Results 1 to 4 of 4
Reload Thread: extremly loose ground causing secondary issue with amp?
    treiber67's Avatar
    treiber67 is offline Senior VIP Member
    Dec 2012
    ft.lauderdale fl
    156
    28 Post(s)
    So the other day I noticed that the subwoofers were sounding ok at about 10% volume anything past that would cause them to fall out and make strange noises. Come to find out I had a very looks ground that was going to my secondary battery I figured I would just tighten it up and everything would be fine. After tightening up and turning on it didn't work. From there I removed headunit and tried switching the rcas to a different output. I then put them back and now I have no output at all even back on the subwoofer output. Heres my question with a loose ground would that cause my ground inside of the amplifier that goes to the rca outputs to malfunction?
    keep_hope_alive's Avatar
    keep_hope_alive is offline Acoustics Engineer keep_hope_alive is a Supporting Member of the forum!
    May 2007
    Quad Cities, IL
    7,080
    28
    47 Post(s)
    1502 Post(s)
    Re: extremly loose ground causing secondary issue with amp?
    loose grounds will cause voltage problems. just being tighter doesn't mean there wasn't arcing or corrosion. check all fuses and then use a DMM to verify voltage at the amp and remote relative to the amp ground terminal.
    got a question? shoot me a PM. Matthew 6:9-15 - YouTube Channel: https://www.youtube.com/channel/UCkYUo2EShW9lgtrfXiDvLNQ/videos
    2014 Accord build log: http://www.caraudio.com/forums/car-audio-build-logs-cars-trucks-suvs/608637-2014-accord-sport-sq-build-keep_hope_alive.html
    2001 Accord build log: http://www.caraudio.com/forums/car-audio-build-logs-cars-trucks-suvs/536049-2001-accord-ex-sedan-its-long.html
    My 1966 MGB: http://www.mgexp.com/journal/keephopealive
    Fix Photobucket Image Loading ------> https://addons.mozilla.org/en-US/firefox/addon/photobucket-fix/ <------
    robert420's Avatar
    robert420 is offline Senior VIP Member
    Dec 2012
    geneva ne
    338
    86 Post(s)
    also, remove the ground and make sure there is no rust, corrosion etc.
    treiber67's Avatar
    Dec 2012
    ft.lauderdale fl
    156
    28 Post(s)
    Who would of thought after ripping everything apart and regrounding blah blah dash apart blah blah 5 hours invested....the fust under the hood no signs of it being blown was the cause of this whole issue. 100 amp glass fuse. Anyone else ever had this issue?
    ---------- Post added at 01:03 PM ---------- Previous post was at 01:03 PM ----------
    Fuse*
    You would of helped me if I kept up with my post, thank you for your input!
  1. issues with amp help needed
    By REDz28 in forum Amplifiers
    Last Post: 03-16-2013, 04:56 PM
  2. Power Issues with Amp
    By Nickum32 in forum Wiring, Electrical and Installation Help
    Last Post: 03-06-2012, 10:46 PM
  3. Issue with Amp?
    By Packer24 in forum Wiring, Electrical and Installation Help
    Last Post: 09-10-2011, 10:05 PM
  4. Having Issues With Amp Please Help
    By JimmyCart in forum Amplifiers
    Last Post: 07-18-2009, 12:21 PM
  5. Bridging causing an issue with time correction
    By bikinpunk in forum Head Units
    Last Post: 10-28-2006, 01:39 AM
