Page 4 of 7 FirstFirst 1 2 3 4 5 6 7 LastLast
Results 46 to 60 of 105
Reload Thread: Battery - Alternator HELP
  1. #46
    NASTY08IMPALA's Avatar
    NASTY08IMPALA is offline CarAudio.com Veteran
    Aug 2012
    LOUISVILLE, KENTUCKY
    6,131
    3 Post(s)
    2554 Post(s)
    Re: Battery - Alternator HELP
    Quote Originally Posted by gamehawk55 View Post
    Is 13.6-13.8 really THAT bad? Also can you make a stock alt charge that high too? Or does it always have to be an HO alt to push em that high?
    considering i dont drop below 14.4 @full tilt yea its.bad ..and.sure.u should.be able.to get.stock alt that high
  2. #47
    gamehawk55's Avatar
    gamehawk55 is offline CarAudio.com Elite
    Nov 2012
    Victoria BC, Canada
    31
    534
    230 Post(s)
    Quote Originally Posted by NASTY08IMPALA View Post
    Might have to look into that.
    Vehicle: 2007 Pontiac G6 GT
    Head Unit: Kenwood DDX419
    Speakers: Focal PS165 Components
    Distribution: Knukonceptz KNF-60 Power/Ground Distribution block
    Amps: Audioque 200.2, Rockford Fosgate T2500-1BDCP
    Subs: 2 SA-8v2 D2 wired @2ohms in custom ported box tuned to 34-35hz
    Wiring: All 1/0 Gauge SHOK Wire and Knukonceptz wire + BIG 3
    Alternator: Singer 310A 6 Phase High Output Alternator
  3. #48
    phemps's Avatar
    phemps is offline CarAudio.com Veteran
    May 2009
    PA
    2,023
    284 Post(s)
    the small pulley wont fix.it ..its controlled by the pcm
    Actually now that i think of it.. im not using my factory plug i have the new alt wired into ignition switched NOT Controlled by PCM and i have similar issues so i dont see how it could be that...
    Refs: Rio, DbzArson, goodstuff, Worstenemy453
    Quote Originally Posted by Altec View Post
    Then obviously I am asking the wrong person, because you don't know how to hook up subs if they sounded like "****". Maybe learn your ohms and your diagrams before you call something ****. Learn to make boxes to specs and use the right wires and its called dynomat. Then maybe your car wouldn't of sounded like ****, yeah?
  4. #49
    phemps's Avatar
    May 2009
    PA
    2,023
    284 Post(s)
    My battery light has been on and i have been having charging issue messages pop up which i assumed was because the new alt doesn't use the factory plug
  5. #50
    Aug 2012
    6,131
    3 Post(s)
    2554 Post(s)
    Quote Originally Posted by phemps View Post
    then u have a totaly diff problem
    ---------- Post added at 05:23 AM ---------- Previous post was at 05:22 AM ----------
    anytime ur.not.usimg the oem plug u will get batt light amd warning messages..mine does
  6. #51
    MecaVA's Avatar
    MecaVA is offline Member
    May 2013
    Va
    33
    15 Post(s)
    funny i dont have a batt light yet
  7. #52
    Aug 2012
    6,131
    3 Post(s)
    2554 Post(s)
    Quote Originally Posted by Calilove View Post
    some manufactures dont.come in at all ..mine.cane on like a week after my ho alt install
  8. #53
    Aug 2012
    6,131
    3 Post(s)
    2554 Post(s)
    what year make and model?
  9. #54
    pacustomz's Avatar
    pacustomz is offline Member
    Sep 2011
    Bakersfield,CA
    36
    10 Post(s)
    A high output alt puts out the most amps at high rmp, what you need to understand is a alt will ''shut down'' at certain temps so when you see your voltage drop its because your enginge isn't spinning fast enough to keep it cool to produce the amps. Yes chevy did make alts to be controlled by pcm only to save fuel. I never noticed mine till i did upgrades to my electrical. If your not using the factory plug your alt is "always" on in a sense. What you should do is use a module it will raise the "charge point" of a alt to keep the voltage up even at idle. When it comes to alt and charging everyone has there own opinion and there isn't a common answer since every car is different just read up as much as you can and see what will work in your situation.
