Results 1 to 2 of 2
Reload Thread: jl audio amp wiring question?
    cockeyed00's Avatar
    cockeyed00 is offline Senior VIP Member
    Jan 2003
    Antioch, CA
    272
    I am gonna be doing an install in my truck that consists of: jl audio 500/1 and a
    jl audio 300/4. The 500/1 will be pushing 2 old 10w6s(300rms @ 1.5 ohms). The 300/4 will be pushing (4) db6500 components(100rms @ 4 ohms) My question is, do I need to run 4 ga. to boh amps, or can I run 4 ga. to the 500 and 8 ga. to the 300?
    thanks
    What else will be needed for this install(cap(s), alternator rewound, etc ?
    HEY LOOK, you dropped your pocket....
    tomhanaway's Avatar
    tomhanaway is offline Junior Member
    Mar 2004
    BoyntonBeach, FL
    13
    Re: jl audio amp wiring question?
    I just did this install with a jl aud 500/1 and 450/4 and walmart dual 4 gauge kit. The splitter connects the 4 gauge to two 8 gauges when you finish the powerline run from the battery to the amps. So my power run of actual 8 gauge is only about 8 " to the 500/1 and 2 feet to the 450/4. I also bought a second splitter so I could run both grounds out from the amps (8 ga) to one common 4 gauge which went to the B pillar driver's side screw next to the seat. Grounded HU to same point.
    Seems to work fine. No capacitor or alternator mods necessary.
    Tom H.
  1. amp question
    By scono in forum Amplifiers
    Last Post: 03-11-2004, 05:44 AM
  2. Wiring Help with Planet Audio Amp
    By scottrc5391 in forum Wiring, Electrical and Installation Help
    Last Post: 01-05-2004, 10:57 PM
  3. strangest wiring problem ever, PLEASE HELP!!! (thanks!)
    By dragonplayboy in forum Wiring, Electrical and Installation Help
    Last Post: 12-21-2003, 04:51 PM
  4. Amp wiring question
    By Dookie in forum Amplifiers
    Last Post: 11-13-2003, 10:36 PM
