Results 1 to 7 of 7
Reload Thread: Help think I may have F***ed my head unit!!
    gamehawk55's Avatar
    gamehawk55 is offline CarAudio.com Elite
    Nov 2012
    Victoria BC, Canada
    31
    534
    230 Post(s)
    Hey guys.
    So I was installing my new amp and distribution block tonight and everything went fine. Did a final test before bolting everything down to make sure everything was good (and it was). After bolting everything down I turn the car on again and all of a sudden have HORRENDOUS ECM noise with the car "off" and even worse noise with the car "on".
    Turns out when I was bolting down I accidentally clipped one of the speaker wires slightly with a screw and I got a bad feeling it may have shorted out something in the head unit, like a PICO fuse or something. The noise happens whether I use the front or rear RCA cables, but the noise does not effect the subs.
    And I know it's not just a bad ground because everthing was fine before I nicked the speaker wire.
    Also I don't think it's the amp that got fried because I tried another amp and had the same problem , in fact the problem was even worse on the other amp, where that amp had no noise issues at all the last time it was installed 2 weeks ago.
    My head unit is a Kenwood DDX419, so if anyone knows what exactly has happened here and can let me know if this is fixable or if the unit is toast now or what?
    Vehicle: 2007 Pontiac G6 GT
    Head Unit: Kenwood DDX419
    Speakers: Focal PS165 Components
    Distribution: Knukonceptz KNF-60 Power/Ground Distribution block
    Amps: Audioque 200.2, Rockford Fosgate T2500-1BDCP
    Subs: 2 SA-8v2 D2 wired @2ohms in custom ported box tuned to 34-35hz
    Wiring: All 1/0 Gauge SHOK Wire and Knukonceptz wire + BIG 3
    Alternator: Singer 310A 6 Phase High Output Alternator
    mylows10's Avatar
    mylows10 is offline B2,singer,ampere rep mylows10 is a Supporting Member of the forum!
    mylows10 is a Supporting Vendor of the forum!
    Sep 2009
    monterey , ca
    54
    22,432
    141 Post(s)
    1 Thread(s)
    6011 Post(s)
    Re: Help think I may have F***ed my head unit!!
    kenwoods dont have the pico fuse,,may have burned a resister in the deck ,may be a n easy fix for a shop
    pioneer avhx 4800 dvd, ampere tfhe 9.0 and 150.4 with arc audio xxd 4080
    4 d3100 and 3 deka 8a31 and d975 ,270 dc power and 320 amp singer alt
    B2 ref mids,Cdt es6 mids cdt es 010 tweets x2 ,es 03 Mids x 2 mx1000 , sky high ,eb flex, and stinger hpm o gauge wires ,also 2 crossfire xsv2 18s in a 4th order no wall box
    NOR CAL DB DRAG JUDGE
    http://www.dcsoundlab.com
  3. Likes basswiigee liked this post
  4. #3
    gamehawk55's Avatar
    Nov 2012
    Victoria BC, Canada
    31
    534
    230 Post(s)
    Quote Originally Posted by mylows10 View Post
    It's just weird that clipping the speaker wire would have done it. I could understand if I had of clipped the RCA but it was the wire.
    But I hope you are right about it being an easy fix for a shop cuz I just spent like $1200 on new amps. I don't want to have to spend another $300 right now replacing a deck too lol. Annd actually it would be more than $300 probably cuz I would need it right away so would have to pay local prices.
  5. #4
    gamehawk55's Avatar
    Nov 2012
    Victoria BC, Canada
    31
    534
    230 Post(s)
    Ok so the head unit was screwed up. Got a new one and hooked it up and the noise is gone. Fought with an idiot at futureshop for like 20 minutes cuz he wouldn't stop telling me that it was a bad ground issue and couldn't POSSIBLY be anything else. Fuc**n' reta**s.
    Annnnyyways..I have a new problem now. For some reason my tweeters no longer work (both of them). I'm not sure if they stopped working when the last head unit went or if it was today. I only noticed it after hooking up the new HU because all the engine and ECM noise was gone so could clearly hear the speakers again.
    How would I go about testing to see if the tweeters really are dead?
  6. #5
    robert420's Avatar
    robert420 is offline Senior VIP Member
    Dec 2012
    geneva ne
    338
    86 Post(s)
    put a dmm to the tweeters
  7. #6
    basswiigee's Avatar
    basswiigee is offline CarAudio.com Veteran
    Apr 2013
    MICHIGAN
    3,337
    4 Post(s)
    1112 Post(s)
    ↑↑↑↑ i agree...
  8. #7
    pickup1's Avatar
    pickup1 is offline CarAudio.com Veteran
    Aug 2005
    Roanoke,TX
    53
    8,464
    19
    7 Post(s)
    835 Post(s)
    Your surge may have roasted them...
  1. Need help with finding the correct harness for my head unit (Sony CDX-GT250MP)
    By nickk513 in forum Wiring, Electrical and Installation Help
    Last Post: 12-11-2012, 07:03 PM
  2. I think I may have an improper ground. Input Please.
    By Zaytser in forum Wiring, Electrical and Installation Help
    Last Post: 10-04-2008, 04:36 PM
  3. I think I blew my head unit...Help please
    By s5pitfire in forum Wiring, Electrical and Installation Help
    Last Post: 08-09-2007, 07:17 PM
  4. I think I may have found the one
    By KnOkIn It 420 in forum Amplifiers
    Last Post: 11-15-2005, 09:23 PM
