Results 1 to 11 of 11
Reload Thread: Help please.
    Silver's Avatar
    Silver is offline CarAudio.com Veteran
    May 2004
    Brighton, MI
    30
    2,703
    1 Post(s)
    3 Post(s)
    Help please.
    07 Jeep Grand cherokee.
    I just installed a Infinity Basslink into my new jeep, but I'm running into an issue. I have the Premium sound in my jeep aswell. I did a LOC, but I think it hooked up wrong. I hooked it up behind the radio (rear speakers). The sub volume stays consistent no matter what volume the radio is at. It eventually cancels out.
    Do I have to hook up my LOC between the amp's output and the speakers? Also, should I wire them to the front door speakers instead?? I was reading those speakers are actualy the low range speakers. Thanks in advance.
    http://www.caraudio.com/forums/signaturepics/sigpic14041_2.gif
    07 Jeep GC - Viper reps / afe stage 2 / chipped / h&r lowering springs
    Stock stereo
    nvturbo's Avatar
    nvturbo is offline Senior VIP Member
    Nov 2012
    North Carolina
    158
    28 Post(s)
    Re: Help please.
    Are you sure you wired it correctly with the correct POLARITY? Take a look at your work because it sounds like a simple fix. It doesn't matter what brand of speakers is installed in the rear.....even if there are no speakers there at all. The LOC is converting the signal from the headunit (to the speakers) to run your amp.
    1997 Honda Del Sol Si
    * ///Alpine CDA-9851 CD player
    * Audio Control 2XS crossover
    * Soundstream Reference 500s
    * Precision Power PPI-2030M
    Front -- Morel Maximo 6 6.5" components
    Rear -- Pioneer TS-A1686R 6.5" speakers
    Sub -- American Bass XD1044 (pair)
    robert420's Avatar
    robert420 is offline Senior VIP Member
    Dec 2012
    geneva ne
    338
    86 Post(s)
    Re: Help please.
    ^^ basically. it doesent really matter if you splice it into the speakers or directly out of the hu. even if your jeep didnt have speakers, you could just splice the LOC into the existing wires
    Silver's Avatar
    May 2004
    Brighton, MI
    30
    2,703
    1 Post(s)
    3 Post(s)
    Re: Help please.
    Figured out the sub cancelling, the phase was wrong on the amp, but I'm still having a volume issue. Even with the HU at 1, the sub plays at full tilt. Does anybody know if the output of the amp on a factory system is also volume control??
    Stock stereo
    shrowihr's Avatar
    shrowihr is offline Member
    Sep 2012
    dslfih,woiju
    119
    28 Post(s)
    Re: Help please.
    a lot of time they are. I would use some scotch lock connectors and try installing the LOC after the amp. most factory amps push about the same as an aftermarket headunit so it shouldn't be a big deal. try it.
    CrossoverOre's Avatar
    CrossoverOre is offline CarAudio.com Elite
    May 2012
    oregon
    1,041
    205 Post(s)
    Re: Help please.
    on this particular vehicle you have to go on the output of the fact amp. the communication to the amp from the head is in a data format. fader balance and volume are done this way. Thats why when you replace the factory head you actually lose the fade. Go to the output of the amp and you will be good to go.
    mylows10's Avatar
    mylows10 is offline B2,singer,ampere rep mylows10 is a Supporting Member of the forum!
    mylows10 is a Supporting Vendor of the forum!
    Sep 2009
    monterey , ca
    54
    22,432
    141 Post(s)
    1 Thread(s)
    6011 Post(s)
    Re: Help please.
    thats why you tap the wires before the stock amp not after
    pioneer avhx 4800 dvd, ampere tfhe 9.0 and 150.4 with arc audio xxd 4080
    4 d3100 and 3 deka 8a31 and d975 ,270 dc power and 320 amp singer alt
    B2 ref mids,Cdt es6 mids cdt es 010 tweets x2 ,es 03 Mids x 2 mx1000 , sky high ,eb flex, and stinger hpm o gauge wires ,also 2 crossfire xsv2 18s in a 4th order no wall box
    NOR CAL DB DRAG JUDGE
    http://www.dcsoundlab.com
    May 2012
    oregon
    1,041
    205 Post(s)
    Re: Help please.
    Quote Originally Posted by mylows10 View Post
    this car you have to do after the amp.
  9. #9
    mylows10's Avatar
    Sep 2009
    monterey , ca
    54
    22,432
    141 Post(s)
    1 Thread(s)
    6011 Post(s)
    Re: Help please.
    Quote Originally Posted by CrossoverOre View Post
    find them behind the deck
  10. #10
    May 2012
    oregon
    1,041
    205 Post(s)
    Re: Help please.
    thats how he has them now and the vol is fixed. That is how these decks work. the signal out of the deck is fixed and the data control of the head makes the output of the amp attenuate.
  11. #11
    Silver's Avatar
    May 2004
    Brighton, MI
    30
    2,703
    1 Post(s)
    3 Post(s)
    Re: Help please.
    Thanks a bunch man. That did the trick!!
    Stock stereo
  1. I need help please!!!!!
    By 02CaddyTruckOnDUbDueces in forum General Discussion
    Last Post: 05-08-2002, 07:33 PM
  2. I still need help....please refer to my 01-03-02 post!
    By crash_n_burn69 in forum General Discussion
    Last Post: 01-04-2002, 05:28 PM
  3. I NEED HELP ..PLEASE!!!!!!!!!!!!
    Last Post: 01-03-2002, 04:01 PM
  4. NEWBIE HERE..need help PLEASE..!!!!!!
    By Tryin2bump in forum General Discussion
    Last Post: 12-29-2001, 10:58 AM
  5. NEWBIE HELP PLEASE.....
    By Tryin2bump in forum Subwoofers
    Last Post: 12-29-2001, 12:41 AM
