Page 2 of 4 FirstFirst 1 2 3 4 LastLast
Results 16 to 30 of 54
Reload Thread: HELP! what do i need...
  1. #16
    mylows10's Avatar
    mylows10 is offline B2,singer,ampere rep
    Sep 2009
    monterey , ca
    54
    22,442
    141 Post(s)
    1 Thread(s)
    6015 Post(s)
    Re: HELP! what do i need...
    Quote Originally Posted by basswiigee View Post
    i got 4ga batt. to chas.,
    ---------- Post added at 11:15 PM ---------- Previous post was at 11:14 PM ----------
    05 cobalt
    not good enough ,0 gauge , i have kits for 45 shipped .you can use the jl wire if you have it .4 gauge big 3 is mostly useless ,but better than stock sometimes
    pioneer avhx 4800 dvd, ampere tfhe 9.0 and 150.4 with arc audio xxd 4080
    4 d3100 and 3 deka 8a31 and d975 ,270 dc power and 320 amp singer alt
    B2 ref mids,Cdt es6 mids cdt es 010 tweets x2 ,es 03 Mids x 2 mx1000 , sky high ,eb flex, and stinger hpm o gauge wires ,also 2 crossfire xsv2 18s in a 4th order no wall box
    NOR CAL DB DRAG JUDGE
    http://www.dcsoundlab.com
  2. #17
    basswiigee's Avatar
    basswiigee is offline CarAudio.com Veteran
    Apr 2013
    MICHIGAN
    3,337
    4 Post(s)
    1112 Post(s)
    Quote Originally Posted by mylows10 View Post
    i got enough to do everything except batt to alt. cuz my batt is in the trunck thats gonna be hell trying to run that through the whole car...
  3. #18
    mylows10's Avatar
    Sep 2009
    monterey , ca
    54
    22,442
    141 Post(s)
    1 Thread(s)
    6015 Post(s)
    well that will cost you prolly $50 alone for that run ,i have it in stock
  4. #19
    basswiigee's Avatar
    Apr 2013
    MICHIGAN
    3,337
    4 Post(s)
    1112 Post(s)
    Quote Originally Posted by pinoy2o9 View Post
    goodluck with ur big 3.
    thanks! geez never knew so much was involved!
  5. #20
    mylows10's Avatar
    Sep 2009
    monterey , ca
    54
    22,442
    141 Post(s)
    1 Thread(s)
    6015 Post(s)
    yes if you want your system to run efficiently
  6. Thanks basswiigee thanked for this post
  7. #21
    basswiigee's Avatar
    Apr 2013
    MICHIGAN
    3,337
    4 Post(s)
    1112 Post(s)
    just decent 0ga doesnt have to be jl, question can i run it from the alt. to the spot under the hood used for jumping the car, or literally all the way back to the battery and if i just take it to get it done whats a fair price?
  8. #22
    audiobaun's Avatar
    audiobaun is offline CarAudio.com Veteran
    Jun 2011
    Tx
    9,245
    25 Post(s)
    2153 Post(s)
    You really need to get it done so that the supply needed for the amp maintains proper voltage,and not starve for power resulting in low voltage in which will/can damage your amplifier due to low voltage.It will help with the Dimming of your lighting, as well as maintain the voltage from severe voltage lost due to poor supply.
  9. #23
    audiobaun's Avatar
    Jun 2011
    Tx
    9,245
    25 Post(s)
    2153 Post(s)
    You can run it underneath the vehicle for an easy install/straight run as well,drill or find a spot to bring it back up to the battery terminal in the rear.Cover the wire with split loom,and secure with Zip ties even,or other means of security for the wiring.
  10. Thanks basswiigee thanked for this post
  11. #24
    audiobaun's Avatar
    Jun 2011
    Tx
    9,245
    25 Post(s)
    2153 Post(s)
    But if you want to run 600+ true RMS wattage,and maintain proper voltage, you have to get that big three done.And do it in 0ga is highly recommended,.
  12. #25
    basswiigee's Avatar
    Apr 2013
    MICHIGAN
    3,337
    4 Post(s)
    1112 Post(s)
    thank you all for the advice, im gonna take it and get it done, definitely mandatory as everything in that car is electric and is a must, appreciate it guys, would do it myself if the batt. was under the hood...
  13. #26
    audiobaun's Avatar
    Jun 2011
    Tx
    9,245
    25 Post(s)
    2153 Post(s)
    There may be someone on this Forum in your area that can help you do it,and save you some money,and make sure it is done properly.supply Lunch,and the materials would be good enough for me
  14. #27
    basswiigee's Avatar
    Apr 2013
    MICHIGAN
    3,337
    4 Post(s)
    1112 Post(s)
    Quote Originally Posted by audiobaun View Post
    lol i wish u werent across the country from me! i got a cuz that works at car tunes so i should be able to get it down cheap with a little drive...
  15. #28
    basswiigee's Avatar
    Apr 2013
    MICHIGAN
    3,337
    4 Post(s)
    1112 Post(s)
    p.s.s i'm near detroit, ya really dont trust many people around here, lol go to get the big 3 and wind up with 357... lol
  16. #29
    mylows10's Avatar
    Sep 2009
    monterey , ca
    54
    22,442
    141 Post(s)
    1 Thread(s)
    6015 Post(s)
    theres a member in saginaw that may can help you
  17. #30
    basswiigee's Avatar
    Apr 2013
    MICHIGAN
    3,337
    4 Post(s)
    1112 Post(s)
    im not too trusting in people...
  1. Wiring Help? What do I need..
    By Carsen in forum Wiring, Electrical and Installation Help
    Last Post: 07-30-2009, 04:55 PM
  2. Help me with a install what do i need etc.
    By Joseph23 in forum Wiring, Electrical and Installation Help
    Last Post: 10-18-2007, 07:38 PM
  3. What do I need!! Serious Help Here
    By KickerNeedHeLp in forum Subwoofers
    Last Post: 08-25-2006, 08:14 PM
  4. PLEASE HELP! What do i need?!
    By iltoivfe in forum Amplifiers
    Last Post: 10-22-2005, 08:13 PM
