Results 1 to 5 of 5
Reload Thread: dual inline fuse holder question
    amedeuce's Avatar
    amedeuce is offline :crap:
    Jan 2004
    CA
    1,791
    3 Post(s)
    I was thinking about buying this inline fuse holder. These are the specs on it.
    · 1 - 0 Gauge Input
    · 2 - 4 Gauge Outputs
    · Dual ANL Fuses
    · Inner steps ensure perfect recessed fit of cable jacket
    into the battery terminal.
    · Wire is securely held in place with the use of allen set screws.
    · 24k gold finish on set screws
    · Use with ANL fuses 60 to 300 amps.
    Now my question is this, Can different size fuses be put in it? Like say a 150 amp going to one amp and an 80 amp going to another. Also do both sides “need” to be used?
    It should work with just one fuse and one wire in and one wire out right?
    Attached Thumbnails Attached Thumbnails dual inline fuse holder question-audiopipe-dual-anl-platinum-fuse-holder.jpg
    ramos's Avatar
    Dec 2001
    Virginia
    53
    10,329
    104 Post(s)
    Re: dual inline fuse holder question
    Yep you can use different fuse values on each side. And yep you can use just one side if you want.
    5 % equipment
    90 % install
    5% beer
    Jplaya135's Avatar
    Jplaya135 is offline Senior VIP Member
    May 2004
    orlando , Fl.
    244
    where can u get that fuse holder from?
    amedeuce's Avatar
    Jan 2004
    CA
    1,791
    3 Post(s)
    thanks ramos and jplaya I got it at darvex.com
    ramos's Avatar
    Dec 2001
    Virginia
    53
    10,329
    104 Post(s)
    Yeah man, anytime
    5 % equipment
    90 % install
    5% beer
  1. inline power fuse and amp fuse
    By cockeyed00 in forum Wiring, Electrical and Installation Help
    Last Post: 05-15-2004, 07:00 PM
  2. Noob: How do you put 4g Wire to a ANL Fuse holder?
    By aarunt1 in forum Wiring, Electrical and Installation Help
    Last Post: 04-21-2004, 03:55 PM
  3. The difference between gold and silver fuse and fuse holder
    By TheVanMan in forum Wiring, Electrical and Installation Help
    Last Post: 11-16-2003, 02:52 PM
  4. what size inline fuse?
    By phazeone in forum Subwoofers
    Last Post: 10-14-2003, 02:03 AM
