Results 1 to 7 of 7
Reload Thread: 2 subwoofers wired to 1 channel
    xXnavyseal2Xx's Avatar
    xXnavyseal2Xx is offline Junior Member
    Sep 2013
    Chicago, IL
    5 Post(s)
    Is it possible to have a 5 channel amp, wire 4 coaxial, and wire 2 subwoofers to the 1 remaining 1 channel? Do I need a 6 channel amp? Also if possible can someone lead me to a visual diagram if possible?
    Thanks,
    Have a nice day
    Side Show's Avatar
    Side Show is offline Bringin The Noise
    Aug 2007
    Australia
    3,337
    457 Post(s)
    Re: 2 subwoofers wired to 1 channel
    what type of subs and impedance are they? depends on the amp and subs. don't see it being a problem
    Sep 2013
    Chicago, IL
    5 Post(s)
    Hoping to get the Pyle BLADE 6800 Watts 5 Channel Compact Class-D Full Range Hybrid Amplifier but I don't know if that's even a good amplifier. I want sound quality in my system but don't know what speakers subwoofers or amplifier to buy. I know that I want 2 subwoofers and 4 coaxial and the impedance should be 4 ohms and if wired down it should be 2 ohms.
    Thanks,
    Have a nice day
    Milk Mayne's Avatar
    Milk Mayne is offline Doing 160
    Jan 2013
    The Triad, NC
    30
    235
    83 Post(s)
    If you want sound quality, go with components over coaxials. Build your own (or have one built) box for your subwoofers. Use ANYTHING besides that Pyleofchit amp. For the two subs, you can run them off a mono amplifier (or sub channel on a five channel), as long as they're wired correctly. If your amp is only four ohm stable, get two dvc four ohm subs and wire in series. If two ohm stable, two dvc two ohm subs wired in series. If you don't know how to do something as simple as that, I'd suggest taking your vehicle to someone who does as far as installation is concerned.
    And for future reference, you're not going to get "3000 rms watts OF SUPA POWA!!!" For $150. Just spend some time READING AND SEARCHING the forums, most questions you're going to ask have already been answered. Check out the audio 101 stuff.
    Slo_Ride's Avatar
    Slo_Ride is offline Take It Easy
    Oct 2005
    SC
    12,805
    33 Post(s)
    3015 Post(s)
    Refs = PapaGeno21, Goindef154, 92c1v1c, Disarmer, chemmins, 97maxima, kroid777, ithertz, basscort2009, hunterw, mar08052, appleyard, millimac247, jonny101abc, sundownz, cranberryyumyum, mig139, daboyfrumdabx, skateguy92, basebalz13.
    Side Show's Avatar
    Aug 2007
    Australia
    3,337
    457 Post(s)
    yep, stay away from cheapo ebay amps ect..... splits at the front, & coax in the rear.... nice 5 channel amp will do the job
    vector's Avatar
    vector is offline Member
    Aug 2011
    Colorado
    43
    3 Post(s)
    You can find some 4 channel amps on craigslist for dirt cheap. I've bought quite a few quality 4 channel amps for less than 60 bucks on craigslist. Then just get a decent quality mono amp from the classifieds here or amazon/sonic/carstereoonline/craigslist in your price and power range. You will be much much happier with your system going this route. Everyone I've ever known that has used a 5 channel amp has eventually replaced it with a mono block for the subs. Don't buy Pyle you will regret it! It is literally wasting your money as you will replace it sooner than later.
    That being said this is a ridiculously good deal near you, and if you buy a 2 ohm/dual 4 sub would be perfect.
    Kicker ZX700.5 Five channel amp
    or one of these
    Eclipse amplifier
    Zapco 500.1 amp trade or sell
    and then offer this guy 50 bucks
    Old school Rockford Fosgate amp
    If they let you test these and everything works well you will be way better off than that pyle pos.
  1. Subwoofer wiring to amp
    By Tiger Bass in forum Wiring, Electrical and Installation Help
    Last Post: 09-18-2007, 02:22 AM
  2. wiring 2 channel amp to 1 sub
    By shortys408 in forum Amplifiers
    Last Post: 05-08-2005, 12:41 PM
  3. how to wire 4 channels amp to high?
    By geo in forum Wiring, Electrical and Installation Help
    Last Post: 10-08-2003, 09:56 AM
  4. Subwoofer Wiring to Amp
    By mpsilkk376 in forum Wiring, Electrical and Installation Help
    Last Post: 03-01-2003, 05:09 PM
  5. wiring (4) subwoofers into one channel
    By leemo in forum Wiring, Electrical and Installation Help
    Last Post: 05-28-2002, 07:20 PM
