Results 1 to 13 of 13
Reload Thread: 250 amp fuse turned a strange color in the center....
    treiber67's Avatar
    treiber67 is offline Senior VIP Member
    Dec 2012
    ft.lauderdale fl
    156
    28 Post(s)
    I only have what I have for now but I have second online fuse connected in the back of my truck for my kicker Kx1200.1 why would it have turned. Different color in the center. I'm running acc 4ga wire from amp to fuse to my third battery.
    Boomsday's Avatar
    Boomsday is offline CarAudio.com Veteran
    Apr 2010
    My House
    3,885
    62 Post(s)
    785 Post(s)
    Re: 250 amp fuse turned a strange color in the center....
    If its like a purple to black color, its about to blow or is partially blown
  3. Thanks treiber67 thanked for this post
  4. #3
    basswiigee's Avatar
    basswiigee is offline CarAudio.com Veteran
    Apr 2013
    MICHIGAN
    3,337
    4 Post(s)
    1112 Post(s)
    if its yellowish or white/cloudy moisture
  5. Thanks treiber67 thanked for this post
  6. #4
    treiber67's Avatar
    Dec 2012
    ft.lauderdale fl
    156
    28 Post(s)
    Perfect that's the case boomsday, just got the package of new ones from eBay. It's prolly running so much current through that garbage copper allum wire that I got. Thank you for the answers. Just curious when running two mono amps does the polarity always have to be flipped on the slave amp? Granted the subs are in phase when checked with a 9v but from prior experiences I still had to flip one of the wires around. Voice coils start to smell when I turn them up and gain is tuned perfectly with my 5v pre outs. The subs that are smelling are my orions I think there the old school hccas with the gray and black basket.
  7. #5
    Side Show's Avatar
    Side Show is offline Bringin The Noise
    Aug 2007
    Australia
    3,337
    457 Post(s)
    ......... so when the fuse goes to an annodised/black color, does that mean the fuse is about to blow? and does it restrict pwr when it's like this?
    do you have two kx1200.1's strapped? (only stable to 2 ohm I think) also my 1200.1 is still going strong
  8. #6
    treiber67's Avatar
    Dec 2012
    ft.lauderdale fl
    156
    28 Post(s)
    That's what was happening its almost like the subs were cutting out when they were dropping on lows, but after tonight putting in the new 250 its in working order except after a full song at 75% they start stinking.
  9. #7
    treiber67's Avatar
    Dec 2012
    ft.lauderdale fl
    156
    28 Post(s)
    Unfortunately I don't have two Kx's, I'm running a hifonics glx1400.1. It's loud but I hate even showing people. Just on a budget lately....better than no bass.
  10. #8
    Side Show's Avatar
    Aug 2007
    Australia
    3,337
    457 Post(s)
    hope you havnt tried to strap those different amps together..........
  11. #9
    treiber67's Avatar
    Dec 2012
    ft.lauderdale fl
    156
    28 Post(s)
    No lol
  12. #10
    Side Show's Avatar
    Aug 2007
    Australia
    3,337
    457 Post(s)
    hehehe sweet.... what are the internals like? might be worth getting a Perspex cover for it
  13. #11
    treiber67's Avatar
    Dec 2012
    ft.lauderdale fl
    156
    28 Post(s)
    Maybe if I had two Kx12's but I'm sure the internals of the glx is nothing like the kx. Plus sonic is **** about the seal being broken just in case I would need a warranty replacement.
    ---------- Post added at 10:48 PM ---------- Previous post was at 10:47 PM ----------
    My a.n.a.l. just got ******ed out.
  14. #12
    Side Show's Avatar
    Aug 2007
    Australia
    3,337
    457 Post(s)
    the kx internals are actually pretty ugly, (glue dollips everyware) but if you have warrenty, you doint want to void that
  15. #13
    bbeljefe's Avatar
    bbeljefe is offline CarAudio.com Elite
    Jul 2013
    Shreveport, LA
    1,800
    2 Post(s)
    679 Post(s)
    Can you clarify a few things?
    Are you running two 1000+ watt amps on one run of 4 gauge CCA fused at 250 amps?
    Are you running multiple brands of subs?
    If so, are they in the same air space?
    When you say gains are set perfectly, how did you go about setting them and did you verify head unit clipping level before setting them?
    Owner, Audio Anarchy, LLC
    2915 Youree Drive, Shreveport, LA
    318-780-6149
    https://www.facebook.com/AudioAnarchyLLC
  1. 100 amp vs 250 amp fuses
    By Black Truck 10 in forum Wiring, Electrical and Installation Help
    Last Post: 09-11-2008, 08:17 PM
  2. OK to use two 250 amp fuses as one 500?
    By JoeSmith502 in forum Wiring, Electrical and Installation Help
    Last Post: 05-14-2008, 12:00 AM
  3. WTB: 1/0 ANL Fuse Holder + 250 amp Fuse + Battery + Deadener + Alarm
    By theothermike in forum Wanting to Buy (WTB) - Car Audio
    Last Post: 01-14-2007, 02:58 PM