  10. #55
    09civic's Avatar
    09civic is offline CarAudio.com Veteran
    Dec 2010
    Melbourne, FL
    6,832
    1229 Post(s)
    What Mike Singer told me was that when having the smaller pulley, it spins faster when at idle to boost the idle amps.
    The problem isn't your PCM, it's because you switched the pulleys.
  11. #56
    pacustomz's Avatar
    Sep 2011
    Bakersfield,CA
    36
    10 Post(s)
    Quote Originally Posted by 09civic View Post
    We know its not the PCM since he by passed the harness,so yes it could be the pulley but since your gonna do a smaller pulley make sure you get a smaller belt to prevent slip
  12. #57
    cbuts's Avatar
    cbuts is offline CarAudio.com Elite
    Sep 2011
    canada,ont
    837
    177 Post(s)
    Quote Originally Posted by pacustomz View Post
    Mike is telling me its the pulley aswell I got one just short of an inch and I'm going to try that tonight with the small pulley. Hopefully all goes well. My idle should be atleast 14 right? Pretty sūre that's what it was with stock alt
    Ok I'm using factory plug aswell no harness nothing
    2006 Chevrolet Malibu 3.5l V6
    JVC KD-R620
    RE Audio XXX 6.5 components (front)
    Hifonics ZRX500.2 500W 2-Channel Class A/B Amplifier
    2 Sundown Audio 12s
    Rockford fosgate 15001bd Mono Amp
    Big 3 Upgrade
    Cadence 0 AWG Wiring Kit
    Singer 275A Alternator
    Optima Red Top under hood
  13. #58
    profundus-sanus's Avatar
    profundus-sanus is offline CarAudio.com Veteran
    Dec 2006
    wilmington, NC
    31
    2,970
    22 Post(s)
    this is absolutely correct. ^^^
    your problem is not your computer, as your computer will not vary alt output by rpm.
    If it is the computer all you have to do is turn your headlights on to bypass it. Most pcm regulated alternator gm vehicles have it programmed in to automatically command 14v instead of 12.9 once the headlights are turned on. I'll gladly make a video with my scan tool, 270a singer alt, and my 05 grand prix if anyone wants to argue that.
  14. #59
    09civic's Avatar
    Dec 2010
    Melbourne, FL
    6,832
    1229 Post(s)
    Quote Originally Posted by cbuts View Post
    Aim for 1/2in to 3/4in shorter. Don't go any smaller.
    I had to use a 6 groove instead of 7 groove for my car because they didn't make a 7 groove that was the right length.
  15. #60
    SounDrive's Avatar
    SounDrive is offline www.soundrive.audio SounDrive is a Supporting Member of the forum!
    SounDrive is a Supporting Vendor of the forum!
    Apr 2013
    Lebanon, TN
    3,072
    20 Post(s)
    1347 Post(s)
    I use a stock length belt in mine with no belt slip. It depends on the car though, I suppose some tensioners won't hold the belt as tight as others. Make sure to get a good belt like a Gates or a Gatorback.
    Owner, SounDrive Audio
    Visit our store at www.soundrive.audio
    Like us on Facebook at www.facebook.com/soundriveAudio
    PLEASE EMAIL ME FOR FASTER RESPONSES - [email protected]
    Dealer for: SounDrive Audio | Synergy Audio | Audio Legion | XS Power | Mechman | SPL-Lab | Taramps | Limitless Lithium | Wolfram Audio | Singer Alternators | Ampere Vibraflex
  1. Battery/alternator help please
    By joker4096 in forum Wiring, Electrical and Installation Help
    Last Post: 04-19-2009, 07:56 PM
  2. Battery, Alternator, Capacitor Help
    By thermal in forum Wiring, Electrical and Installation Help
    Last Post: 11-24-2006, 02:43 PM
  3. battery/alternator help
    By slim j in forum Wiring, Electrical and Installation Help
    Last Post: 12-08-2005, 01:48 AM
  4. Need help on battery/alternator installation
    By cadenceman in forum Wiring, Electrical and Installation Help
    Last Post: 06-30-2003, 01:12 AM
  5. battery/alternators HELP ME!!!!!!!!!!!!!!!!!!!!!!!!
    By Unregistered in forum Subwoofers
    Last Post: 01-27-2002, 09:36 PM
