Results 1 to 9 of 9
Reload Thread: 4 speakers to one mono AMP
    SoulSearcher22's Avatar
    SoulSearcher22 is offline Junior Member
    Oct 2013
    home
    4 Post(s)
    Since my alpine died on me recently, I am trying to figure out how to wire 4 speakers into this Kicker zx1000.1 for the time being until i get a new 4 channel. I wired everything up the way I thought it would go but when I play music, the speakers woofer is the only thing i hear and feel. What am I doing wrong?
    bubbagumper6's Avatar
    bubbagumper6 is offline CarAudio.com Veteran
    Apr 2006
    The D
    11,052
    897 Post(s)
    Re: 4 speakers to one mono AMP
    Quote Originally Posted by SoulSearcher22 View Post
    That amp has a low pass filter on it that's probably not defeatable so it's filtering out the higher frequencies.
    So the short answer is, you can't use that amp to power those speakers. If you need a temporary solution connect them directly to your deck.
    Oct 2013
    home
    4 Post(s)
    alrighty, well let me ask you this question then: My alpine got some residual water on it recently. It stopped playing audio. Now, the only way the amp will turn off is if I disconnect the power or negative wires. If I take the remote out, the amp will stay on. Anything I can do here?
    basswiigee's Avatar
    basswiigee is offline CarAudio.com Veteran
    Apr 2013
    MICHIGAN
    3,337
    4 Post(s)
    1112 Post(s)
    good 'ol taco switch until it goes out completely....
    Oct 2013
    home
    4 Post(s)
    Quote Originally Posted by basswiigee View Post
    Not sure what you're getting at here...it doesn't play audio still.
    basswiigee's Avatar
    Apr 2013
    MICHIGAN
    3,337
    4 Post(s)
    1112 Post(s)
    thought it just wouldn't shut off... you could get it checked out but look at the amp... is it worth it? most amp fixs are around a hundred bucks give or take, then you got to factor shipping unless local... most of the time its just easier to buy a good used one off here... i've seen some nice amps go for cheap on here!!!
    basswiigee's Avatar
    Apr 2013
    MICHIGAN
    3,337
    4 Post(s)
    1112 Post(s)
    @timhof13 ; has some alpine amps at good prices...
    Oct 2013
    home
    4 Post(s)
    'Preciate it. Thats what i'll probably end up doing. THanks!
  9. #9
    timhof13's Avatar
    timhof13 is offline CarAudio.com Elite
    Dec 2012
    Michigan
    1,482
    13 Post(s)
    342 Post(s)
    Hit me up, I have a few amps
  1. Replies: 6
    Last Post: 09-09-2011, 03:08 AM
  2. how to hook up 2 amps, one mono amp for sub and another amp for my 4 speakers.
    By dubstep009 in forum Wiring, Electrical and Installation Help
    Last Post: 03-23-2011, 01:49 AM
  3. Safe to wire 8 subs to one Mono amp ?
    By Trevormac7 in forum Wiring, Electrical and Installation Help
    Last Post: 11-16-2009, 12:04 PM
  4. 4 speakers to jl mono amp?
    By srch4aresn in forum Amplifiers
    Last Post: 06-10-2009, 01:12 AM
  5. Can i connect subs with speakers to one amp
    By yash in forum Wiring, Electrical and Installation Help
    Last Post: 01-14-2004, 04:20 PM
