Page 3 of 3 FirstFirst 1 2 3
Results 31 to 45 of 45
Reload Thread: System keeps killing my battery.. need some advice.. PLEASE!
  1. #31
    EGordon_'s Avatar
    EGordon_ is offline Junior Member
    Jul 2013
    United States
    22
    18
    12 Post(s)
    Re: System keeps killing my battery.. need some advice.. PLEASE!
    Quote Originally Posted by audiobaun View Post
    Pretty normal setting/resting voltage..Look into getting that BIG3 done on your current battery before you replace it,may be just fine,may not.If not, replace the batt for the agm, with that big3 done, and be sure to turn everything off before you shut the vehicle down, and you should be just fine.Read up/you tube the BIG3.it will help your voltage regulation/needs compared that of STOCK..Turn that switch off before shutting down also.
    Is the Big 3 extremely simple or would it be beneficial to have it done by my mechanic when he just swaps batteries? As I said, I'm not the most knowledgeable guy with cars. Thank you so much for your help so far
  2. #32
    audiobaun's Avatar
    audiobaun is offline CarAudio.com Veteran
    Jun 2011
    Tx
    9,316
    27 Post(s)
    2169 Post(s)
    Quote Originally Posted by EGordon_ View Post
    That's a good idea, and most likely my best bet. Should I have my mechanic do that, or bring it to an audio store? I don't want to risk doing myself as I would probably only mess it up further and complicate things
    You can do it yourself,or with help.Ask questions, or even research for yourself to save some money.Amp supply from batt ,ground wire,rcas,and remote wire to hu, and wires to speakers..Sounds simple,to some it is not.You can go to 12v.com, and look at wiring diagrams for easy /simple installation process.You can run the wiring yourself,and learn as well,rather than shelling out Hundreds of $$$$s on installing basics.But that is up to you if you are uncertain on how to do.There may be someone cl;ose to youn that could help that is on this Forum as well.You could run a Help thread for your location,fore an experienced Forum member to help you out
  3. #33
    audiobaun's Avatar
    Jun 2011
    Tx
    9,316
    27 Post(s)
    2169 Post(s)
    Car Audio 101 - The Big 3 Upgrade Tutorial - YouTube
    ---------- Post added at 01:07 PM ---------- Previous post was at 01:07 PM ----------
    Fairly simple
  4. #34
    EGordon_'s Avatar
    Jul 2013
    United States
    22
    18
    12 Post(s)
    Awesome. Thank you so much man, I really appreciate all your help! I'll see if I can find a buddy that doesn't mind doin it for me
  5. #35
    audiobaun's Avatar
    Jun 2011
    Tx
    9,316
    27 Post(s)
    2169 Post(s)
    A good respectable/honest mechanic,should be able to do your Big 3 in 15 min while replacing the battery,as long as he has the wiring ready.You can buy a BIG 3 kit on this forum pretty reasonably price3d/shipped, ready to install..and can be removed/transfered from vehicle to vehicle,as long as the wiring is still good/in most cases,they are,so its not a ONE time buy for just that vehicle,you should be able to reuse on most if the wiring is long enough,,,,so money is well spent on this upgrade for any vehicle.I believe @mylows10 has kits available ready to be installed, and possibly others on this forum
    ---------- Post added at 01:16 PM ---------- Previous post was at 01:16 PM ----------
    Its just 3 wires,Thats it
  6. Thanks EGordon_ thanked for this post
    Likes EGordon_ liked this post
  7. #36
    Jes 42's Avatar
    Jes 42 is offline DeezNtzz
    Aug 2012
    Ohio
    2,383
    4 Post(s)
    709 Post(s)
    I would remove the amp, and wire everything properly,so there are no surprises,and that you know exactly where all your wires are at.Sure its a PITA,but Assuring,and most effective,and most of all...DONE RIGHT/PROPERLY+
