Page 5 of 7 FirstFirst 1 2 3 4 5 6 7 LastLast
Results 61 to 75 of 105
Reload Thread: Battery - Alternator HELP
  1. #61
    profundus-sanus's Avatar
    profundus-sanus is offline CarAudio.com Veteran
    Dec 2006
    wilmington, NC
    31
    2,970
    22 Post(s)
    Re: Battery - Alternator HELP
    Quote Originally Posted by cbuts View Post
    Mike is telling me its the pulley aswell I got one just short of an inch and I'm going to try that tonight with the small pulley. Hopefully all goes well. My idle should be atleast 14 right? Pretty sūre that's what it was with stock alt
    Ok I'm using factory plug aswell no harness nothing
    correct. your voltage shouldn't vary more than .1-.2 between cruising rpm and idle.
  2. #62
    cbuts's Avatar
    cbuts is offline CarAudio.com Elite
    Sep 2011
    canada,ont
    837
    177 Post(s)
    Quote Originally Posted by profundus-sanus View Post
    thanks, ill be putting the belt in today, in a couple hours. hope the batt light goes out lol
    2006 Chevrolet Malibu 3.5l V6
    JVC KD-R620
    RE Audio XXX 6.5 components (front)
    Hifonics ZRX500.2 500W 2-Channel Class A/B Amplifier
    2 Sundown Audio 12s
    Rockford fosgate 15001bd Mono Amp
    Big 3 Upgrade
    Cadence 0 AWG Wiring Kit
    Singer 275A Alternator
    Optima Red Top under hood
  3. #63
    Dec 2006
    wilmington, NC
    31
    2,970
    22 Post(s)
    indeed. that likely means that the pcm is commanding voltage and the alternator isn't producing it, so it thinks there is a problem with the alternator. By chance do you know what size pulleys he sent you? Do you know what the lowest rpm was that the alt would turn back on at? I can do the ratio calc for you really quick.
  4. #64
    cbuts's Avatar
    Sep 2011
    canada,ont
    837
    177 Post(s)
    im really not sure, so your still saying the pulley will fix it right? and the battery light? lol its got 6 ribs on the best, and we got just short of an inch shorter then oem belt
    i was sent the small one (attached) and a bigger one, i took small off and used bigger one for stock belt
    my belt doesnt even seem to be slipping atm
    JVC KD-R620
    2 Sundown Audio 12s
    Big 3 Upgrade
  5. #65
    09civic's Avatar
    09civic is offline CarAudio.com Veteran
    Dec 2010
    Melbourne, FL
    6,832
    1229 Post(s)
    Quote Originally Posted by Tenacious. View Post
    I use a stock length belt in mine with no belt slip. It depends on the car though, I suppose some tensioners won't hold the belt as tight as others. Make sure to get a good belt like a Gates or a Gatorback.
    Was the pulley size difference relatively small or big?
    And the 04 Taurus's had auto tensioners so that's probably why.
  6. #66
    09civic's Avatar
    Dec 2010
    Melbourne, FL
    6,832
    1229 Post(s)
    The PCM in my car will not use the alternator unless a power source other than a stereo system is in use.
    For example, my stinger voltmeter will read 12.7-12.8 until I turn on my lights, use the windshield wipers, roll down the windows, etc. Once I turn any of those items on, it will then read 14.4+.
    PCM's will not compensate for your system's draw.
  7. #67
    Dec 2006
    wilmington, NC
    31
    2,970
    22 Post(s)
    Quote Originally Posted by 09civic View Post
    a lot of gm's have a current measuring ring on the ground wires running to batt to determine draw on the batt.
    my gp for example. if i take it right off the charge and go drive it it'll be at 13.0v in 5 minutes if i leave the head lights off. but if its been sitting for a couple days and it might stay above 14v for 20+ minutes.
  8. #68
    Dec 2006
    wilmington, NC
    31
    2,970
    22 Post(s)
    well i can't say one way or another. if your smaller pulley is .1" smaller then it might not. if it's 1" smaller then i'm sure it will.
  9. #69
    cbuts's Avatar
    Sep 2011
    canada,ont
    837
    177 Post(s)
    Well on my way to fix it.. hope no light after this
    JVC KD-R620
    2 Sundown Audio 12s
    Big 3 Upgrade
  10. #70
    NASTY08IMPALA's Avatar
    NASTY08IMPALA is offline CarAudio.com Veteran
    Aug 2012
    LOUISVILLE, KENTUCKY
    6,131
    3 Post(s)
    2554 Post(s)
    Quote Originally Posted by pacustomz View Post
    We know its not the PCM since he by passed the harness,so yes it could be the pulley but since your gonna do a smaller pulley make sure you get a smaller belt to prevent slip
    ok since no one will listen here i go again...hes using.the stock plug ..not bypassed ...yes he needs to change the pulley ..but the 05+up chevys are pcm controlled for fuel econ..period..when i bought my mechman i had to externally regulate it so that i could charge at 15.3 ..or else it would drop down to 12.9-13v ...anyone else??
  11. #71
    Aug 2012
    6,131
    3 Post(s)
    2554 Post(s)
    exatly the same on the chevys ..honda u can do a eld bypass ...but the chevys will go from 13.9-14.5 then drop down to 12.9-13 .as controlled by the pcm ...no size puley will change that ..only way is a external reg.
  12. #72
    09civic's Avatar
    Dec 2010
    Melbourne, FL
    6,832
    1229 Post(s)
    Quote Originally Posted by NASTY08IMPALA View Post
    My Honda uses the PCM for fuel economy and I didn't have to bypass anything. Just plug n play. Yes, my alt is internally regulated.
    It's not charging it at 12.9-13.0, it's not using your alt at all.
    It's not just a GM thing.
  13. #73
    09civic's Avatar
    Dec 2010
    Melbourne, FL
    6,832
    1229 Post(s)
    Does using an accessory make the voltage jump back up?
    The way I bypass my PCM is to turn on the fogs during the day to keep the alternator running.
  14. Likes profundus-sanus liked this post
  15. #74
    Dec 2006
    wilmington, NC
    31
    2,970
    22 Post(s)
    pcm regulation will not cause your battery light to come on when your using a stock plug. It will not cause your voltage to die at idle but be fine at cruising speed.
    Your on the right track but your missing some key symptoms.
    On several gm vehicles if you just trick the light sensor to keep the lights on all the time it'll keep you above 14.0v and wont throw a charging system error code, which some vehicles do if you bypass pcm regulation.
  16. Likes SounDrive liked this post
  17. #75
    Aug 2012
    6,131
    3 Post(s)
    2554 Post(s)
    when i had my stock alt i did.things like turn the air/heat on headlights anythig.to gwt the alts attention ..my car also kicks into 3cyl mode when cruising ..so if.i kept it.in 6 it wouldnt drop
  1. Battery/alternator help please
    By joker4096 in forum Wiring, Electrical and Installation Help
    Last Post: 04-19-2009, 07:56 PM
  2. Battery, Alternator, Capacitor Help
    By thermal in forum Wiring, Electrical and Installation Help
    Last Post: 11-24-2006, 02:43 PM
  3. battery/alternator help
    By slim j in forum Wiring, Electrical and Installation Help
    Last Post: 12-08-2005, 01:48 AM
  4. Need help on battery/alternator installation
    By cadenceman in forum Wiring, Electrical and Installation Help
    Last Post: 06-30-2003, 01:12 AM
  5. battery/alternators HELP ME!!!!!!!!!!!!!!!!!!!!!!!!
    By Unregistered in forum Subwoofers
    Last Post: 01-27-2002, 09:36 PM
