Results 1 to 5 of 5
Reload Thread: 2007 Saturn Aura xe WIRING HELP!!
    Yakub268's Avatar
    Yakub268 is offline Junior Member
    Jun 2013
    fort bragg,nc
    Short Backstory: allowed my brother to install a sub system. He jacked up the wiring believe he split into the wrong remote wire behind the stereo. so you had to disconnect the subs at the amp or theyd kill the battery.
    The wife decided to have another guy "fix" it. Ended up with a three wires under the driver seat that had to be twisted together If you wanted the tail lights (plus some other cabin lights like the door handels ect) and subs to be powered and work.
    I have tried cutting the blue radio wire behind the stereo and the spliced wire behind the rear stereo console. Nothing is working and Im getting sick of having to flick a "gheto rigged" switch to turn on tail lights.
    Im positive if I were able to revert the wiring to factory Id be able to do the install my self. so just any help is much appreciated
    NIHL8ION's Avatar
    NIHL8ION is offline RUN ur car NOT ur mouth !
    Mar 2013
    IlliNOISE
    1,355
    22
    377 Post(s)
    Re: 2007 Saturn Aura xe WIRING HELP!!
    WOW... sounds like a fkn MESS If any plugs or connectors were cut off or removed, then I would go to a junkyard and find some from a donor car if you don't have them. Wire everything back up to stock, get the proper harness / interface(s) / etc. and wire everything up the RIGHT WAY with the remote turn on lead from your HU connected to the remote wire ran for your amp
    - Cadence DCA2500.1 Running a Tantric HDD - 12" D2
    *Bought From: cx-7heaven, nutnbutcustm, naughtyca, agarabaghi, Skip01*Traded With: infamous_e46, basswiigee**Sold To: DeanG, R.S.D., livinloud!*
    Feedback Link: http://www.caraudio.com/forums/itrader.php?u=1028333
    Yakub268's Avatar
    Jun 2013
    fort bragg,nc
    I dont know what connectors were possibly cut or what wires without the schematics allowing me to visually inspect the entire line.
    noweach time I mess with the connectors It messes up something else, my alarm keeps going off, driver door locks wont lock, other odds and ends. I realy need help here.
    Jepalan's Avatar
    Jepalan is offline CarAudio.com Elite
    Jun 2013
    Midwest
    603
    1 Post(s)
    158 Post(s)
    Does this help at all?
    2007 Saturn Aura Stereo Wiring Information
    Radio Battery Constant 12v+ Wire: White/Yellow
    Radio Accessory Switched 12v+ Wire: White/Red
    Radio Ground Wire: Black
    Radio Illumination Wire: Red/Black
    Stereo Dimmer Wire: Red
    Stereo Antenna Trigger Wire: Yellow/White
    Stereo Amp Trigger Wire: Yellow/White
    Left Front Speaker Positive Wire (+): White
    Left Front Speaker Negative Wire (-): Orange
    Right Front Speaker Positive Wire (+): Yellow
    Right Front Speaker Negative Wire (-): Brown
    Left Rear Speaker Positive Wire (+): Red
    Left Rear Speaker Negative Wire (-): Green
    Right Rear Speaker Positive Wire (+): Blue
    Right Rear Speaker Negative Wire (-): Black
    Yakub268's Avatar
    Jun 2013
    fort bragg,nc
    I found the issue The previous installer did a crap sodder job and didnt reconnect the power to the tail lights behind the rear console.
    I undid all his and just splicing into the pink wire from the amp. I now Im curious why the factory amp isnt plugged into the preamp output slot behind the head unit?
    Still having an issue with the alarm and the locks.
  1. Saturn Ion ACC Wire Help
    By Lingerfelt in forum Wiring, Electrical and Installation Help
    Last Post: 09-24-2007, 10:59 PM
  2. Alpine, Saturn, wiring... HELP!
    By HUM469 in forum Wiring, Electrical and Installation Help
    Last Post: 05-12-2005, 03:46 PM
  3. Saturn Wiring Help!
    By JD18 in forum Wiring, Electrical and Installation Help
    Last Post: 11-26-2003, 05:35 AM
  4. Wiring Help...anyone
    By nik_man in forum Wiring, Electrical and Installation Help
    Last Post: 02-02-2002, 11:45 AM
  5. 2001 Blazer---AMP POWER wire help......
    By Tryin2bump in forum General Discussion
    Last Post: 12-29-2001, 11:53 PM
Tags for this Thread
