Results 1 to 15 of 15
Reload Thread: good system?
    Off_Roader33's Avatar
    Off_Roader33 is offline Junior Member
    Aug 2013
    Upstate South Carloina
    2 Post(s)
    good system?
    im putting a system in my truck and was wanting to know if it was a good choice of componets with a budget of about $550. Here's what i'm looking at:
    head unit:Pioneer DEHX7500S
    amp:Crunch P1-1650.4n 200wx4channels 4ohm
    door speakers: Four Kicker 40CS684 6"x8" 225w max, RMS: 75w 4ohm
    subs: Two Kicker 10C104 Comp 10-Inch Subwoofer 4 Ohm 150w rms 300w max each 4ohm
    on most websites they say the amp is 250x4 4 ohm but crunch's website says its 200x4 4 ohm
    I planned on wiring the subs to a channel each and having the 6x8s 4 on 2 channels
    HELP!!!!
    Jeffdachef's Avatar
    Jeffdachef is online now Gunz That Turn on Nunz
    Feb 2013
    South Coast Metro, CA
    15,088
    217 Post(s)
    7247 Post(s)
    Re: good system?
    would not do the crunch amp, they are borderline boss audio, a buddy of mines added a crunch amp to his bose system and it was only 10% louder than his head unit volume, very weak and amp with bloated power ratings. Your also going to want to look for continuous RMS power, crunch only lists maximum power which is the rating they see before they explode. Realistically they'd probably put out 30 watts rms and i'm being very generous.
    What i would do for your system is to only get your head unit and a good set of compenents for your front speakers, buy this amp Precision Power PPI P900.4 (p9004) 4-Channel Phantom Car Amplifier wire the front speakers to two channels on the amp and use the other two channels for the kicker subs. Let your rear speakers be powered by the head unit, its the least important part of your system really, you can upgrade that anytime later. Focus on your front and subs and never skimp out on the amp.
    your also going to need to fit in wiring kit, sub box and rcas in your budget.
    09 Sienna Subs : Four Team Ascendant 18s......Sub amp: Two Taramps 15k
    Headunit: Pioneer 80PRS................................Mids/Highs amp: CT 500.2, ppi 600.2, ppi 900.4 bridged
    Front stage: Two PWX 10s per door midbass only....... PRV 6MR500 midrange....... Massive CT 2 german tweeters.
    320 amp Singer alt....... 1 group 34 under the hood 6 group31 agms in the back 560 amp hours total.
    naughtyca's Avatar
    naughtyca is offline CarAudio.com Veteran
    Feb 2012
    Tampa FL
    2,105
    803 Post(s)
    Re: good system?
    head unit head unit:Pioneer DEHX7500S $100
    sub amp apsm 1500 $125
    door speakers: Four Kicker 40CS684 6"x8" 225w max, RMS: 75w 4ohm $140
    american bass tnt $135 eash
    DoesDad's Avatar
    DoesDad is offline CarAudio.com Veteran
    Dec 2011
    Tulsa, OK
    2,342
    675 Post(s)
    Re: good system?
    I don't mind the headunit, the speakers for the subs. The amps gotta go... People are going to bash on the Kicker Comps as well. And while there's better subs out there, I think the Kickers are still great budget subs and can sound great.
    Aug 2013
    2 Post(s)
    Re: good system?
    I already know what box im getting. what about a Lanzar MNX460 amp? and how over powerd should my speakers and subs be?
    garychoffmann's Avatar
    garychoffmann is online now CarAudio.com Elite
    Mar 2011
    Missouri
    1,905
    6 Post(s)
    507 Post(s)
    Re: good system?
    Stay away from the lanzar. Whats your serious budget? We'll find you an amp
    SounDrive's Avatar
    SounDrive is online now www.soundrive.audio SounDrive is a Supporting Member of the forum!
    SounDrive is a Supporting Vendor of the forum!
    Apr 2013
    Lebanon, TN
    3,072
    20 Post(s)
    1347 Post(s)
    Re: good system?
    Quote Originally Posted by Off_Roader33 View Post
    What kind of box? If it's pre fabricated, stay away from it (unless it's a sealed box)
    You'll get a lot more output from a ported box, but you'll need a properly designed one.
    For $550 you can get a decent system with two tens.
