Page 2 of 2 FirstFirst 1 2
Results 16 to 22 of 22
Reload Thread: Need help with Battery comparison
  1. #16
    Dub7sonoma's Avatar
    Dub7sonoma is offline Premium Member Dub7sonoma is a Supporting Member of the forum!
    Jan 2013
    Greenwood, La
    25
    1,028
    324 Post(s)
    Re: Need help with Battery comparison
    Quote Originally Posted by Ahmed Johnson View Post
    When the amp is pulling power from the battery, does the amp see 14.4 volts or is it seeing 12 volts?
    12. Your alternator is what keeps the voltage up above 12 volts. Batteries usually rest around the mid to high 12 volt range. Once your pulling more current than your alternator puts out the voltage drops. But you still need extra batteries, even with HO alternators. Alternators dont put out max current at all times. The more amps you draw, the more they put out until they hit their max. So if you had a HO alternator with just a stock battery, and pulled more than the alternator put out, you would have a huge voltage drop. Also batteries act as a buffer for your amps. Say you hit a hard sudden bass note, your alternator wasn't puttin out much before the note an now all of a sudden it needs to put out more. The extra batteries will keep the voltage from dropping as fast and as far
  2. Thanks jkok7, Ahmed Johnson thanked for this post
    Likes jkok7 liked this post
  3. #17
    Ahmed Johnson's Avatar
    Ahmed Johnson is offline Senior VIP Member
    Jul 2013
    E-town in the burbs now.
    373
    143 Post(s)
    Quote Originally Posted by Dub7sonoma View Post
    I Appreciate the info.
  4. #18
    jkok7's Avatar
    jkok7 is offline Senior VIP Member
    Oct 2009
    Dallas, TX
    210
    43 Post(s)
    In my old car I ran my 2 battery setup in series. Just wondering should I do it differently this time. Run one power wire from the alternator to the underhood batt and another power from the alt to the trunk batt. Pretty sure the way I had it before was the best, but just checking.
    Down hur we say Grace & Ma'am. If you don't like that, you aint worth a Damm!
  5. #19
    Dub7sonoma's Avatar
    Jan 2013
    Greenwood, La
    25
    1,028
    324 Post(s)
    Quote Originally Posted by jkok7 View Post
    If you had the batteries ran in series, they would have been putting out around 24v, which would have burned everything to the ground. You had them wired parallel. Series is when you connect one positive output from one battery to the negative output of another battery and use the remaining open terminals for power and ground. As long as you did the big 3 then I would just run a power and ground wire from your front battery to the rear battery
  6. #20
    jrdnhsnbrg's Avatar
    jrdnhsnbrg is offline Pimped my grandma's ride
    Aug 2012
    Menomonie, WI
    22
    1,874
    683 Post(s)
    Do your big 3, ie 0ga from alt to pos. batt, batt neg. to chassis, and batt neg. to engine block. Then run 2 runs of 0ga from your front battery to your rear battery, one positive and one negative. Hook negative to negative and positive to positive. Fuse in all the right places and you're golden.
    2013 Ford Taurus SEL - James aka Captain Slow
    Stock... For now.
    New build log:http://mobileaudioforum.com/forum/showthread.php?8019-2013-Ford-Taurus-SEL-audio-performance
  7. Thanks jkok7 thanked for this post
  8. #21
    jkok7's Avatar
    Oct 2009
    Dallas, TX
    210
    43 Post(s)
    I meant parallel, my bad. But what you're referring to is running a wire from the + post on one batt to + post on another batt and doing the same with the - posts like jrdnhsnbrg said. Correct?
  9. #22
    Dub7sonoma's Avatar
    Jan 2013
    Greenwood, La
    25
    1,028
    324 Post(s)
    Yes do it that way
    ---------- Post added at 08:43 AM ---------- Previous post was at 08:43 AM ----------
    Yes do it that way
  1. Need help with batteries?
    By squid88 in forum Wiring, Electrical and Installation Help
    Last Post: 04-27-2009, 11:11 PM
  2. need help with battery/car trouble
    By copperhead069 in forum General Discussion
    Last Post: 01-19-2006, 09:44 AM
  3. need help with amp comparison
    By Nitroxide in forum General Discussion
    Last Post: 11-16-2005, 08:13 PM
  4. I need help with batteries
    By Xtremeon22z in forum General Discussion
    Last Post: 05-23-2005, 02:45 AM
Tags for this Thread
