Results 1 to 3 of 3
Reload Thread: 2007 Yaris Help with simple head unit after dead battery.
    Sphenoid's Avatar
    Sphenoid is offline Junior Member
    Oct 2013
    Atlanta, GA
    I replaced the head unit in my 2007 Yaris yesterday thinking "how hard could it be?" Apparently there's more to it than I thought. There's nothing fancy in my car, no subwoofer or anything other than the new head unit. I bought the correct wiring harness and used butt connectors to connect like wires to like wires and everything worked great. This morning I go to get in the car to go to work and the battery is dead.
    When I hooked up the harnesses, there were 2 wires on the Metra harness that did not have corresponding wires on the Pioneer harness. Blue for power antenna (my car doesn't have a power antenna), and Orange/White for dimmer (ceiling light seemed to be working as normal as it was dark by the time I was done). On those wires I went ahead and crimped a butt connector onto them so there would be no exposed copper. The factory radio also had 3 plugs going to the back of it where the Metra harness only has 2 so I've got a free plug hanging out in the dash. I'm sure it's something simple but this is my first self-install so I'm obviously missing it. Any help would be greatly appreciated.
    winkychevelle's Avatar
    winkychevelle is offline CarAudio.com Veteran
    Jun 2009
    Ponchatoula, La
    26
    3,431
    769 Post(s)
    Re: 2007 Yaris Help with simple head unit after dead battery.
    May have just killed the battery while installing it. Other wise make sure the red wire on the harness only gets power while the key is on. The dimmer and power antenna wires can be capped off. I never use the dimmer it sometimes causes weird problems
    2014 Chevrolet Cruze Diesel
    2013 Chevrolet Silverado 3500HD 4x4
    Pioneer touch screen with front and rear cam, will add
    A kingpin camera and a trailer rear cam soon
    Memphis viv component run active
    Kicker cx1200.1
    Kicker cx 300.4
    2 jl 13tw5-3 wired to 1.5ohm at about 1000rms
    ****** box that needs to be replaced soon
    Sphenoid's Avatar
    Oct 2013
    Atlanta, GA
    Cool, thanks. I'll jump it tonight and take it to the auto parts store to get the battery tested since it's about 5 years old. Some more googling found that that extra cable I have is not necessary so that shouldn't be the problem.
  1. help with Eclipse head unit
    By fastaccord in forum Head Units
    Last Post: 05-20-2005, 01:52 PM
  2. I need help with Apline Head unit
    By tasmisr in forum Wiring, Electrical and Installation Help
    Last Post: 04-05-2004, 12:02 AM
  3. I need help with a Head unit problem
    By 99ws6 in forum Wiring, Electrical and Installation Help
    Last Post: 01-29-2004, 12:19 AM
  4. Help With Volvo Head Unit install.
    By PretecSH in forum Wiring, Electrical and Installation Help
    Last Post: 01-18-2004, 08:53 PM
  5. Need some help with pioneer head unit
    By Unregistered in forum Wiring, Electrical and Installation Help
    Last Post: 02-10-2002, 09:10 AM
