with gains so you can barely hear the rears relative to the front.
    otherwise, you keep the rears on the head unit and just use SNI35#1 on the fronts to feed 2 channels to the HD600/4. then set the HD600/4 to 2CH input mode.
  11. #10
    CrossoverOre's Avatar
    CrossoverOre is offline CarAudio.com Elite
    May 2012
    oregon
    1,041
    205 Post(s)
    another thing to keep in mind is it looks like the signal is jumped through the connector at the tweeter. might be easier (if they fit) to put the xovers in the dash below the tweets. if I'm not mistaken if you just unplug the tweet you loose signal to the mid in the door. The oem toyota wiring usually is a little beefier than some and should be sufficient to supply power to the doors without having to run new wires.
  12. #11
    T4R13's Avatar
    Oct 2013
    Tampa
    17
    D-Day today! Started at 12p halfway there. Amp wired up with power,ground and speakers wires to crossover hiding spot. just need to deal with wiring with HU.
    Bracket/adapter got online from tacotunes for 6x9 to 6.5 doesn't fit. Will need to make a trip to a shop tomorrow to get it fabricated.
    Gain on sni35 should I set everything on max?
  13. #12
    T4R13's Avatar
    Oct 2013
    Tampa
    17
    ust wired up the sni35 1 to front HU and SNI35 2 to rear.
    just to verify
    12 volt red from HU to remote turn on rfor amp right?
    I'm using 2 toyota metra harness so do I hook up everything else on the harness besides the front and rear to SNI35 ( 12 volt memory, ground, power ant,)?
  14. #13
    T4R13's Avatar
    Oct 2013
    Tampa
    17
    The the amp is working now with sub, man the HD600/4 is overkill for the JL 10W0v3-4, gain is not even quarter up with bass set -5, truck is thumpin! I'll probably look for another shallow mount speaker with higher RMS rating to replace this JL.
    Quick question on fuse, the HD600/4 manual recommends 50 amps fuse, closest I can get is 60 amp fuse, should I keep looking for 50 amps fuse or 60 would work?
  15. #14
    May 2012
    oregon
    1,041
    205 Post(s)
    60 is fine
  16. #15
    T4R13's Avatar
    Oct 2013
    Tampa
    17
    ok . Thanks.
    Quick question anyone know which wire is + or - on Image Dynamics CTX 6.5 tweeter? Found it's manual didn't say which is which.
    Attached Thumbnails Attached Thumbnails 2013 4runner 4 Channel amp install Help-img_20131106_171615.jpg
  1. 4 channel amp install HELP!#2
    By iivan in forum Amplifiers
    Last Post: 07-22-2012, 09:21 PM
  2. 4 channel amp install HELP!
    Last Post: 07-19-2012, 08:10 AM
  3. Problems Installing 4-Channel Amp, Pleas Help!
    By Mattd0344 in forum Wiring, Electrical and Installation Help
    Last Post: 10-03-2010, 07:51 PM
  4. Ghetto 4 channel amp install help!
    By memphisman00 in forum Wiring, Electrical and Installation Help
    Last Post: 09-03-2009, 09:34 PM
  5. Installing 4 channel Amp!! Need Help
    By lionel2 in forum Wiring, Electrical and Installation Help
    Last Post: 03-19-2006, 12:56 AM
