Page 2 of 2 FirstFirst 1 2
Results 16 to 26 of 26
Reload Thread: Space Issue for Batts...
  1. #16
    bgowdy's Avatar
    bgowdy is offline HE NEEDS SOME MILK
    Apr 2011
    Campbellsville, Ky
    7,837
    71
    2 Post(s)
    2487 Post(s)
    Re: Space Issue for Batts...
    Quote Originally Posted by Wanacustomx View Post
    Actually with a better designed box, or more efficient, wouldn't your amp see a lower ohm load more often. ( you wouldn't get as much box rise) so you would actually use more power and have lower voltage.. I'm only usin 4 xs batts for the nendo 5.5k and 1s a starting.. You should be fine with 2 supplementary batteries...
    well in that case i have a battery under hood for the truck itself. then i have the 3 xtra batts. but only really enough room for the 2.
    06 DODGE STRATUS SXT
    Subs: Sundown ZV4 15 D1 Rev1 Motor/Rev2 Softies
    Enclosure: 3.85 Cubes Net Tuned 36hz
    Amp: Soundstream Ta.3kw @ .5ohm
    Stock 120a Alt ~1 XS D3400 & 1 Kinetic HC1800 ~ Multiple runs of Bullz Audio 1/0
    Loudest Build Score ~ 148
    F.C.B.C. > 2010 450 Street 3rd Place Overall > 2011 450 Street Champion
    YOUTUBE SEARCH->bgowdy31 & bgowdy3131
  2. #17
    bgowdy's Avatar
    Apr 2011
    Campbellsville, Ky
    7,837
    71
    2 Post(s)
    2487 Post(s)
    Quote Originally Posted by dbeez View Post
    Yes the ones you took today I will comment on it also box is better wouldnt say super efficient
    na i know its not super efficient or nothing but just rounded smooth insides, and more port area and what not. still double plated birch all the way around and of course the all thread front to back. i have 2 dial rods i can put in from top to bottom but idk if im going to or not.
  3. #18
    bgowdy's Avatar
    Apr 2011
    Campbellsville, Ky
    7,837
    71
    2 Post(s)
    2487 Post(s)
    Quote Originally Posted by bhsdriller View Post
    no way a 3100 would fit under the hood in the Blazer
    You'd probably be ok with 2, test it and see is the only real way to find out
    true... what size batt would fit under the hood
  4. #19
    dbeez's Avatar
    dbeez is offline CarAudio.com Veteran
    Nov 2008
    crestwood,ky
    9,436
    1 Post(s)
    915 Post(s)
    Quote Originally Posted by bgowdy31 View Post
    Well I will be at the show sunday morning for a little bit I ill kick some ideas your way.
    2002 suburban
    Security System Code alarm
    Electrical Dc power sp270 7 deka 9A31's and lots of 1/0
    Headunit pioneer 880prs
    Amps 2 Sax125.2 front stage crossfire [email protected]
    Wiring lots of 1/0 stinger, tsunami
    Mids & Tweeters 2 sets cdt m6+ mids 2 sets cdt tw25 tweets
    Subs 2-18" nightshade v2's d2
    System DetailsDaily driver.
  5. #20
    Wanacustomx's Avatar
    Wanacustomx is offline Senior VIP Member
    Jul 2012
    Myrtle beach south carolina
    388
    126 Post(s)
    You should be more than fine with the 2 extra
    Head unit: kdcx-996
    Sub stage: (4) Shok Industries Titan 12"
    Sub Amp: (2)Crescendo Audio BC5500d
    Front Stage: (4) PWX 6.5's (2) PWX 10's (4) FT1 supertweeters
    Rear Stage: (4) PWX 6.5's (2) PWX 10's (2) FT1 supertweeters
    Amps: (2) Crescendo Audio C1100.4's (1) Image Dynamics Q700.2
  6. #21
    bgowdy's Avatar
    Apr 2011
    Campbellsville, Ky
    7,837
    71
    2 Post(s)
    2487 Post(s)
    ok kewl. i may have the 3rd batt hooked up but idk yet. regardless ill have it with me. i still have to get my ports in, connect all my batteries and hook up my amp and ill be ready. im not expecting any stellar numbers or nothing but better then a 147.8 lol. my box has breathing room now, and it looks 1000 times better atleast....
  7. #22
    bgowdy's Avatar
    Apr 2011
    Campbellsville, Ky
    7,837
    71
    2 Post(s)
    2487 Post(s)
    i would really like to actually get rid of that battery tho. the battery sux....
  8. #23
    Lexicon740iL's Avatar
    Lexicon740iL is offline AGM FTW!
    Jan 2013
    Minneapolis, MN
    187
    76 Post(s)
    Your 95 Blazer takes a group 75 Side terminal battery.
    You could go with a Yellow Top 8042-218
    or one of our AGM X2 Power Products the SLI75AGMDT
    Either of those options will give you some extra capacity in your battery bank.
    Let me know if you need help sourcing one. I'm work for the biggest battery retailer in the nation.
  9. #24
    bgowdy's Avatar
    Apr 2011
    Campbellsville, Ky
    7,837
    71
    2 Post(s)
    2487 Post(s)
    Quote Originally Posted by Lexicon740iL View Post
    kew... thing is i would like to trade the 3rd one off for a batt if anything. also would a group 24 battery fit up there? i dont need side terminal batteries for the way my trucks wired. i have everything setup for top post under my hood including accessories.
  10. #25
    bhsdriller's Avatar
    bhsdriller is offline CarAudio.com Veteran
    Jul 2007
    bakersfield,ca
    4,491
    344 Post(s)
    xs d3400 is a popular batt for blazers....have to trim the tray a little for it to fit but other then that there's no problem. Get the xs ibar kit also and you can have the stock sidepost connection, and then connect all your extra **** on top of the battery
    Team Flex Issues
    4 18" Mayhems
    2 bc5500's
    Bought from: ameduce(x2), Hatchet_Warrior, jeeper07,DB_DRAG_SPL,ssackett, lyttleviet,MillzThaYungin, blackbonnie, ryan1126, Goindef154(x2), Lonnie, dave_damage
    Sold to: Ilovebass, nismos14, chednompton, teen, jonesy
  11. #26
    bgowdy's Avatar
    Apr 2011
    Campbellsville, Ky
    7,837
    71
    2 Post(s)
    2487 Post(s)
    With the way mines setup now i can wire everything on top
  1. space issues
    By liftedcj7on44s in forum Enclosure Design & Construction Help
    Last Post: 04-15-2008, 12:21 PM
  2. WTB(or trade for) batts, alt
    By blong131 in forum Wanting to Buy (WTB) - Car Audio
    Last Post: 10-23-2007, 08:05 PM
  3. Sub space issues though...
    By KingSham in forum Subwoofers
    Last Post: 09-26-2007, 11:06 PM
  4. good price for batt?
    By stishdr in forum Wiring, Electrical and Installation Help
    Last Post: 04-13-2007, 11:53 PM
  5. ok yet ONE more what sub/amp question. (space issues)
    By WheresTheButta in forum Subwoofers
    Last Post: 04-14-2005, 08:26 PM
