Results 1 to 6 of 6
Reload Thread: 4 Channel Amp, 5 Speakers. Best option for rears?
    Gawdzila's Avatar
    Gawdzila is offline Junior Member
    Apr 2013
    San Diego, CA
    2 Post(s)
    Hey all,
    I'm a stereo installation newb with a setup question. Things should be mostly straightforward, but I do have one question about the rear speakers. I was contemplating just leaving the rears unpowered but I'd like to have some rear fill, especially for back seat passengers.
    What I was thinking is to leave the rears powered by the HU and power the fronts with the amp. However, the HU only has one set of switchable pre-outs that I'm going to leave on "rear" to send a full-range signal to an EQ. Will this cause the HU to stop sending a signal to the rear speakers? If so, would it be okay to simply wire the rears to the front output on the HU? Is there a better way I could handle this?
    In case it is salient, here's what I'm working with (in a 95' Civic):
    Sony CDX-GT130 (1 set pre-outs, switchable rear/sub)
    Alpine MRP-F240 4-channel amp (will bridge 2 channels to power sub)
    1 soon-to-be-purchased inexpensive EQ (probably Lanzar Vibe 440PSU)
    Front: Pioneer TS-A1374R 5-1/4" 3-way
    Rear: Stock
    Sub: 1 Rockford Fosgate Prime R1S410 (0.7ft^3 enclosure)
    BrownVanMan's Avatar
    BrownVanMan is offline CarAudio.com Veteran
    May 2009
    Minneapolis MN
    2,018
    1 Post(s)
    331 Post(s)
    Re: 4 Channel Amp, 5 Speakers. Best option for rears?
    Just run the rear on the deck?
    May 2009
    Minneapolis MN
    2,018
    1 Post(s)
    331 Post(s)
    And you will need RCA splitters for that amp.
    Gawdzila's Avatar
    Apr 2013
    San Diego, CA
    2 Post(s)
    Quote Originally Posted by BrownVanMan View Post
    That is what I wanted to do but I was curious if, in general, setting the pre-outs to "rear" would shut off the speaker-level signal to the rears from the HU?
    Hm, I hadn't thought of doing that, running 4 channels from a single set of pre-outs. I think I'll have an EQ, though, based on an earlier recommendation from someone in this forum I was planning to run one set of RCAs from the HU pre-outs to the EQ, and 2 sets of RCAs from the sub/front EQ outs to the amp.
    May 2009
    Minneapolis MN
    2,018
    1 Post(s)
    331 Post(s)
    I don't know for sure, but I doubt that deck is sophisticated for that feature
    Gawdzila's Avatar
    Apr 2013
    San Diego, CA
    2 Post(s)
    Awesome, I'll just leave the rears hooked up to the HU and hope for the best.
    Thanks
  1. WTT autostart as-2775 for a small 4 channel amp or nice 6x9s for my rear fill
    By Weekz21 in forum Wanting to Buy (WTB) - Car Audio
    Last Post: 09-15-2010, 11:46 PM
  2. Best option for 6x8 speakers???
    By Navy guy in forum Speakers
    Last Post: 03-04-2008, 04:46 PM
  3. looking for a 4 channel amp to power fronts and rear
    By iamamp3pimp in forum Amplifiers
    Last Post: 01-05-2004, 12:12 AM
  4. IMO, 4 channel Amps are a Must for 3-way Comps.
    By nrgy in forum General Discussion
    Last Post: 03-06-2003, 01:45 PM
  5. Best bass for rear doors under 120 retail
    By triptickon in forum Subwoofers
    Last Post: 10-17-2002, 09:33 PM
