Results 1 to 14 of 14
Reload Thread: HELP -Power Slowly Decreasing
    dragonware's Avatar
    dragonware is offline Member
    Aug 2012
    Canada Toronto
    43
    7 Post(s)
    Hi Guys im new to this can you please help me figure if my wiring is wrong or if I need a better amp.
    here is the story.
    FIRST
    2 Eminence beta-6a 175RMS @ 8 ohm in my front doors parallel to 4ohm
    Powered by Massive audio NX2- Bridged 480RMS CEA-compliant @4ohm
    SOUNDED excellent clean loud crystal clear
    Second
    2 kicker components DS6.21 60RMS @4ohm in the rear doors
    Powered by Massive Audio NX4- one speaker per ch 100RMS CEA-Compliant @4ohm
    Sounded crystal clear but I lost about 10% volume
    Kickers are over powered
    and the eminence are underpowered and the ohm is mis matched but still sounded great and amp would not go into protect mode.
    In this configuration if I attempted to Bridge and parallel the NX4 for the eminence it would go into protect after 20 mins of play
    Third
    2-Tweeters/crossovers from the kicker components added to the front doors ( assuming this is 4ohm also)
    My music sounds complete now however i have lost another 10% of my volume.
    am i wiring this wrong ?
    Would my tweeter be getting more power than the eminence since they are on the same crossover ?
    Any risk of damage ?
    anything I can do to wire differently or change crossover to get back my volume all gains are set properly dont wana mess.
    The amp is capable of 200RMS @2ohm by adding the tweeter to the eminence on the crosover am i now down to 2.66ohms so the amp is giving 200RMS instead of 100 ? Why the loss in power is the tweeter pulling more watts as its the one with the lower impedance ?
    Sorry for the long winded post wanted to give as much info as i can.
    FYI 2-12" RE audio *** 1200 RMS @1ohm on a Hifonics GLX1400.1D
    JVC-kd-X40 head unit
    Cadence CE-773 EQ
    Extra battery and 0 gauge No big 3.
    trumpet's Avatar
    trumpet is offline CarAudio.com Veteran
    Jan 2011
    Grafton, ND
    36
    6,792
    43 Post(s)
    1859 Post(s)
    Re: HELP -Power Slowly Decreasing
    Adding tweeters doesn't drop the impedance like adding a woofer in parallel. You're not actually running that amp at 2.66 ohms. How are you arriving at this 10% loss of volume? How did you set the gains on the amp? Also, when you're into your system upgrades this far you must do the Big 3. Your electrical upgrades are bottlenecked at critical junctions.
    Rubyserv - I believe I can delivery joy every time you drive by the power of an incredible sound system. Barry Schanz, Owner
    Authorized dealer for CDT Audio - Shop With Us Now.
    FB | Rubyservsales
    IG | Rubyserv
    dragonware's Avatar
    Aug 2012
    Canada Toronto
    43
    7 Post(s)
    I noticed the volume drop the first time when I unbridged I needed to take my volume up to 20 to be heard a block away,
    now that I added the tweets an crossover i have to take my volume up to 30 to get the same results.
    I have the wire and planned on doing the big 3 problem is i need to hoist my car up 2008 ford focus Se to get to my alternator.
    and my garage told me that its un necessary since i have 2 batteries and a 110 stock alternator.
    I dont see any lights dimming or anything and my volt meter is pretty much constant on 13.9 when car is running.
    Gains on the NX4 are set to just a little bit past half way mark but less than 3/4
    Thanks for your response most of my posts go un answered in here guys say they dont like canadians
    Nov 2011
    Dallas, Tx/Ada, Ok
    24
    3,768
    1308 Post(s)
    Dude just do the big 3, your garage don't know sheit if there not reccomending. There's only one way to solve a problem like this and it's test test test, first thing is first.. Do your big 3
    trumpet's Avatar
    Jan 2011
    Grafton, ND
    36
    6,792
    43 Post(s)
    1859 Post(s)
    Set your gains with a DMM at the least. An oscilloscope or a DD-1 would be better. Setting the gains by going to the half way mark or by using any arbitrary method is not correct. A lot of people can set gains by ear, but they've been doing it a long time.
    There's nothing wrong with needing to turn the volume up higher to get the desired output, as long as you're not pushing the amp into heavy clipping. Unless you still have speakers powered by the head unit you should be turning the volume up to roughly 75% before adjusting the gains.
