Page 6 of 7 FirstFirst 1 2 3 4 5 6 7 LastLast
Results 76 to 90 of 105
Reload Thread: Battery - Alternator HELP
  1. #76
    NASTY08IMPALA's Avatar
    NASTY08IMPALA is offline CarAudio.com Veteran
    Aug 2012
    LOUISVILLE, KENTUCKY
    6,131
    3 Post(s)
    2554 Post(s)
    Re: Battery - Alternator HELP
    Quote Originally Posted by profundus-sanus View Post
    pcm regulation will not cause your battery light to come on when your using a stock plug. It will not cause your voltage to die at idle but be fine at cruising speed.
    Your on the right track but your missing some key symptoms.
    On several gm vehicles if you just trick the light sensor to keep the lights on all the time it'll keep you above 14.0v and wont throw a charging system error code, which some vehicles do if you bypass pcm regulation.
    im not saying.that the pulley doesnt need.to be changed im saying.he will still have the pcm symptoms once he gets it straigtened out
  2. #77
    profundus-sanus's Avatar
    profundus-sanus is offline CarAudio.com Veteran
    Dec 2006
    wilmington, NC
    31
    2,970
    22 Post(s)
    Quote Originally Posted by NASTY08IMPALA View Post
    i don't think anyone is arguing that pcm regulation type symptoms wont occur.
    I think we're all on the same page though, now.
  3. #78
    cbuts's Avatar
    cbuts is offline CarAudio.com Elite
    Sep 2011
    canada,ont
    837
    177 Post(s)
    Voltage fine. Batt light still on. Founders right nasty. Now how I get rid of it
    2006 Chevrolet Malibu 3.5l V6
    JVC KD-R620
    RE Audio XXX 6.5 components (front)
    Hifonics ZRX500.2 500W 2-Channel Class A/B Amplifier
    2 Sundown Audio 12s
    Rockford fosgate 15001bd Mono Amp
    Big 3 Upgrade
    Cadence 0 AWG Wiring Kit
    Singer 275A Alternator
    Optima Red Top under hood
  4. #79
    Aug 2012
    6,131
    3 Post(s)
    2554 Post(s)
    Quote Originally Posted by cbuts View Post
    drive around for a while i bet ur voltage will drop..without the stereo ..what is ur voltage at now?
  5. #80
    Aug 2012
    6,131
    3 Post(s)
    2554 Post(s)
    sometimes it took mine 15-30 minutes to drop from 14.5 to 12.9
  6. #81
    cbuts's Avatar
    Sep 2011
    canada,ont
    837
    177 Post(s)
    Sat in drive with break ac on and voltage stayed where it should for like ten mins. I need to get rid of this battight though. Ill be driving soon but I think voltage is fine now
    ---------- Post added at 08:05 PM ---------- Previous post was at 08:05 PM ----------
    Isles 14.7 and with ac break on stereo off 14.3
    JVC KD-R620
    2 Sundown Audio 12s
    Big 3 Upgrade
  7. #82
    Aug 2012
    6,131
    3 Post(s)
    2554 Post(s)
    but then again if the batt light is still on and the pcm senses a charging problem it might not shut the alt down..this might work in your favor
  8. #83
    Aug 2012
    6,131
    3 Post(s)
    2554 Post(s)
    like i said if u get the batt light off u might drop down to 13 while driving like its suppose to do...if it stays at 14.7 after driving a while i would leave it alone ...u might have tricked the computer to keep the alt fully charging
  9. #84
    Dec 2006
    wilmington, NC
    31
    2,970
    22 Post(s)
    you can probably pull the neg battery terminal for 15 minutes or so to reset the computer to have it go away. it's probably just a cel that needs to clear.
    Edit: you could just wait a day or so of driving it and wait for it to go away. if its charging good now i wouldn't be too concerne.d
  10. #85
    cbuts's Avatar
    Sep 2011
    canada,ont
    837
    177 Post(s)
    voltage stayed fine whole drive home around 14.7-14.9, half hour drive, stopped at harveys and it dropped to 14.5 lowest while in drive through so all seems to be fine, sounds normal and everything except if i accelerate really fast 3000+rpm it makes like a VRR and i feel a TINY vibration in the peddle, im not sure if this is normal, it may be with h.o alts.
    anyways i unplugged my neg terminal and am eating my harveys, i will plug it back in in like a half hour and see what happens.
    thanks both of yas much appreciated
    JVC KD-R620
    2 Sundown Audio 12s
    Big 3 Upgrade
  11. #86
    cbuts's Avatar
    Sep 2011
    canada,ont
    837
    177 Post(s)
    p.s my buddy got the belt, it wasnt made for my car, but same amount of ribs, and the guy told him it was just shy of an inch shorter, ( although they kkinda looked the same matched up) either way it fixed my voltage issue.
    JVC KD-R620
    2 Sundown Audio 12s
    Big 3 Upgrade
  12. #87
    Aug 2012
    6,131
    3 Post(s)
    2554 Post(s)
    exactly id leave it alone if its staying that high ...i wouldnt risk the conputer kicking in if u clear the code
  13. #88
    cbuts's Avatar
    Sep 2011
    canada,ont
    837
    177 Post(s)
    well i just want my car to function normally is all.. lol
    JVC KD-R620
    2 Sundown Audio 12s
    Big 3 Upgrade
  14. #89
    cbuts's Avatar
    Sep 2011
    canada,ont
    837
    177 Post(s)
    light still on.. what else could it be.. alternator made a wierd noise when i turned the key before i started it too, voltage staying past 14.5
    JVC KD-R620
    2 Sundown Audio 12s
    Big 3 Upgrade
  15. #90
    cbuts's Avatar
    Sep 2011
    canada,ont
    837
    177 Post(s)
    JVC KD-R620
    2 Sundown Audio 12s
    Big 3 Upgrade
  1. Battery/alternator help please
    By joker4096 in forum Wiring, Electrical and Installation Help
    Last Post: 04-19-2009, 08:56 PM
  2. Battery, Alternator, Capacitor Help
    By thermal in forum Wiring, Electrical and Installation Help
    Last Post: 11-24-2006, 03:43 PM
  3. battery/alternator help
    By slim j in forum Wiring, Electrical and Installation Help
    Last Post: 12-08-2005, 02:48 AM
  4. Need help on battery/alternator installation
    By cadenceman in forum Wiring, Electrical and Installation Help
    Last Post: 06-30-2003, 02:12 AM
  5. battery/alternators HELP ME!!!!!!!!!!!!!!!!!!!!!!!!
    By Unregistered in forum Subwoofers
    Last Post: 01-27-2002, 10:36 PM
