Page 2 of 3 FirstFirst 1 2 3 LastLast
Results 16 to 30 of 40
Reload Thread: lights dimming without serious voltage drops?
  1. #16
    robert420's Avatar
    robert420 is offline Senior VIP Member
    Dec 2012
    geneva ne
    338
    86 Post(s)
    Re: lights dimming without serious voltage drops?
    Quote Originally Posted by TreyE View Post
    I took that as, when his car is off his batteries are resting at 12.4 volts. Ive always thought it should be at least 12.5-12.9 resting...
    actually i think the voltage should be at 12v- 12.5 when its OFF...
    while idle it should read between 14.2- 14.4v
  2. #17
    LosIsATool's Avatar
    LosIsATool is offline CarAudio.com Veteran
    Apr 2011
    Pensacola, Florida
    37
    17,717
    107 Post(s)
    7515 Post(s)
    Quote Originally Posted by robert420 View Post
    car dependent. Some like mine before the bypass dont charge over 13.8
    2014 Ford Fusion SE 2.0T
    JBL MS-8
    DD M1c, DD SS4A
    IDQ12v4 1.8cu sealed
    Hertz HT28
    Hertz HV165XL
    Knuconceptz OFC, Custom fit Soundrive RCAs.
  3. #18
    TreyE's Avatar
    TreyE is offline CarAudio.com Veteran
    Apr 2006
    Tampa
    3,843
    2 Post(s)
    187 Post(s)
    I guess 12.4 is ok. Any lower you need to charge or do a load test (for free at autozone or something). It should NOT be resting at 12-12.2, thats no bueno.
    2011 Honda Accord Coupe
    ---Pioneer AVH-x3700BS---Seas Neo H1396---Silver Flute 6.5---05 RE XXX 12---FSD 1600D & 85.4---Knu Wiring---MurderMat Deadener
    Build: http://www.caraudio.com/forums/car-audio-build-logs-cars-trucks-suvs/618553-2011-accord-coupe-rims-suspension-idmax-silver-flute.html
  4. #19
    robert420's Avatar
    Dec 2012
    geneva ne
    338
    86 Post(s)
    Quote Originally Posted by DDtC View Post
    makes sense... my car stays at a steady 13.8 all day long
  5. #20
    NASTY08IMPALA's Avatar
    NASTY08IMPALA is offline CarAudio.com Veteran
    Aug 2012
    LOUISVILLE, KENTUCKY
    6,131
    3 Post(s)
    2554 Post(s)
    Man up and externally regulate tht shlt ..i rest at 15.3
  6. #21
    gckless's Avatar
    gckless is offline CarAudio.com Veteran
    Aug 2011
    San Antonio
    5,159
    6 Post(s)
    2218 Post(s)
    Optima's are crap. I had a Yellowtop in my last car, won't buy one again. Bought it new in August, fell to resting voltage of 12.2V by November. That's part of his current problem.
    BUT, no one can really recommend what he should get, besides maybe new batteries, until he actually says what amps he's going to be using, and therefore what kind of draw he will be seeing. Blind guessing at this point. Need more info OP.
  7. #22
    des343's Avatar
    des343 is offline CarAudio.com Elite
    Feb 2011
    Kalamazoo, MI
    994
    436 Post(s)
    Quote Originally Posted by gckless View Post
    So again, what amps do you have and plan on getting? If you plan on getting decent sized amps, electrical is going to cost a lot, so you may want to rethink your amp decision.
    Well I have a t2000 thought about two of those but I have a ln audiopipe 3000 and I think it sounds much better on the woofers than the t2000 honestly more power and better range of settings. So thought on another one plus they are cheap I had two once but I was a idiot and mad and in a hurry doing something and fried it.
    Plus subs are w7s so the odd ohms favors the ap3000
  8. #23
    des343's Avatar
    Feb 2011
    Kalamazoo, MI
    994
    436 Post(s)
    Yeah every battery I've personally tested with it being out of the vehicle has rested at 12.4 and that's even after a full charge from the battery charger... And I have had both batteries tested to make sure everything was okay with them when I got em
  9. #24
    des343's Avatar
    Feb 2011
    Kalamazoo, MI
    994
    436 Post(s)
    How about start by setting the amp up right and make sure you have a good ground
    I'm pretty sure my ground isn't ideal but I know its solid...its grounded to the battery and the battery is grounded to the floorboard sanded and bolted down very tight.
    I mean I can get pretty loud like car alarms go off with it at 40 with zero drop but I got it set to go to like 58 before distortion and that's when the voltages will start to drop
  10. #25
    Aug 2012
    6,131
    3 Post(s)
    2554 Post(s)
    58 before distortion??? what headunit is that? was it set with a dd1 or oscope to test distortion at the hu..seems high
  11. #26
    des343's Avatar
    Feb 2011
    Kalamazoo, MI
    994
    436 Post(s)
    Quote Originally Posted by NASTY08IMPALA View Post
    It is high but I keep my bass on the hu at 0 or under amp is not even half way gain. Its a pioneer that is like 3 or 4 years old don't remember the model off hand it tops out at like 70 I think and I have this setting SLA I think is what it is though not sure exactly what it means or meant to do bit I turn that to about neg 2 which dulls everything down which allows me to turn it up high I think it sounds much better that way
  12. #27
    gckless's Avatar
    Aug 2011
    San Antonio
    5,159
    6 Post(s)
    2218 Post(s)
    Quote Originally Posted by des343 View Post
    I'm a bit buzzed, but this is really confusing to me. So are you currently running both those amps in the car? List what amps you are currently using, and which amps you plan on getting.
    But 4 of either of those amps is going to require some substantial electrical. No wonder you're dropping to low voltages running 2. You're going to need HO alt, multiple runs of 1/0ga from front to back, big 3 done in 1/0ga, multiple batteries in the back. If you buy new, absolutely no less than $1200, but probably more like $1800 or so. If you buy all used, you might get away with ~$1000
  13. #28
    des343's Avatar
    Feb 2011
    Kalamazoo, MI
    994
    436 Post(s)
    Lol im only running one which is the ap3000 I've tried both at different times. But I have 4 w7s current set up only has 2 of them
  14. #29
    Warren89's Avatar
    Warren89 is offline Member
    Dec 2012
    Maine
    55
    8 Post(s)
    Possibly your alternator is going. My f350 would dim heavily when using my MM plow. Replaced the alternator and problem solved.
    Smokey the Deer says downed power lines are bad!!!
  15. #30
    gckless's Avatar
    Aug 2011
    San Antonio
    5,159
    6 Post(s)
    2218 Post(s)
    Even running one, not surprised you're dropping down as low as you are. Not at all. What do you plan on running in the future?
  1. voltage drop without dimming?
    By Beatin' in forum Wiring, Electrical and Installation Help
    Last Post: 01-29-2013, 05:07 PM
  2. voltage drop/lights dimming issue with bad grounds?
    By Guinelle1 in forum Wiring, Electrical and Installation Help
    Last Post: 07-05-2011, 10:18 PM
  3. voltage drops...and protect light
    By jguti92 in forum Wiring, Electrical and Installation Help
    Last Post: 01-14-2010, 10:25 PM
  4. serious voltage drop and dimming
    By bigchevyboy in forum Wiring, Electrical and Installation Help
    Last Post: 08-26-2007, 03:14 PM
  5. NOT Light Dimming, But Excess Voltage?
    By kicker06 in forum Wiring, Electrical and Installation Help
    Last Post: 02-11-2007, 03:33 PM
