Page 2 of 3 FirstFirst 1 2 3 LastLast
Results 16 to 30 of 34
Reload Thread: How much coverage do I need?
  1. #16
    Bass911's Avatar
    Bass911 is offline CarAudio.com Elite
    Sep 2007
    Dallas,TX
    1,111
    90 Post(s)
    Re: How much coverage do I need?
    One of my friends had an Audiobahn amp with a meter with the needle. He had no choice but to put the amp on the box. The box had overkill bracing. The bass was hitting so hard it was rattling the meter and needle. It looked like it was about break. We put 2 layers of Peel n Seal on the back of the amp and screwed it back on the box. Peel n Seal saved the day again. The meter was perfectly still under heavy bass conditions. It must be my imagination that it works? I can't really tell that any of you have used it that claims it does nothing?
  2. #17
    whitedragon551's Avatar
    whitedragon551 is offline Moderator
    Mar 2009
    IL
    13,564
    40 Post(s)
    1409 Post(s)
    Quote Originally Posted by J31Rob View Post
    You can't tell me that if directly applied to sheet metal that it won't stop rattles. I'm not suggesting he use it by any means.. but in a pinch it will stop a sheet metal rattle such as an import trunk.. such as my 93 Corolla that used it for about 2 years when I was young and dumb. It went from sounding like literally a tin to...... not sounding like a tin can.
    Exactly why Ill never buy AT stuff. Ignorance is bliss.
    Quote Originally Posted by Bass911 View Post
    Peel and Seal does not work. Deadener works by the butyl layer contracting and expanding under vibration and turns that energy into heat and dissipates through the aluminum layer. Asphalt does not absorb vibrations. Their is empirical scientific data out there that proves even laying it on does nothing for you. Read up on the 1/4 wave theory.
    This will get you started on the scientific information behind deadener and what each piece of the puzzle does and does not do for you.
    http://sounddeadenershowdown.com/how...o-applications
    CA.com FAQ's
    CA.com TOS Agreement
    Forum Rules
    HU: ///Alpine 9887, KCE-400BT, KCE-433IV, KTX-100EQ Imprint, 8Gb iPod Touch
    Front Mids: Eclipse SC6500
    Front Tweeters: Morel made Xtant 28MM Silks
    Subs: Audiomobile Evo 10" TC2+
    Enclosure: 1.1 Cubes sealed with 10 Ounces Poly Fill
    Amp: Audio Systems Twister F6 380 III
  3. #18
    Kingstroker's Avatar
    Kingstroker is offline Mr Dique
    Oct 2012
    Guthrie, OK
    381
    123 Post(s)
    just a promo
    '05 F250 King Ranch Crew Cab 4X4 Off Road Modded Powerstroke
    Rebuild in process
    Pioneer DEH 80PRS
    Modded Linear Power LP4753IQ
    Front Woofer: Infinity Kappa Perfect 6.5"
    Front Tweeter: SEAS Neos in pods
    Back: Pioneer TS-D6802R
    Knukonceptz Karma 12ga
    Stinger HPM3 RCA's
    Big 8: PhoenixGold Oga
  4. #19
    Bass911's Avatar
    Sep 2007
    Dallas,TX
    1,111
    90 Post(s)
    The science is wrong or they can't figure out the proper term for what Peel n Seal really does. Maybe Peel n Seal is using dark matter to absorb the sound? I could point you to Peel n Seal before and after YouTube videos, but we both know real video proof is not scientific enough for you. I was never looking for the best deadner. I'd rather use Raamat or Second Skin. I'm well aware of what Peel n Seal is. My truck never sounded like a tin can without deadening. I just wanted to try it since I'm replacing the carpet. The interior has a few new rattles due to heavy bass, and that is my main concern. It is mostly plastic trim pieces buzzing.
  5. #20
    mlstrass's Avatar
    mlstrass is offline Shaggy DOA
    Jul 2006
    Illinois
    10,782
    6 Post(s)
    1266 Post(s)
    Dragon get up on the wrong side of bed today?
    Whether you like it or not P&S does stop vibrations/rattles. I've used it on quite a few cars before more deadener companies came out and prices went down.
    It might just add mass and raise the freq at which the panel will resonate, but either way it will work.
  6. #21
    mlstrass's Avatar
    Jul 2006
    Illinois
    10,782
    6 Post(s)
    1266 Post(s)
    Now for a diff question: which deadener will stay stuck to a roof and not come loose?
    I've used 3-4 of the most popular last summer and ALL of them have fallen off or come loose in areas. Roofs were all dust/rust free and wiped down with acetone before applying. All were applied with a roller.
  7. #22
    btsteinb's Avatar
    btsteinb is offline Member
    Nov 2011
    United States
    70
    25 Post(s)
    Quote Originally Posted by whitedragon551 View Post
    Great reason... I have had b stock 80 mil on my roof for 2 years without a single issue.