    This ^^^^
    Pioneer 880PRS
    4 PRV 6.5's 4 Bazooka Euphonic os tweets
    Kicker KX850.4
    2 Incriminator Death Penalty 18's
    American Bass VFL450.1
    300 amp Ohio Gen alt
    4 Deka Intimidator's in back.C&D 77ah up front.
    Lotta 1/0 welding wire
  8. Thanks audiobaun thanked for this post
  9. #37
    EGordon_'s Avatar
    Jul 2013
    United States
    22
    18
    12 Post(s)
  10. #38
    audiobaun's Avatar
    Jun 2011
    Tx
    9,316
    27 Post(s)
    2169 Post(s)
    wire amp kits and big 3 kits for sale
    Id go with 0ga kit,for money well spent
  11. #39
    des343's Avatar
    des343 is offline CarAudio.com Elite
    Feb 2011
    Kalamazoo, MI
    994
    436 Post(s)
    Alright sweet, thank you! I will def look into it. The guy I bought it from actually installed a switch right near the steering wheel to turn the amp on/off for the purpose of killing the subs quickly around cops..etc. I don't know why I didn't realize it but could that possibly be the problem? The amp is still draining the battery after the car is off?
    This is your problem I bet he rigged the switch to the remote wire so basically I bet your amp is staying on thus draingig your battery I have two optima batts and I had my amp rigged directly to the battery one time as a temporary solvant to an issue I was having but if I forgot to pull it when the car was off id come out of workn and both my batts would be shot.
    I say to fix your problem you should just re-run the remote wire properly
  12. #40
    cbuts's Avatar
    cbuts is offline CarAudio.com Elite
    Sep 2011
    canada,ont
    837
    177 Post(s)
    Do the big 3 yourself, youtube "how to big 3 upgrade" its very simple..and make sure you go with 0 awg.
    2006 Chevrolet Malibu 3.5l V6
    JVC KD-R620
    RE Audio XXX 6.5 components (front)
    Hifonics ZRX500.2 500W 2-Channel Class A/B Amplifier
    2 Sundown Audio 12s
    Rockford fosgate 15001bd Mono Amp
    Big 3 Upgrade
    Cadence 0 AWG Wiring Kit
    Singer 275A Alternator
    Optima Red Top under hood
  13. #41
    EGordon_'s Avatar
    Jul 2013
    United States
    22
    18
    12 Post(s)
    Quote Originally Posted by des343 View Post
    Yeah I was just texting the guy and he said that If the switch is left on, the amp will remain on and draining the battery even if car is off. So if I get a slightly higher powered battery and ensure to flip the switch off every time.. or just redo all the wiring.. it should take care of the problems correct?
  14. #42
    EGordon_'s Avatar
    Jul 2013
    United States
    22
    18
    12 Post(s)
    Alright cool, will do. What is the min. powered battery I should purchase/exchange for?
  15. #43
    Jes 42's Avatar
    Aug 2012
    Ohio
    2,383
    4 Post(s)
    709 Post(s)
    Just traded my 04 Mustang 3.8L off not too long ago and the big 3 is very simple to do on those.Just do that and do away with the switch and rerun your remote wire.Doubt you'll have any problems with it then.Good luck.
    Pioneer 880PRS
    Kicker KX850.4
  16. Thanks EGordon_, audiobaun thanked for this post
    Likes EGordon_, audiobaun liked this post
  17. #44
    EGordon_'s Avatar
    Jul 2013
    United States
    22
    18
    12 Post(s)
    Quote Originally Posted by Jes 42 View Post
    Alright sweet. Thank you for the help!
  18. #45
    Jes 42's Avatar
    Aug 2012
    Ohio
    2,383
    4 Post(s)
    709 Post(s)
    Not a problem.You'll see how easy it is when you get into it.Any questions just shoot me a pm.Mustangs are pretty easy to work on.
    Pioneer 880PRS
    Kicker KX850.4
  19. Likes audiobaun liked this post
  1. almost done with my box, need some advice
    By derek33 in forum Enclosure Design & Construction Help
    Last Post: 02-19-2005, 10:51 AM
  2. Etronics and my cm3...need some advice.
    By Strecker25 in forum Subwoofers
    Last Post: 05-03-2004, 11:13 PM
  3. decided to port my box, need some advice
    By substance in forum Enclosure Design & Construction Help
    Last Post: 04-04-2003, 10:44 AM
  4. need some advice please
    By slickrick in forum Subwoofers
    Last Post: 02-06-2002, 11:02 PM
Tags for this Thread
