Page 3 of 3 FirstFirst 1 2 3
Results 31 to 34 of 34
Reload Thread: How much coverage do I need?
  1. #31
    keep_hope_alive's Avatar
    keep_hope_alive is offline Acoustics Engineer keep_hope_alive is a Supporting Member of the forum!
    May 2007
    Quad Cities, IL
    7,082
    28
    48 Post(s)
    1502 Post(s)
    Re: How much coverage do I need?
    adding substantial mass to the thin metal panels will help, especially with 100%+ coverage.
    you don't get true damping, and it smells, but it will be better than nothing.
    i've used the asphalt based sheets that parts express used to sell in some previous cars (8+ years ago). put a large sheet on each front door - covered the entire door. it did the job of a noise barrier but didn't stick for shyt.
    if you want to lower road noise, you could use peel-n-seal, but best to put foam or carpet padding between it and the metal so it acts as a barrier. MLV is the superior option for this though.
    got a question? shoot me a PM. Matthew 6:9-15 - YouTube Channel: https://www.youtube.com/channel/UCkYUo2EShW9lgtrfXiDvLNQ/videos
    2014 Accord build log: http://www.caraudio.com/forums/car-audio-build-logs-cars-trucks-suvs/608637-2014-accord-sport-sq-build-keep_hope_alive.html
    2001 Accord build log: http://www.caraudio.com/forums/car-audio-build-logs-cars-trucks-suvs/536049-2001-accord-ex-sedan-its-long.html
    My 1966 MGB: http://www.mgexp.com/journal/keephopealive
    Fix Photobucket Image Loading ------> https://addons.mozilla.org/en-US/firefox/addon/photobucket-fix/ <------
  2. #32
    mlstrass's Avatar
    mlstrass is offline Shaggy DOA
    Jul 2006
    Illinois
    10,782
    6 Post(s)
    1266 Post(s)
    FYI....peel & seal does NOT smell. Not sure why everyone says that...
  3. #33
    autobotguy's Avatar
    autobotguy is offline Junior Member
    May 2013
    Portland, OR.
    14
    4 Post(s)
    I know I'm new on this forum, but I too can attest that although its not an ideal product and it is being used outside of its intended use, Peel & Seal does somewhat work. I've used it on my '90 Maxima to deaden some trunk rattle and it really worked. It took 2 completely layers, but at the time the Peel & Seal was only like $12 a roll, so cost wise it was preferable to the only other product out there at the time which was Dynamat.
  4. #34
    raptor727's Avatar
    raptor727 is offline come get some!!
    Apr 2012
    pensacola FL
    1,817
    1 Post(s)
    559 Post(s)
    Same here peal and seal worked for me too didn't have a meter to check for gains but it **** sure helps wih rattles...And about it not sticking if you clean properly you shouldn't have an issue, i live in florida and had it on my roof for two+ years without an issue. just my two cents
  1. How much power do I need for 3 amps
    By pilyin in forum Wiring, Electrical and Installation Help
    Last Post: 03-16-2004, 03:40 AM
  2. How much dynamat do I need???
    By slh in forum General Discussion
    Last Post: 02-23-2003, 02:46 AM
  3. how much room do i need....
    By mgaidica in forum Enclosure Design & Construction Help
    Last Post: 02-09-2003, 04:37 PM
  4. How much power do i need
    By jeeper in forum Amplifiers
    Last Post: 08-20-2002, 02:56 PM
  5. how much power do i need?
    By hiloracerboy84 in forum Subwoofers
    Last Post: 02-21-2002, 07:33 PM
