Results 1 to 13 of 13
Reload Thread: 2005 toyota corolla jbl stock plug in
    nickdeberg's Avatar
    nickdeberg is offline Junior Member
    Jul 2013
    waterloo, IA
    Icon8 2005 toyota corolla jbl stock plug in
    does anyone know of something that can replace the stock radio plug-in (the one that comes out of the dash that you plug the radio into) that will fit my 2005 toyota corolla with a stock jbl audio system.
    NFrazier's Avatar
    NFrazier is offline Senior VIP Member
    Oct 2006
    Massachusetts
    355
    87 Post(s)
    Re: 2005 toyota corolla jbl stock plug in
    Are you talking about the harness to replace the radio? It's the metra 70-8114. you'll need at least two sets of preouts (front and rear, and sub if you wanna do a sub at some point) or 2 sets with rear switchable preouts and then use 2 y adapters but you'll lose fade or balance (depending on how you connect the y adapter).
    iNNovative Concepts: Audio, Alarms/Remote Starts, OEM Integration, etc.
    MECP Master Certified Technician
    2015 Mobile Electronics Magazine Top 50 Installers - North America
    nickdeberg's Avatar
    Jul 2013
    waterloo, IA
    thanks for your response but i dont think that will work. i need something that i can wire to the wiring harness and still get the amp to work. so pretty much what im dealing with is imagine taking the radio out of the dash and when you go to unplug it you dont. and just cut the wires. The amp wires and other weird wires that used to go to that pluggin need to all be spliced back in
    nickdeberg's Avatar
    Jul 2013
    waterloo, IA
    and it also has to be jbl that one is not. i already tried this Best Kits BHO8113 Toyota Radio JBL Stereo Wire Harness | eBay and that is the exact size and thing i need exepct it only goes up to 2004 so i need the 05 - 10 one but i dont think they have it
    NFrazier's Avatar
    Oct 2006
    Massachusetts
    355
    87 Post(s)
    ooooooooh, gotcha. someone cut the factory plug.
    whats wrong the the BHO8113 harness? that's the appropraite harness? that will work for an 05 (despite it saying up to 04). the yotas that year didn't use a data amp turn on.
    nickdeberg's Avatar
    Jul 2013
    waterloo, IA
    yea i gotcha 05 toyota arn't differnt? on the package it said to 2004 and the wires do not quite line up want me to make a youtube video showing everything? and ive been without radio for 3 weeks and im going insane the bestbuy guys cant even fix it -_-
    NFrazier's Avatar
    Oct 2006
    Massachusetts
    355
    87 Post(s)
    the only reason that harness wouldn't work is if you have the first gen can (data amp turn on) JBL setup - which is VERY rare for an 05. If you do than there was two plugs. one handled all the power to the radio and speaker wires/illumination, etc. the other handled the can-bus.
    2005-2008 Toyota Corolla with JBL Wiring Information
    you should have had one plug like above link (data wires purple and pink) should have been in that plug.
    Is it the same radio that came with the car or was it a junk yard find? and your car actually had the factory JBL system in it?
    DARKHART's Avatar
    DARKHART is offline One Hitter Quitter
    Aug 2002
    LITTLE ROCK, AR
    2,290
    197 Post(s)
    With it being the JBL factory system then I assume that it has 6 speakers so try the Metra 71-8113 harness, it should be the right one. I've never liked and quit using the Best Kits products very early on......check out this pdf
    http://www.metraonline.com/files/pro...NST71-8113.pdf
    Just when they though it couldn't get any worse, in came the Lord of Kaos, the Darkhart has arisen from his century long slumber..
    ____________
    refs:
    Type-S Texan ............Xtremebass5
    NE14MX ........Grinder1989
    NJack2AF
    .............Jameseypoo
    Randyrsx ..........Bagdntagd
    M3Transporter......Teggybwoy
    RJ Sclafani...........Zeuslicious
    Saltyreefguy........Qkassidyw
    Qtrhorse..............Nismos14
    Pistonsfan70........4nine
    SlainNothing.........Orangelss
    [email protected]............Louisiana_CRX
    SW9152..............DukeNut
  9. #9
    NFrazier's Avatar
    Oct 2006
    Massachusetts
    355
    87 Post(s)
    Quote Originally Posted by DARKHART View Post
    the bestkits 8113 is the same as the 71-8113 (but i typically dont like bk stuff)
  10. #10
    DARKHART's Avatar
    Aug 2002
    LITTLE ROCK, AR
    2,290
    197 Post(s)
    Quote Originally Posted by NFrazier View Post
    Okay, can you post up pix or something like the back of the factory radio and inside of dash opening????
    ____________
    refs:
    NJack2AF
  11. #11
    nickdeberg's Avatar
    Jul 2013
    waterloo, IA
    oh my thank you so much for the great detailed info on the plug! sadly the pink and purple lines that u showed or the data lines the 8113 doesnt have wires in the right place is their any way to take them out and move them over so they go where the pink and purple should. so the socshe thing lines up right?
  12. #12
    DARKHART's Avatar
    Aug 2002
    LITTLE ROCK, AR
    2,290
    197 Post(s)
    If you can get them out but I would be VERY careful though and not being able to see it for myself I'm very guarded against saying do it......
    ____________
    refs:
    NJack2AF
  13. #13
    nickdeberg's Avatar
    Jul 2013
    waterloo, IA
    okay great news i got it all hooked up correctly ( had to repin some wires but got it exactly like the stock one was ) thanks for all the help guys! now im having a bit more trouble my bass is like super loud and the vocals are way too soft ive tried all the settings and nothing seems to help even when i put the bass no 0 and everything else high or try vocal mode. i have a sosche thing that makes my cd player work with my car and my cd player only has red and white plug ins and the sosche thing has grey white purple green it seems i can hook up any combination of those 4 and the thing still plays. ( i usually just keep white on left and grey on right ) so i dont think its that anyone have any ideas why my vocals wont turn up? may i note the vocals are definately their just very faint thanks
  1. 2005 toyota corrolla stock jbl amp NIGHTMERE help
    By nickdeberg in forum Wiring, Electrical and Installation Help
    Last Post: 07-12-2013, 05:18 PM
  2. Quick question on 2005 Toyota Corolla S
    By HannaS10 in forum General Discussion
    Last Post: 03-11-2007, 11:51 PM
  3. 2005 Toyota Corolla type S Amp Location
    By XxSuperAdamxX in forum Enclosure Design & Construction Help
    Last Post: 01-20-2007, 04:53 AM
  4. Worklog: 4 18" SX in a 92' Toyota Corolla *Pics*
    By Doitle in forum General Discussion
    Last Post: 04-02-2006, 12:39 PM
  5. A '98 Toyota Corolla Stock Radio
    By Heresy in forum Wiring, Electrical and Installation Help
    Last Post: 09-17-2002, 07:53 PM
Tags for this Thread