    Coleman has some of the best CS I have ever dealt with too. Don't be so quick to judge that which you have no experience with. Maybe try stuff out instead of being an e thug.
    Feedback
    http://www.caraudioclassifieds.org/forum/itrader.php?u=13232
  8. #23
    Mar 2009
    IL
    13,564
    40 Post(s)
    1409 Post(s)
    Quote Originally Posted by mlstrass View Post
    Not how deadener works. In order to lower resonant frequency of a panel you need to apply the 1/4 wave theory. That would require 34 inches of material on top of the door skin.
    CA.com FAQ's
    Forum Rules
  9. #24
    mlstrass's Avatar
    Jul 2006
    Illinois
    10,782
    6 Post(s)
    1266 Post(s)
    You have lots of theory, but I'm guessing very little real world experience using Peel & Seal and building loud cars with no rattles...
  10. Dislikes jockhater2 disliked this post
  11. #25
    jockhater2's Avatar
    jockhater2 is offline CarAudio.com Veteran
    Sep 2011
    Saukville, WI
    3,037
    1282 Post(s)
    Head Unit Pioneer P99RS
    3 Runs of 1/0 OFC Power and 3 Runs of 1/0 OFC Ground
    1 XS Power D3400 & 2 XS Power XP3000 with Copper Bus Bars
    380 Amp & 320 Amp Iraggi Alternators(One is a chevy case, the other ford)
    RD 7500.1 running 2 12 inch SPLaudio (AA Mayhem motors/baskets)
    Tuned to 36 hertz. About 4.5 cubic feet, 8" Aeroport (made by dbeez)
    Zed Audio Leviathan III on Morel MDT-29, RS100-4 & RS225-8 Daytons
    Alex Jones www.infowars.com Endgame, Obama Deception, Truth Rising,
    Fluoride in the water, poison in vaccines, chemical trails in the skyglobal
    elite banks run our government towards a one world global government.
  12. #26
    btsteinb's Avatar
    Nov 2011
    United States
    70
    25 Post(s)
    What do you know about loud cars... You have only built 2 160+ of your own, and like 10 other 55+ vehicles.
    Feedback
  13. #27
    mlstrass's Avatar
    Jul 2006
    Illinois
    10,782
    6 Post(s)
    1266 Post(s)
    Quote Originally Posted by jockhater2 View Post
    You swing way too hard....
  14. #28
    keep_hope_alive's Avatar
    keep_hope_alive is offline Acoustics Engineer keep_hope_alive is a Supporting Member of the forum!
    May 2007
    Quad Cities, IL
    7,080
    28
    47 Post(s)
    1502 Post(s)
    What are you bishes babbling about?
    got a question? shoot me a PM. Matthew 6:9-15 - YouTube Channel: https://www.youtube.com/channel/UCkYUo2EShW9lgtrfXiDvLNQ/videos
    2014 Accord build log: http://www.caraudio.com/forums/car-audio-build-logs-cars-trucks-suvs/608637-2014-accord-sport-sq-build-keep_hope_alive.html
    2001 Accord build log: http://www.caraudio.com/forums/car-audio-build-logs-cars-trucks-suvs/536049-2001-accord-ex-sedan-its-long.html
    My 1966 MGB: http://www.mgexp.com/journal/keephopealive
    Fix Photobucket Image Loading ------> https://addons.mozilla.org/en-US/firefox/addon/photobucket-fix/ <------
  15. #29
    phamduyseo11's Avatar
    phamduyseo11 is offline Junior Member
    Apr 2013
    pham duy
    23
    topic hay d?y.up top cho b?n nè
  16. #30
    CrossoverOre's Avatar
    CrossoverOre is offline CarAudio.com Elite
    May 2012
    oregon
    1,041
    205 Post(s)
    just gonna add my 2 cents. like 10 years ago we applied about 12 boxes of asphalt peel and seal to the entire interior of my friends honda crx. afterwards with no interior except dash and seats we drove around. It sounded like a mercedes in there after we were done. almost no road noise at all. before the p&s it was a loud as **** ride and after complete opposite. Deducing from this that the p&s actually reduced the amount of vibration of the metal of the vehicle there by making it a quieter ride.
    Sorry dragon the stuff might not be the best choice but it does in fact do something.
  1. How much power do I need for 3 amps
    By pilyin in forum Wiring, Electrical and Installation Help
    Last Post: 03-16-2004, 04:40 AM
  2. How much dynamat do I need???
    By slh in forum General Discussion
    Last Post: 02-23-2003, 03:46 AM
  3. how much room do i need....
    By mgaidica in forum Enclosure Design & Construction Help
    Last Post: 02-09-2003, 05:37 PM
  4. How much power do i need
    By jeeper in forum Amplifiers
    Last Post: 08-20-2002, 03:56 PM
  5. how much power do i need?
    By hiloracerboy84 in forum Subwoofers
    Last Post: 02-21-2002, 08:33 PM