    If you need to put off the power wire upgrade between the alternator and the battery due to the difficulty then at least upgrade the ground wires. Go from the battery and the chassis and another one between the battery and the engine block.
    FB | Rubyservsales
    IG | Rubyserv
    dragonware's Avatar
    Aug 2012
    Canada Toronto
    43
    7 Post(s)
    yea I can do the ground wires.
    the gains were set by a vetran, i just found it funny that as soon as i added the tweets n crossovers i noticed a 10point volume drop.
    thought it had to do with mis matching the ohms n amp.
    trumpet's Avatar
    Jan 2011
    Grafton, ND
    36
    6,792
    43 Post(s)
    1859 Post(s)
    Disconnect the extra tweeters and crossovers and listen again.
    FB | Rubyservsales
    IG | Rubyserv
    dragonware's Avatar
    Aug 2012
    Canada Toronto
    43
    7 Post(s)
    because
    we all love to remove door panels
  9. #9
    trumpet's Avatar
    Jan 2011
    Grafton, ND
    36
    6,792
    43 Post(s)
    1859 Post(s)
    Quote Originally Posted by dragonware View Post
    because
    Do you want to troubleshoot this or live with the decreased output?
    FB | Rubyservsales
    IG | Rubyserv
  10. #10
    dragonware's Avatar
    Aug 2012
    Canada Toronto
    43
    7 Post(s)
    naw ill go back in and disconect and try again.
  11. #11
    dragonware's Avatar
    Aug 2012
    Canada Toronto
    43
    7 Post(s)
    found it, so turns out the crossover in the door was busted something broke off inside opened it up n re solders its back.
    As to the volume issue when i installed the cross over i put my head unit flat
    to set the EQ. and never put it back up so once i did that i was able to get my volume back.
  12. #12
    trumpet's Avatar
    Jan 2011
    Grafton, ND
    36
    6,792
    43 Post(s)
    1859 Post(s)
    How much are you boosting on the EQ? You could be pushing your amps into bad clipping.
    FB | Rubyservsales
    IG | Rubyserv
  13. #13
    mrclean636's Avatar
    mrclean636 is offline Time is Money
    Sep 2011
    NY
    77
    7 Post(s)
    You should "set" everything for where you are going to listen to it at. Setting and tuning it for a flat eq is perfect but if you are then going to switch it to something like "powerful" or "bass boost" you are wasting your time.
    Car: 2011 Ford Taurus SEL / Alt: DC Power 270XP
    Deck: Pioneer AVIC-Z140BH / Amps: (1) DC 5.0K, (1) RF T400-2
    Speaks: (1) RF T2652-S 6.5", (1) RF T1682 6x8"
    Subs: (2) DC XLm2 15's / Batts: (2) XS XP3000 Batts
    Wiring: Kolossus Fleks Kable 1/0 (2 runs)
    My Ratings:
    iTrader: http://www.caraudio.com/forums/itrader.php?u=1011469
    Feedback Thread: http://www.caraudio.com/forums/buyer-seller-feedback/575818-mrclean636-feedback-thread.html
  14. Dislikes martiandancer31 disliked this post
  15. #14
    dragonware's Avatar
    Aug 2012
    Canada Toronto
    43
    7 Post(s)
    the input on the EQ is almost all the way down, and to the other point. im not using bass bost or loud/powerful on the headunit.
    I just increased the mid n highs up by about 2 points.
    The problem with the crossover is i think its just cheaply made its not the first time things have desoldered from the board an i had to re solder them. in both units KICKER garbage.
  1. 2003 cavalier install help (power issue)
    By valuepac in forum Wiring, Electrical and Installation Help
    Last Post: 10-23-2004, 03:20 PM
  2. need help powering an SI magnum d2
    By scsi in forum Amplifiers
    Last Post: 11-10-2003, 11:07 PM
  3. help power but nothin goin to subs
    By Alpine4life in forum Wiring, Electrical and Installation Help
    Last Post: 10-19-2003, 05:54 PM
  4. HELP!Power suply!!
    By stangpounder in forum General Discussion
    Last Post: 08-06-2003, 11:06 PM
  5. Need help powering subs
    By Unregistered in forum Wiring, Electrical and Installation Help
    Last Post: 03-21-2002, 11:30 PM
