Page 2 of 2 FirstFirst 1 2
Results 16 to 19 of 19
Reload Thread: Tapping into a remote on wire
  1. #16
    keep_hope_alive's Avatar
    keep_hope_alive is offline Acoustics Engineer keep_hope_alive is a Supporting Member of the forum!
    May 2007
    Quad Cities, IL
    7,078
    28
    47 Post(s)
    1500 Post(s)
    Re: Tapping into a remote on wire
    using a relay is a good idea.
    do you know how?
    got a question? shoot me a PM. Matthew 6:9-15 - YouTube Channel: https://www.youtube.com/channel/UCkYUo2EShW9lgtrfXiDvLNQ/videos
    2014 Accord build log: http://www.caraudio.com/forums/car-audio-build-logs-cars-trucks-suvs/608637-2014-accord-sport-sq-build-keep_hope_alive.html
    2001 Accord build log: http://www.caraudio.com/forums/car-audio-build-logs-cars-trucks-suvs/536049-2001-accord-ex-sedan-its-long.html
    Fix Photobucket Image Loading ------> https://addons.mozilla.org/en-US/firefox/addon/photobucket-fix/ <------
  2. #17
    bbeljefe's Avatar
    bbeljefe is offline CarAudio.com Elite
    Jul 2013
    Shreveport, LA
    1,800
    2 Post(s)
    679 Post(s)
    Quote Originally Posted by Dozers View Post
    I guess the question goes back to..Do you think the Enable brown wire in the diagram is an "OEM turn on wire"?
    If it is then are you saying....enable wire to relay - relay back to OEM amp and relay out to processor. From processor remote out to new JL Amps remote turn on?
    If the brown wire is a 12V signal for turn on then yes, that is correct. If it isn't, then one of the smart line out converters would be then sensible thing.
  3. #18
    Dozers's Avatar
    Dozers is offline Junior Member
    Aug 2013
    Mississippi
    1 Post(s)
    Apologies to both of you I was not able to get to page 2 of this thread until today...first time thats happened.
    Quote Originally Posted by keep_hope_alive View Post
    do you know how?
    Yes I do.
    Thanks
    Quote Originally Posted by bbeljefe View Post
    Okay. Thanks
  4. #19
    MutantDreams's Avatar
    MutantDreams is offline Senior VIP Member
    Apr 2012
    Columbus, Georgia
    261
    64 Post(s)
    Why not tie into the ignition harness? You can run it off the acc wire.
  5. #20
    Dozers's Avatar
    Aug 2013
    Mississippi
    1 Post(s)
    Quote Originally Posted by MutantDreams View Post
    Mostly for simplicity. I have to tap into the line outs from the amp anyway and the plug is just under the dash to the left of the steering column. I'm using a 9 wire cable anyway so I figured if i have the ninth wire there use it As a remote on for the processor. Then the amp can remote on from the processor ( those Ive looked at have that option).
  1. why woudl you tap into the deck power wire??
    By 94civik in forum Head Units
    Last Post: 05-01-2008, 11:42 AM
  2. Tap into 12V for Remote Wire? HELP ME
    By DaBurner in forum Wiring, Electrical and Installation Help
    Last Post: 01-10-2007, 10:21 PM
  3. Remote turn on Wire
    By namster44 in forum Amplifiers
    Last Post: 06-26-2003, 10:21 AM
  4. Dead remote turn on wire.
    By jONnyBOi83 in forum Wiring, Electrical and Installation Help
    Last Post: 11-17-2002, 02:44 AM
  5. Tapping Line output convertor into rear BOSE sub wires in '95 Camaro...
    By JeremyBlackwell in forum Wiring, Electrical and Installation Help
    Last Post: 11-10-2002, 09:33 PM