    Subs:
    Audiotechnix Stratos - D2 if you get 2, D4 if you get one - $80 shipped for a 10, can get a 12 or 15 if you have the space - Audio Technix BLOWOUT SALE!!
    Amp:
    PPI 900.5 - $229 - this will power the subs and door speakers Precision Power PPI P900.5 (p9005) 5-Channel Phantom Car Amplifier
    Head unit:
    The one you listed is fine, just make sure you have at least 2 sets of preouts but 3 sets is better.
    Speakers:
    Incriminator I65 components or coaxials - just get some adapters to fit 6.5s in your 6x8 locations. These are around $100 per set of two
    Owner, SounDrive Audio
    Visit our store at www.soundrive.audio
    Like us on Facebook at www.facebook.com/soundriveAudio
    PLEASE EMAIL ME FOR FASTER RESPONSES - [email protected]
    Dealer for: SounDrive Audio | Synergy Audio | Audio Legion | XS Power | Mechman | SPL-Lab | Taramps | Limitless Lithium | Wolfram Audio | Singer Alternators | Ampere Vibraflex
    Aug 2013
    2 Post(s)
    Re: good system?
    if I had two 6x8 kickers and some cheap 6x8s for the back doors to run to the headunit id pay MAX 200 for the amp. I don't want anything spiecal just a good sounding system that has bass if I truned it up
  9. #9
    SounDrive's Avatar
    Apr 2013
    Lebanon, TN
    3,072
    20 Post(s)
    1347 Post(s)
    Re: good system?
    The amp I linked will power your door speakers and subs both. I think with a properly built ported enclosure, you'd really be surprised with the bass output of a single 12 or even a 10. That would leave you a decent amount of money in your budget for the head unit and speakers (and buying an enclosure/design from a professional)
  10. #10
    Aug 2013
    2 Post(s)
    Re: good system?
    would it be fine that the subs are under powered? they are 150w rms, 300w rms pair and the amp is 270w rms sub channel
  11. #11
    Jeffdachef's Avatar
    Feb 2013
    15,088
    217 Post(s)
    7247 Post(s)
    Re: good system?
    it would be fine since it doesnt take much to get those subs moving but you can run it at 2 ohms on the 5 channel ppi amp tenacious listed and you'll have 440 rms to play with. Get the D2s and wire it in series. that amp should have more then enough power to cover future speaker upgrades if you ever want any. hell maybe in the future you might get a dedicated sub amp and use that additional sub channel on the ppi to power some midbass speakers too.
  12. #12
    Aug 2013
    2 Post(s)
    Re: good system?
    okay... thanks yall big help
  13. #13
    mclerico83's Avatar
    mclerico83 is offline CarAudio.com Veteran
    Oct 2009
    tampa
    7,649
    4 Post(s)
    1032 Post(s)
    Re: good system?
    those comp speakers are garbage so much better can be had for the price
  14. #14
    mclerico83's Avatar
    Oct 2009
    tampa
    7,649
    4 Post(s)
    1032 Post(s)
    Re: good system?
    Boston Acoustics G110PD 800W 10" Gtuned Series Loaded Subwoofer Enclosure 690283379988 | eBay
    you would be better suited with a system like this with a custom tuned box from ba if you want to go cheap
    http://www.ebay.com/itm/Cadence-FXA5...a8d895&vxp=mtr
    and be done
  15. #15
    Jeffdachef's Avatar
    Feb 2013
    15,088
    217 Post(s)
    7247 Post(s)
    Re: good system?
    Quote Originally Posted by mclerico83 View Post
    Cadence FXA5000 5 2000 Watt 5 Channel Class A B Car Audio Amplifier Amp Remote | eBay
    and be done
    OP, Thats a much better deal then 2 kicker comps because your getting the box and better sounding subs., would work well with the 5 channel amp
  1. Good System?
    By SuperChunk in forum Subwoofers
    Last Post: 06-18-2002, 01:47 PM
  2. Good system?
    By Billyf17 in forum Subwoofers
    Last Post: 06-11-2002, 11:47 AM
  3. Good System for my van
    By astro89 in forum General Discussion
    Last Post: 05-19-2002, 02:41 AM
  4. Is this good system for xterra
    By Unregistered in forum Wiring, Electrical and Installation Help
    Last Post: 04-19-2002, 03:04 PM
  5. good system for acura
    Last Post: 03-19-2002, 05:41 PM
Tags for this Thread
