im willing.to bet its computer controlled.like.mine ..but swap the pulleys for shlts and gigs
2006 Chevrolet Malibu 3.5l V6
JVC KD-R620
RE Audio XXX 6.5 components (front)
Hifonics ZRX500.2 500W 2-Channel Class A/B Amplifier
2 Sundown Audio 12s
Rockford fosgate 15001bd Mono Amp
Big 3 Upgrade
Cadence 0 AWG Wiring Kit
Singer 275A Alternator
Optima Red Top under hood
thing.about the smaller pulley is.u might need a smaller belt. cause u might have some slippage due to higher spin rate
JVC KD-R620
2 Sundown Audio 12s
Big 3 Upgrade
JVC KD-R620
2 Sundown Audio 12s
Big 3 Upgrade
Its your battery sorry to say go to oriellys and get a batt and alt test it wouldnt matter if you change the pulley why you think it comes with bothgo get a load test and also , when you installed the alt did you upgrade the charging wire to 4 gauge with a 150 amp fuse? Major must
I got a battery 2 days ago and its doin the exact same thing to me I got it tested today and it read bad cell im takin it back to get a new one smdh start with a load test it can read what you cant see smdh
its the godddam computer lol
---------- Post added at 11:49 PM ---------- Previous post was at 11:48 PM ----------
quit buyin crap batteries lol
its a chevy thing ..like i said until i externally regulated my alt i would be 14.6 driving.then at stops it would drop to 12.9..its pcm controled
Any 05 and chevy has a pcm controlled alt, it will go into economy mode and derate the alt. I had to get a module in order to make my dual alt set up work correctly
If it was PCM controlled he would have noticed it BEFORE installing the new alt. He said it was fine before the swap. Stock case rewound alt needs the smaller pulley as it has no output at idle.
I've installed a few DC alts on 05 Impalas and they were not PCM controlled. 14.9v all day at idle....
Bookmarks
