Results 1 to 2 of 2
Reload Thread: Distribution block wiring.
    Driv3's Avatar
    Driv3 is offline Member
    Mar 2013
    Pittsburgh, PA
    59
    12 Post(s)
    Finally got around to purchasing a second amp and tomorrow I'm looking to install it. Right now I got 4 awg cca on my power and ground to my sub amp
    (soundstream rubicon 1.1000d,
    4 ohms: 600 watts x 1 chan.
    2 ohms: 800 watts x 1 chan.
    1 ohm: 1000 watts x 1 chan.)
    Now im adding an autotek mean machine (not the new one but this one
    Autotek MM4-400-RB (LS-mm4400-RB) Factory Refurbished, 800W RMS
    4 ohms: 100 watts x 4 chan.
    2 ohms: 200 watts x 4 chan)
    So i bought all the components, got all the wire, but i am not sure about sizing. Can i keep the 4 awg power and have 2, 8 awgs on these 2 amps? i know the autotek will be fine but the rub? the only larger wire i have is 0/2 awg and i would use that have i had a large enough anl fuse holder. Can i just use an 8 awg to the auto tek and and a 4 awg to the rub or is that just redundant. btw here's the distribution block.
    Lightning Audio 0 1 4 Gauge Input to 2 8 AWG Output Fused Distribution Block | eBay
    Pittsburgh, PA.
    May your subs have wubs and you amps run cool. - Copernicus
    audiobaun's Avatar
    audiobaun is offline CarAudio.com Veteran
    Jun 2011
    Tx
    9,238
    25 Post(s)
    2150 Post(s)
    Re: Distribution block wiring.
    Looks to me, you bought the wrong sized Distro block.This would have been a better choice in my opinion
    Kicker Fused Distribution Block Fdbma New Free Shipping | eBay
    2)American Bass VFL Mini Hybrid [email protected] Ea 4)American Bass XFL DVC 4ohm [email protected] Ft [email protected] CDT 6,5 HD6 Briax.,CDT CL60,CDT 25 tweets,Kicker KS25 tweets Autotek Mean Machine [email protected],Autotek BTX [email protected] AlterStarts Alt 255A/Dallas,Tx,2)Orileys Super Start AGM batts(1more coming)Cadence CCA 0ga on Big 6,AudioTechnix 0ga CCA Kicker Kq9 Eq,Eclipse CD3000(lookingfor upgrade)StingerPro Distro,3)XS Scorpian 8in Scroll Fans 1998 3dr Xcab Chevy(under construction,but operational)
  1. Distribution block wiring question
    By CanadianDream in forum Wiring, Electrical and Installation Help
    Last Post: 11-24-2007, 01:46 PM
  2. Wiring a fused distribution block help
    By alphakenny1 in forum Wiring, Electrical and Installation Help
    Last Post: 10-18-2005, 12:39 AM
  3. tell me if i have this right: wiring set up, fuses, distribution block, etc.
    By billybrown66 in forum Wiring, Electrical and Installation Help
    Last Post: 07-16-2005, 11:52 PM
